RCI maxtrac mounts
Discussion in 'Recovery & Gear' started by TheBeast, Apr 13, 2018.
  1. Apr 13, 2018 at 5:08 PM
    TheBeast
    TheBeast [OP] The Beach
  2. Apr 13, 2018 at 5:20 PM
    Eclipsed & Floating
    Eclipsed & Floating Over it.........
    I’m right where I need to be
    Voluptuous Whitey
    I can’t imagine why they wouldn’t.
  3. Apr 13, 2018 at 5:25 PM
    Flyinryank
    Flyinryank New Member
    Las Vegas, NV
    White 2015 CM 4x4
    Wish someone would make a mount for maxtrax that mounts to the bed rails...
    Sunnier and TheBeast[OP] like this.
  4. Apr 13, 2018 at 5:31 PM
    Sunnier
    Sunny
    San Diego, CA
    TheBeast[QUOTED][OP] likes this.
  5. Apr 13, 2018 at 5:35 PM
    T-Rex266 Moderator Staff Member
    No idea.
  6. Apr 13, 2018 at 5:35 PM
    TheBeast
    bunch of us jumped on the TRED Pro group buy and i cannot find any mounts for the bed rails. You would think a company would start making them and make $$.
    Sunnier likes this.
  7. Apr 13, 2018 at 5:37 PM
    Agitated1
    Agitated1 Newish Member
    Los Angeles
    2017 Tundra Crewmax TRD 4x4 Quicksand
    TRD Pro Grill King Coilovers with compression adjuster Tint 5% Rear, 30% front and 70% windshield Husky X-Act Floor liners BA Muffler 8in standard system Truck Covers USA retractable bed cover Yakima bed rails
    I read that recently as well!
    Sunnier[QUOTED] likes this.
  8. Apr 13, 2018 at 5:45 PM
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    7" BDS, ADS front and rear, Total Chaos UCA's, CB tie rods
    If they make mounts for a Tacoma, they may work. I'm using HiLift jack brackets for Tacoma's on the Tundra. I keep my tred ramps (forgot the brand) behind a cargo net in the bed. Doesn't look pretty but I've known where they're at every time I've had to use them.
    TheBeast[OP] likes this.
  9. Apr 13, 2018 at 6:07 PM
    Bailey
    Bailey Enjoy Every Sandwich
    CO
    2011 DCSB Limited 4x4 “Clifford”
    They will not. Maxtrax and the TRED Pros have different mounting hole spacing.
    A friend tried mounting his TRED Pros to my Maxtrax mounts and it didn't work.
  10. Jun 10, 2018 at 4:31 PM
    the_midwesterner
    the_midwesterner New Member
    Luis
    2016 Tundra TRD Pro - Quicksand
    None, yet....
    In lieu of sounding cheesy, but if you check out the IG linked in my signature, you can see what I did.
    I used the new Rago Fab bed rail plates and mounted the Tred Pros to it and mounted them to the front portion of the bed.
    EDIT: added pics
    Black Wolf likes this.
  11. Nov 27, 2018 at 4:51 PM
    brimy311
    brimy311 New Member
    Kalamazoo
    2018 Tundra Platinum
    Kind of an old thread. Just ordered tred pro tracks, going to figure out some mounting options for the tundra!
    Sunnier likes this.
