Replacing stock 6x9 with....
Discussion in 'Audio & Video' started by johnxmccoy, May 9, 2018.
  1. May 9, 2018 at 9:20 AM
    johnxmccoy
    johnxmccoy [OP] New Member
    Grove City, Ohio
    2019 Crew Max
    Any experiences with replacing factory 6x9 with a better 6x9?
    Geek Squad dude states better to replace factory and stay away from components and it the 6.5.
    Got me all confused now.
    Thanks.
  2. May 9, 2018 at 10:47 AM
    Stumpjumper
    Stumpjumper New Member
    Fate, Tx
    2017 Tundra TSS 4x4
    I would stay away from Geek Squad unless he really knows Tundras. Might want to ask how many Tundra installs he has done. I have Infinity components and very happy with them. I have not upgraded the amp yet. I was going to do the amp first but thought I would switch the order and do the speakers first. The tweeters make a big difference. You might get more bass out of the 6x9s.
    sprtbkr and Ike74 like this.
  3. May 9, 2018 at 10:57 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    get speaker adapters and run 6.5" component or coax.
  4. May 9, 2018 at 11:18 AM
    Beerdude77
    Beerdude77 New Member
    2018 Silver Sky Tundra Limited TRD CM
    Linex bed, "Toyota" Console Safe
    Probably because they don't sell speaker adapters and his computer tells him they don't fit. I think the only qualifying question those guys are asked when hired is, "Have you ever sat in a car and listened to music? Good, you're hired!"
  5. May 10, 2018 at 3:01 PM
    B737
    B737 Throbbing Member
    Jersey Shore
    2015 Tundra Double Cab Limited
    THIS x 1000
    these guys are getting as many cars done, in the shortest period of time. you be the judge of likely end result.
  6. May 10, 2018 at 3:21 PM
    ninjajay
    ninjajay Posting from the toilet
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    Toytec/Radflo Lift, Ambit RS02 18x9+0, Bridgestone Revo 3 295/70/18
    The stock 6x9 aren't exactly the same as regular aftermarket 6x9. Generally speaking, using a 6.5 with an adapter bracket is the correct approach
    Rica25 and TXRailRoadBandit73 like this.
  7. May 10, 2018 at 3:23 PM
    seniramsu
    seniramsu Pro Runnin
    Nate
    VA
    2017 TRD Pro Tundra Wht
    X2
  8. May 10, 2018 at 3:25 PM
    seniramsu
    Nate
    VA
    These are 6.5
  9. May 10, 2018 at 3:30 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    2007 Tundra 5.7 L Double Cab TRD 2WD
    TSS 20's with Cooper ATP ll's, N Fab 3 Step Nerf Bars,, Pioneer AVIC-8100NEX, Masters Tailgate Replacement Latch with Camera, 1" Maxtrac Shackles, LED Interiors/Brake/Reverse/Cargo/Fog Bulbs, Fumoto Drain Valve, Toyota Aluminium Oil Filter Housing, TRD Shift Knob, Courtesy Door Projector LEDs with Toyota Emblem, Console Tray and Lower Divider.
    What happened to the 6 x 9? Back in day, in the 80's (Dating myself) the 6 x 9's were BOSS. They were the "go to" or before subs it seemed. I remember the Pioneer's 6906 (3 way) or 6907 (4 way) with an amp was all you needed. LOL Kenwood and Jenson had some that were ok, probably others.
    Are the 6 x 9 not ever a "go to" anymore?
  10. May 12, 2018 at 1:23 PM
    Taco-Blender
    Taco-Blender Old Guys Rule
    AZ
    2010 DC 4x4
    Don't forget the Clarion 100-EQB-2 5 Band Graphic Equalizer. In my late 70's HS circles you weren't chit if you weren't running the Clarion.
  11. May 12, 2018 at 4:02 PM
    Trooper2
    JR
    Probably saw a few, had a 4 channel Pioneer EQ that hung at the bottom of dash. was really cool.... lol
    timdske and reelcracker like this.
  12. May 12, 2018 at 4:10 PM
    TXRailRoadBandit73 YOTAS,RAILROADIN',RĂ–KnRĂ–LLN',BEER,MAX/GEMMA
    So what's a good brand of door speakers to run without breaking the bank, currently all stock, truck came with sub box 2 Rockford Fosgate R2 10" sealed box with Massive Audio Nano N2 amp, like to keep HU stock, any recommendations???
  13. Jun 13, 2018 at 5:20 PM
    xj2202009
    xj2202009 New Member
    x
    Lutz, Fl
    2017 tundra sr double cab v8 5.7L black 4x2
    looking to replace factory Radio with a pioneer avix588bhs
    the gooseneck eq were the coolest.
    reelcracker and DalTee like this.
  14. Jun 15, 2018 at 8:31 AM
    yoneytan
    yoneytan New Member
    Asi
    14 CM
    I've done extensive research on 6x9's and ended up going with the AudioFrog GS690's in the front doors. My entire system is being installed and should be done by tomorrow or Monday. From everything i've read they blow the competition out of the water at that price point.
    PNWTundra2021 likes this.
  15. Jun 15, 2018 at 8:45 AM
    trdprobped17
    trdprobped17 New Member
    Geek Squad “F’ed” up my other Tundra. I had to take it to a real professional audio shop to fix the mess of hat they made. It is better to go to a stand alone professional audio shop for all your audio needs. They usually have people there that Install many different audio components on many different vehicles. So, they have much better experience and skill levels than the Best Buy Geek Squad people. Do your homework and find the best Installers in your area to do the job.
    One thing to note! One you go away from factory speakers on your door(s), they will have to modify the doors by cutting away the area that housed the original factory speakers, so it is important to get it done right the first time.
  16. Jun 15, 2018 at 9:36 AM
    Danimal86
    Daniel
    Sacramento, CA
    from what i've heard audiofrog makes some really good stuff.
  17. Jun 15, 2018 at 9:54 AM
    yoneytan
    yoneytan New Member
    Asi
    14 CM
    We should know in the next few days but i'm confident there won't be disappointments.
  18. Jun 15, 2018 at 10:07 AM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    Infinity kappas componet set.
    Baoser likes this.
  19. Jun 15, 2018 at 10:49 AM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    what? all I had to do was add adapters. Adapter utilized the existing holes. I second the post on the Infinity Kappas
    Baoser likes this.
  20. Mar 5, 2019 at 3:20 PM
    Baoser
    Baoser New Member
    Bao
    2016 Lifted Tundra Ltd Crew Max
    XD Wheels, 4" lift, All new speakers except center channel, T1000 and T400 amps, infinity doors and dash. JL subs. NSV knight rider light bar, LED heat lights, fog lights and interior lights.
    I had the cheaper infinity components. I've just blown the passenger door speaker. I'm replacing it with the Infinity Kappa Component. It is a more extensive build when coupled with amps but well worth it for the sound. 6.5" are nice and all but the 6x9" will carry more quality sound. Also consider dyno matting the doors.
  21. Mar 5, 2019 at 4:23 PM
    yoneytan
    yoneytan New Member
    Asi
    14 CM
    I've had my audiofrogs for a while now and can tell you I am VERY happy with them.
  22. Mar 8, 2019 at 11:26 AM
    Baoser
    Baoser New Member
    Bao
    I'll have to check out the Audiofrogs. This is the first I've heard of them.
  23. Mar 8, 2019 at 11:34 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    DocHolliday and dandailey like this.
  24. Mar 8, 2019 at 11:36 AM
    Baoser
    Baoser New Member
    Bao
    I was thinking about going with focal but no one here in arkansas has herd of them. I was worried they wouldn't fit. I hear they're the tits tho. I wish I could hear them in action.
  25. Mar 8, 2019 at 11:38 AM
    SpacecoastHusker
    SpacecoastHusker New Member
    Brevard County, FL
    2014 Toyota Tundra Limited CM
    I went with 6X9 Alpine components in the front and 6.5 components in the rear. Sounds great. Personally, I'd get components.
    TK1979 and Baoser like this.
  26. Mar 8, 2019 at 11:44 AM
    Baoser
    Baoser New Member
    Bao
    I like that build Rex. That tail gate is super sweet. Simple yet modded enough for folks to know that its custom. I really like that sway bar. Did you notice a big difference on rigidity of the truck during turns. You made that high mile truck new new again.
  27. Mar 8, 2019 at 11:55 AM
    DalTee
    DalTee New Member
    Dal
    2011 SuperWhite CrewMax Limited
    Extang Folding Tonneau, 20 percent tint, TRD dual exhaust, BedMat, Stubby antennae, Bully Hitch Step, AVS Window Shades
    the Blaupunkt Gooseneck we called it the ET EQ
    619Tundra and reelcracker like this.
  28. Mar 8, 2019 at 12:11 PM
    Rex Kramer
    Georgia
    I chose them on blind faith, and they did not disappoint me.
    Shop around for the best price.
  29. Mar 8, 2019 at 12:20 PM
    reelcracker
    reelcracker Just a squirrel trying to get a nut
    Farva
    2018 off-road d/c
    Tyger steps, 6 " pro comp lift with fox rears, 20" drop stars -25 offset, toyo m/t's 35x12.50
    6x9's ruled the 80's with that eq!!!:headbang: Hair bands 4-life:headbang:dee Snyder made those 6x9's scream
    Eric32444 and Trooper2 like this.
  30. Mar 8, 2019 at 12:43 PM
    pschiller86
    pschiller86 2017 SR5 CrewMax
    Paul
    Temecula, CA
