Trying to install 2 more horns along with original horn without blowing out fuse
Discussion in 'General Tundra Discussion' started by Jt32404, Mar 27, 2016.
  1. Mar 27, 2016 at 4:35 AM
    Jt32404
    Jt32404 [OP] New Member
    2007 toyota tundra crewmax
    I have just bought the wolo model 308-2t sound blaster horn, and i already have the wolo model 200 and along with the original horns to my tundra im trying to hooked up at same time, its loud now but also i blow the 10amp fuse after 1 push of the button, so how could i have my new loud horn system work all the time without blowing out the fuse? Can any help out with a remedy for what I'm trying to accomplish?
  2. Mar 27, 2016 at 4:47 AM
    Jt32404
    Im thinking i may need to install 2 10amp inline fuse holders to the other 2 horns, would that work?
  3. Mar 27, 2016 at 6:46 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Might want to do a relay and pull the power from the battery with a fuse rated for the wire size.
    AZ Pete likes this.
  4. Mar 27, 2016 at 7:58 AM
    Jt32404
    When i did the wolo model 200 in my geo tracker with its original horn i never had the issue of blowing a fuse but i guess since im trying to do pretty much 6 horns all together ill get some relays and inline fuses thanks guys ill see if that does it, if not ill just try to just get and hook up 1 set of horns that would be the same loudness
  5. Mar 27, 2016 at 11:58 AM
    mdavis
    mdavis I need a beer.
    Michael
    Rock Hill, SC
    What the hell do you need 6 horns for?
    rons23 likes this.
  6. Mar 27, 2016 at 5:14 PM
    LOTSOFTOYS
    LOTSOFTOYS Toyota Whisperer
    Jace
    Mile high
    2005 Tundra DBL cab
    Curious as well^^^^
    But yes you are overloading the stock circuit of 10 amps. Which btw is alot.... your horns are pulling some serious current. Find out how much they draw and run a seperate circuit using a big fuse, bigger wire and a nice relay. Similar to an aftermarket offroad light circuit....
