Trail Grap vs Toyo MT?
Discussion in 'Wheels & Tires' started by Rngr188, Jun 6, 2018.
  1. Jun 6, 2018 at 3:08 PM
    Rngr188
    Rngr188 [OP] Ranked the best new member of all time
    Chad
    Harrison AR
    2020 1794 MGM TRD OR
    I know they're the same company and very similar but in a 275/70/r18 which could I expect the best performance out of, assuming proper psi and rotation schedule? We get some winter here and I know these aren't the best for ice but I don't think what little we get should be a factor. It seems the Trail has better siping across the lungs, would that be a plus for them? My truck is a weekend driver as I have a company car. We do some Ozark Mountain gravel/dirt roads with some sharp rocks poking up that can gouge a tread. I hear good tread life from both, my buddy had the Trails on a 2500 Cummins that he replaced at 70k and loved them. Is there an advantage of one over the other? I priced locally and the Trail comes in about $18 cheaper per tire over the OC MT.
  2. Jun 7, 2018 at 4:32 AM
    parker44
    parker44 New Member
    2008 Tundra - Desert Sand Mica
    You are going to get more of personal preferences on this, as people will swear by both of them. I don't think you will be upset with either tire. I personally like the looks of the trail grapplers a little better, so that's what I would probably go with. As far as performance goes, I don't think there is going to be much difference with what you get.
  3. Jun 7, 2018 at 5:06 AM
    Rngr188
    Chad
    Harrison AR
    Kind of what I've gathered after doing some research but was curious if anyone here has ran both and could share their experience with each.
