Diff breather
Discussion in '2.5 Gen Tundras (2014-2021)' started by mgtundra, May 28, 2018.
  1. May 28, 2018 at 8:24 AM
    mgtundra
    mgtundra [OP] New Member
    Joplin mo,
    2015 mg tundra
    6112 bilstein coilovers,5160 remote resivor,camburg upper arm,sway bar,Trd pro skid plate,Trd pro mg grille,high flow air intake
    Just wondering if I need this mod.im backing boat in lake every weekend and some times you’ve got to back in pretty far to get the boat to come off trailer and the stock diff breather sits right on top of rear axle.any thoughts would be appreciated
  2. May 28, 2018 at 8:27 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    It’s a cheap and easy mod to do. I definitely would.
  3. May 28, 2018 at 8:27 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Not sure if “needed” but would be good to keep water out of the diff. I did mine and I’m barely close to water. It’s a quick, cheap and easy mod to do and help protect the diff; so do it IMO.
  4. May 28, 2018 at 8:37 AM
    15whtrd
    15whtrd Mr. Blonde
    I figure they put the front diff breather up in the engine bay the rear should at least be the same. Do it! There’s a good write up around here somewhere. most people put it up behind the tail light on the driver side.
    NewImprovedRon and TXMiamiFan like this.
  5. May 28, 2018 at 8:54 AM
    mgtundra
    Joplin mo,
    2015 mg tundra
    Thanks guys I just order one from arb they have a kit they sell comes with everything,at least it will make me feel better when backing into the lake
  6. May 28, 2018 at 8:57 AM
    Wise choice! I bought the ARB too. There is a much cheaper way to fab your own if you are DIYer and I would have but was posted after I bought my ARB. :cool: All is good though!
    15whtrd and Y0TA PR0 like this.
  7. May 28, 2018 at 10:05 AM
    Over the LINE
    Over the LINE New Member
    New Orleans
    2016 Limited CM 4x4 2025 SR5 CM 4 x 4
    About halfway down my build pictures is where I put mine behind the drivers taillight. Easy mod.
  8. May 28, 2018 at 10:07 AM
    seniramsu
    seniramsu Pro Runnin
    Nate
    VA
    2017 TRD Pro Tundra Wht
    Yep easy day!!!
    B737, 15whtrd, 1UPPER and 1 other person like this.
  9. May 28, 2018 at 12:54 PM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Good choice! Cheap insurance as someone said
