Dirty deeds dual exhaust
Discussion in 'Performance and Tuning' started by Yoda21, May 31, 2018.
  1. May 31, 2018 at 7:48 PM
    Yoda21
    Yoda21 [OP] New Member
    Hayward ,ca
    2022 limited Trd crew max
    Can u make either the six in or eight in set up a dual exhaust out the sides behind the tires
  2. May 31, 2018 at 7:50 PM
    boostedtrdpro
    boostedtrdpro voided warranty
    Jeremy
    2019 SC TRD Pro CM 040 2020 Sequoia TRD Pro 040
    Short answer, yes. The TRD dual replacement does just that.
  3. Jun 1, 2018 at 7:50 AM
    dirtydeeds
    Keith
    USA
    2003 and 2013 tundra
    more than I can list here
    KTJO 4x4 and boostedtrdpro like this.
  4. Jun 1, 2018 at 7:55 AM
    Yoda21
    Hayward ,ca
    Yea cuz I was looking to do the eight in with duals out the sides
  5. Jun 1, 2018 at 8:40 AM
    Jengel451
    Jengel451 Misanthropist
    The Bitterroot, MT
    just got a Tundra and was looking at that system. is the price on your site only the mid section? and then i'd need to buy the TRD tailpipes separately? 2017 model.
  6. Jun 1, 2018 at 9:08 AM
    dirtydeeds
    Keith
    USA
    Yessir. Price is for muffler section. You would need to purchase tailpipes from your local dealership.
    The pic shows the tailpipes bolted up for demonstration purposes.
  7. Jun 19, 2018 at 7:22 PM
    Marco
    Marco New Member
    MBRP dual exhust sounds very throaty note engine runs cooler.
  8. Jun 19, 2018 at 7:24 PM
    dirtydeeds
    Keith
    USA
    Really, what was the temp before? And what device do you use to measure the temp? What is new temp after exhaust install? Just curious I’ve never heard of such a thing.
    boostedtrdpro likes this.
  9. Jun 19, 2018 at 7:30 PM
    Marco
    Marco New Member
    Temperature gauge. The gauge indicates a lower reading with Dual exhust.. as compared to the stock exhust.
    Not rocket science.
  10. Jun 19, 2018 at 7:32 PM
    Marco
    Marco New Member
    It’s common sense. Dual exhust flows freely removes HOT exhust gases more efficiently...
    dirtydeeds likes this.
  11. Jun 19, 2018 at 7:39 PM
    CaptainJohnnySR5
    CaptainJohnnySR5 Tundra Lifer Now!
    Capt Johnny
    Winter Garden Fl
    2012 Silver Tundra 5.7 SR5 2WD DC TRD Upgraded. 2017 SR5 TSS Off Road 4x4 DC Blazing Blue. 2019 1794 White TRD Off Road 4x4 CM
    I am totally addicted to Tundra Life now!
    :duel:Here we go.....
  12. Jun 19, 2018 at 7:40 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
  13. Jun 19, 2018 at 7:45 PM
    CaptainJohnnySR5
    Capt Johnny
    Winter Garden Fl
    We are all friends on Tundras.com We all work as a team helping one another build eachothers dreams as efficiently as possible. Dirty Deeds builds custom Exhaust systems for a living for all of us on here and does everything possible to guide us in the right direction. No need to get aggressive in your responses. Just my 2 cents.
  14. Jun 20, 2018 at 5:15 AM
    myt1
    myt1 New Member
    Richard
    Scottsdale, AZ
    2010 Tundra DC TRD SR5 Desert Sand Mica
    OME Lift, 275/70R 18
    What type of effect will an TRD aftermarket exhaust have on gas mileage?
    I'm at 15mpg now and I would hate to go lower than that.
  15. Jun 20, 2018 at 8:03 AM
    dirtydeeds
    Keith
    USA
    Your results are very interesting. If the literally hundreds of exhaust systems that I’ve tested I’ve never seen a single one show a different temperature (I’m assuming you’re referrring to coolant temp?)
    Are you looking at the needle on the dash, or are you using a scanner to see the actual temp?
    I don’t see anything as aggressive, I’m trying to better understand the previous statement about temperature.
  16. Jun 20, 2018 at 8:05 AM
    dirtydeeds
    Keith
    USA
    Our trucks were designed by Toyota to run best with single exhaust, until you install long tube headers;)
    I’ve never specifically tested mpg with Trd exhaust. But I have tested driveability. And there is better low end torque with a single exhaust.
    You can make duals work, but you need a proper x pipe. Even then, a properly built single exhaust has better low end torque than a dual exhaust with x pipe.
  17. Jun 27, 2018 at 8:25 AM
    Marco
    Marco New Member
    Yes fluid temp. The gauge is lower with dual exhust then with single.
    I do notice that the lack of back pressure
    Has robbed the performance under aggressive acceleration.
  18. Jun 27, 2018 at 9:58 AM
    Marco
    Marco New Member
    I have noticed the drop in low end torque
    With Dual exhust. But it sounds so good.
    So the long tube headers will give a restriction effect allowing back pressure to build.
  19. Jun 27, 2018 at 10:08 AM
    Marco
    Marco New Member
    So long tube headers will create enough back pressure to aid in low end torque..
    I wonder if a remote controled in-line valves would work. To achieve back pressure
  20. Jul 1, 2018 at 7:47 AM
    dirtydeeds
    Keith
    USA
    It’s not back pressure that you want. Back pressure is an unfortunate side effect of sizing the exhaust small enough for scavenging to occur at the rpm you’re lookin for it to happen.
    Ultimately the exhaust would get bigger as rpm goes up. And smaller as rpm goes down. Then scavenging would happen and there would be no back pressure.
    Long tube headers release a massive amount of back pressure. You can size them way bigger since the length of the runner is way longer and scavenging happens way sooner with a longer runner.
  21. Jul 15, 2018 at 7:48 PM
    Yoda21
    Hayward ,ca
  22. Jul 15, 2018 at 9:39 PM
    Rica25
    Ricardo
    Tulare
    Which system did you purchase?
  23. Jul 15, 2018 at 9:44 PM
    Yoda21
    Hayward ,ca
    8in
  24. Jul 16, 2018 at 7:06 AM
    MlrTyme
    MlrTyme New Member
    I am interested in the TRD replacement. I'm just not sure which one. Debating between the mild and medium but have no clue if the medium may be too loud. Do you think you will be doing any group buys anytime soon?
  25. Jul 16, 2018 at 3:45 PM
    dirtydeeds
    Keith
    USA
    Neither is actually very loud. Even loud is still kinda mild compared to what we can make:)
    Call for details. 760-877-4234
    We are doing flat rate shipping right now. Pay the lowest amount thAt a 6’ package costs to ship and we pay the difference.
  26. Jul 18, 2018 at 3:27 AM
    zeke7681
    zeke7681 New Member
    Zeke
    PA
    2018 Black TRD Sport CM
    Keith what is your typical lead time for a stainless steel standard budget system for a 2018 CrewMax?
  27. Jul 18, 2018 at 8:21 AM
    dirtydeeds
    Keith
    USA
    I quote 30 days. Usually it’s sooner. But 30 just to be safe. 760-877-4234
    showtime240 likes this.
  28. Jul 18, 2018 at 8:34 AM
    showtime240
    showtime240 New Member
    Hi Keith,
    What about using a H pipe rather than a X pipe on a dual system?
    Basically, H Pipe, 2.5 piping, 2 mufflers, 2.5 piping, 2 exits towards the rear like the TRD
    Will a single exit exhaust still provide more low end torque?
    dirtydeeds[QUOTED] likes this.
  29. Jul 18, 2018 at 9:11 AM
    Fiestee23
    Fiestee23 A CHICK'S TRUCK
    SOCAL
    White sr5 4wd
    Hey there keitg. I am in the market for a new Mod.... I currently have my truck in the shop, but right after that. 2017 tundra sr5 crewmax...
    Here is what I'm looking for. .. some sound but not too much. My main priority is making sure I don't lose any power for towing, but still have a nice growl when accelerating. I had a magnaflow on my Tacoma but everyone seems to love your product. I'm ok with dropping behind the axle or running all the way through, but I do NOT want too much sound resignating in the cab.
    Let me know what u have for me... Or anyone... What are suggestion with the prooducts
  30. Jul 18, 2018 at 10:42 AM
    Masher59
    Masher59 New Member
    Ponchatoula, La
    2018 Platinum Tundra
    The way Keith explained it to me I believe you will be best suited with the 8" system. I was on the phone with him a few weeks ago going over the same questions. I wanted a little bit more growl so I went with the 6" and it's supposed to be here on the 20th as per FedEx. Can't wait!
