joonbug's build
Discussion in '2.5 Gen Builds (2014-2021)' started by joonbug, Nov 29, 2016.
  1. May 7, 2018 at 12:38 PM
    #931
    joonbug
    joonbug [OP] °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    5-6-18
    Peligreen Jeepway
    The trip from hell. Not enough technical stuff and way too much bush. And not the good bush. Bad bad bush. Glad to knock this trail off the list but we won’t be going back.
    05B4B0FB-E76F-47B1-9743-C959F9CA2966.jpg C7DBA3B8-D4E8-4694-A89E-5B0B95C073F2.jpg
  2. May 7, 2018 at 5:53 PM
    #932
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    I think you should just skip anything with the word Jeep on it! :rofl:
  3. May 7, 2018 at 6:01 PM
    #933
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    I tried hanging out in back so they'd clear a path. Lemme tell ya, these guys suck at trail blazing... I think they might've made it worse.;)
    The last photo of the trail was taken at one of the wide spots.
  4. May 7, 2018 at 6:03 PM
    #934
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Holy cow. I would have been out clearing the way with a chain saw :eek:
  5. May 7, 2018 at 6:22 PM
    #935
    joonbug
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    Not sure what these guys are all talking about. I just hosed down my truck and there’s not a scratch on it. :notsure:
  6. May 7, 2018 at 6:24 PM
    #936
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Holy cow. Must be that new “anti-pinstripe wax” you applied last week!
  7. May 7, 2018 at 6:49 PM
    #937
    joonbug
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    Lol. Nah, that was my good side. I only want to buff one side at a time when I eventually do it, so I always lean the passenger side into the brush. You know I’m lazy like that. Here’s the bad side. Which still isn’t too bad. Actually looked even worse two weeks ago before the wax job.
  8. May 7, 2018 at 8:12 PM
    #938
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Soooo, You did make it worse for it me :annoyed: LOL
  9. May 7, 2018 at 10:20 PM
    #939
    Cemented
    Cemented Function over Form
    Manuel
    2017 Cement TRD Pro
    I totally favored my drivers side also. Subconsciously at first but then figured it made sense to minimize damage on one side.
  10. May 8, 2018 at 12:37 AM
    #940
    Spolar
    Spolar Going broke
    Zac
    Seal Beach CA
    2016 sr5
    I’ve done trails that clearly no full size truck has done in years. I don’t mind trashing my paint but the constant “nails on the chalkboard” noise does get old real quick...
    landphil, GodlessPro, JC303 and 4 others like this.
  11. May 9, 2018 at 12:59 AM
    #941
    Randy1794
    Randy1794 New Member
    Randy
    Wentzville, MO
    2014 Tundra 1794
    Joon, what brand and where did you get your gas can setup?
    Thanks
  12. May 9, 2018 at 8:33 AM
    #942
    joonbug
    Joon
    NorCal - Dublin
    2020 Long Travel DC
  13. May 9, 2018 at 8:43 AM
    #943
    GodlessPro
    GodlessPro Bougie BASTRD
    Matthew
    NorCal
    2018 Cement CM Limited
    I've got 2 of the gas can holders brand new in box. After I had them sitting around for a few months I decided to get a slightly different version. Let me know if you are interested and we can work something out.
    joonbug[QUOTED][OP] likes this.
  14. May 9, 2018 at 2:48 PM
    #944
    Randy1794
    Randy
    Wentzville, MO
    2014 Tundra 1794
    Thanks, keeping this saved for a future project. I like taking long trips, especially where gas stations are rare, looking for something to add a little comfort factor.
    joonbug[OP] likes this.
  15. May 15, 2018 at 9:47 PM
    #945
    KevinK
    Back in Arizona. Again.
    Tundras to Sedona
    Gas can related.
    We strapped ours in between the wheel well and front of the bed. An otherwise empty space for us.
    https://youtu.be/QFFHFfpOluU
  16. May 16, 2018 at 11:00 AM
    #946
    Erichudgins
    Erichudgins New Member
    Eric
    Murfreesboro, TN
    2017 Super white Limited DC
    https://www.tundras.com/threads/the-un-limited-build.25949/
    Shitll buff out:)
  17. May 26, 2018 at 2:32 PM
    #947
    joonbug
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    Truck is making all kinds of noises. Was sounding like a damn trampoline. Greased the UCAs today and got rid of the major squeaking. But still need to track down a clunking sound.
  18. May 26, 2018 at 4:08 PM
    #948
    Pale_Horse
    Pale_Horse Sooooooooo White.
    FL
    White 2013 TRD OR 4x4 DC
    Cupcake chit.
    If you find that clunking sound lmk where it is :rofl:
    I thought it was my spacer lift so I pulled that right off and put on coilovers. Still made the sound. Drove my dads stock truck and it makes the same clunk. Not sure if it is a mileage thing:notsure:
    I gave up.
    GodlessPro and joonbug[OP] like this.
  19. May 27, 2018 at 7:35 AM
    #949
    PLC721
    PLC721 New Member
    Patrick
    Chandler, AZ
    2018 Ram 2500 Cummins Laramie
    IG: PLC721
    Skid plates clunk, sway bars clunk, leaf springs chatter lol all kinds of damn noise!
    GodlessPro, TheBeast and Watt maker like this.
  20. May 28, 2018 at 9:21 PM
    #950
    KevinK
    Tundras to Sedona
    check the cams on the LCAs. Mine do it all the time after an install, time on the road/trail, then they start to clunk if I don't retorque them a couple times. I hit them with 210 lb/ft and they shut up. Then I go hit them hard again on some warehouse ramps by the house and tighten them again. Then they actually stay quiet.
  21. May 28, 2018 at 9:28 PM
    #951
    Vizsla
    Vizsla ☠️☠️☠️
    And there is probably around a 90% chance cams are not torqued to 207 ft. lbs when you get an alignment at almost anywhere. Although less apparent, don’t get me started on tie rod ends.
  22. May 28, 2018 at 10:57 PM
    #952
    KevinK
    Tundras to Sedona
    I don’t think they’ve been tight one time after an alignment.
    And tie rod ends. Fuck. Basically I go through the whole front end from rack to dif to control arms and shocks every time anyone but me touches it. And then again before any off road shenanigans.
  23. May 29, 2018 at 8:54 AM
    #953
    joonbug
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    Thanks Kevin. I’ll check them.
    KevinK[QUOTED] and GodlessPro like this.
  24. Jun 11, 2018 at 12:20 PM
    #954
    joonbug
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    6/9/18
    Poker Flat Trail
    @831Tun
    @GodlessPro
    @Cemented
    @Tundra4us
    Ran this trail again. Just a great little trail with a little bit of everything. Especially that view from the lookout tower. Just wish it had a little more technical stuff but still one of my favorite trails. The new guys freaked out a little on the start of the climb out as it was rough, tight and a little wet. ;) But they all handled it like champs.
    The line up
    Warren
    Manuel
    D
    No one ever gets pics of the truck in front :( so I snapped a couple while waiting for D to change out his flat tire. Also tested out the A-Trac again. That godawful sound it makes. :eek:
    Saddleback Lookout Tower
    31CD89CE-D499-4CB9-AA31-A742314DBE79.jpg 2A8DE1DD-45F9-4117-9151-41FE2DD96986.jpg
  25. Jun 11, 2018 at 12:26 PM
    #955
    joonbug
    Joon
    NorCal - Dublin
    2020 Long Travel DC
  26. Jun 11, 2018 at 12:58 PM
    #956
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
  27. Jun 11, 2018 at 1:13 PM
    #957
    Erichudgins
    Eric
    Murfreesboro, TN
    So f'ing jealous of your guys trails
    831Tun and joonbug[OP] like this.
  28. Jun 11, 2018 at 1:13 PM
    #958
    GodlessPro
    Matthew
    NorCal
    I purposely ran up the hill to get pictures of the lead truck, so that you wouldn't feel bad.
    And one of you relaxing.
  29. Jun 11, 2018 at 1:15 PM
    #959
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    There ya go joon! Good job matt! dont mind my other post in the Poker thread.:sorry:
  30. Jun 11, 2018 at 1:16 PM
    #960
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    I spy a gopro setup? that you matt?
