Rear Differential Skid for 07+ Tundra - CAD Drawings and Feeler
Discussion in 'Deals & Group Buys' started by boardude, Apr 19, 2018.
Thread Status:
Not open for further replies.
  1. Apr 25, 2018 at 6:28 PM
    #121
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Not trying to be that guy....but I will be that guy.
    What happens after some hard hits and abuse, not asking in terms of the skid, asking in terms of the 2 studs being used as mounting points. How much abuse will those take before bending/shearing or brraking the diff seal and leakikg fluid?
  2. Apr 25, 2018 at 6:31 PM
    #122
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    I have the same concern. Haven’t seen one that uses these bolts to mount. All have been “straps” around the axle.
  3. Apr 25, 2018 at 6:33 PM
    #123
    14burrito
    2014 SR5 CM 4x4 5.7
    From what I recall on the Taco sets, u bolts around the axle.
    Black Wolf and jc153 like this.
  4. Apr 25, 2018 at 6:55 PM
    #124
    jc153
    jc153 Speed-ish Glamper
    San Diego
    2009 Tundra Ltd CM 4x4
    TC Front Long Travel, ADV Glass Fenders & Bedsides, TC Spindle Gussets & King LT Coilovers, RCV Axles, DuroBumps, CB Steering & Carrier Bearing Drop Kit, SDHQ ABS Sensor Shields, Rear 3.0 ADS Triple Bypasses w/MCM Fab Under Bed Shock Mount Relocation, SUA Deaver I96HD Springs & TC Shackles, MCM Fab Rear Hydro Bumpstop Kit, Solid Offroad Engine Mounts, 17" Method Standards, 37/12.5/17 Toyo RT's, Nitro 488 Gears w/Auburn LSD, Evil Off Road Bumpers, RCI Skid Plates, White Knuckle Sliders, Dirty Deeds Ind. BAMuffler 8" Catback, Baja Designs Lighting, SwitchPros Controller, Custom PS Cooler Relocation Kit, Custom Dual Battery Setup
    Thanks for the update.
    I echo 14burrito and csuviper concerns. Seems like the mounting point will be a weak spot. My worry is if you hit the skid hard enough would the bolts snap off leading to a diff issue?
    I like the design in post #56 of this thread. It wraps around the diff and 3rd member spreading the load out.
    osidepunker and Black Wolf like this.
  5. Apr 25, 2018 at 7:11 PM
    #125
    boardude
    boardude [OP] I am Batman
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Yeah that's a valid concern. I can only imagine the hits it would take to shear those bolts off. But yeah that would worry me too after a good hit. Either way, taking those kind of hits with or without the skid is going to F shit up.
    osidepunker likes this.
  6. Apr 25, 2018 at 9:27 PM
    #126
    csuviper
    Broomfield, CO
    Yea thats it, ubolts
  7. Apr 26, 2018 at 9:11 AM
    #127
    GodlessPro
    GodlessPro Bougie BASTRD
    Matthew
    NorCal
    2018 Cement CM Limited
    dcsleeper408 and 14burrito like this.
  8. Apr 26, 2018 at 9:29 AM
    #128
    itsdchz
    itsdchz 50statesoverland
    Clovis, CA
    2018 SR5 CM Cement 4x4
    Icon, UCAs, Method, SSO, KB VOODOO, Skids and Sliders
    Not sold on design and possibility of failure at mounting points rather than UBolts.. I'm out...
  9. Apr 26, 2018 at 11:50 AM
    #129
    csuviper
    Broomfield, CO
    If going with the bolt on route I would suggest 4 bolts instead of two on the diff. Also must bolt up or ubolt to the front side of the diff where driveline attaches.
  10. Apr 30, 2018 at 3:11 PM
    #130
    csuviper
    Broomfield, CO
    Any updates?
    Sunnier likes this.
  11. Apr 30, 2018 at 3:45 PM
    #131
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    The more you wrap the skid around the diff from the bottom the harder it's going to be to get in there and get it on the bolts lol. There is a third TBD attachment point towards the front noted in the design specs.
    Was in Sedona last week so I'm just trying to catch up with everything. I'll connect with him and see what he says
    Sunnier likes this.
  12. Apr 30, 2018 at 4:01 PM
    #132
    froggy78
    froggy78 Loco Moco Bastrd
    JP
    SF Bay Area
    1794 TRD
    I just spoke to RCI. It hasn't been fixed.
  13. Apr 30, 2018 at 4:47 PM
    #133
    GodlessPro
    Matthew
    NorCal
    @matluth Which problem were you referring too?
  14. Apr 30, 2018 at 4:55 PM
    #134
    There was an issue with fasteners sticking out on the gas tank skid. I find it hard to believe they didn't fix that.
  15. Apr 30, 2018 at 5:03 PM
    #135
    Vizsla
    Vizsla 2 = 2.5
    I had mine a year before the rest of these guys. Same.
    dcsleeper408 and GodlessPro like this.
  16. Apr 30, 2018 at 5:04 PM
    #136
    RCI's two locations are only about 45 minutes to an hour away from me. Front skid is next on list after SPC's. I plan on making the short trip for a shop tour soon. I'll see for myself up close!:thumbsup:
  17. Apr 30, 2018 at 5:05 PM
    #137
    GodlessPro
    Matthew
    NorCal
    I had a local fab shop "fix" mine, but let us know if RCI has changed their design.
  18. Apr 30, 2018 at 5:08 PM
    #138
    Yeah...you shouldn't have to fix something to make them work right. I believe T-Rexx has the gas tank skid.
    froggy78 and dcsleeper408 like this.
  19. Apr 30, 2018 at 5:09 PM
    #139
    Yeah..I'm big on the U-bolt mount design too.
    GodlessPro likes this.
  20. Apr 30, 2018 at 5:31 PM
    #140
    Here is the latest gas tank skid pick on RCI's site just now. Front fasteners are recessed. No longer protruding................[​IMG]Looks pretty much fixed to me. Kind of thought so. Too many previous complaints to not do it..
    dcsleeper408 likes this.
  21. Apr 30, 2018 at 5:39 PM
    #141
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    Looks like a baby tank?
  22. Apr 30, 2018 at 5:39 PM
    #142
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    @matluth any update on the bigger tanks?
    Sunnier and Black Wolf like this.
  23. Apr 30, 2018 at 5:41 PM
    #143
    ??????? You lost me on that one.
    Never mind. I know what you are referring to. Not sure about that. RCI only mentions the 26 gal skid plate.
    • " Smooth, flat surface that easily slides over obstacles. No exposed bolt heads on skid plates on 26g fuel skidplate"
    dcsleeper408[QUOTED] likes this.
  24. Apr 30, 2018 at 5:57 PM
    #144
  25. Apr 30, 2018 at 5:58 PM
    #145
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    Yeah the bigger gas tank guys like @Vizsla @GodlessPro @froggy78 are looking for a solution or some type of fix for the exposed bolts showing on there skid.
    With the tank hanging pretty low/long wheel base they are really prone to get dragged/hung up at some times. With the exposed bolts the fear of them shearing off and potentially causing more damage was somewhere along the lines of the big tank skid concern.
    Edit: @GodlessPro fixes his from a local shop. Skid on top of a skid type of thang
  26. Apr 30, 2018 at 6:27 PM
    #146
    I get it now..Wonder why RCI thought that would fly to begin with on the big tank skids??
    froggy78, Sunnier and GodlessPro like this.
  27. Apr 30, 2018 at 6:44 PM
    #147
    Agitated1
    Agitated1 Newish Member
    Los Angeles
    2017 Tundra Crewmax TRD 4x4 Quicksand
    TRD Pro Grill King Coilovers with compression adjuster Tint 5% Rear, 30% front and 70% windshield Husky X-Act Floor liners BA Muffler 8in standard system Truck Covers USA retractable bed cover Yakima bed rails
    This is what my RCI gas skid for the 38 gallon tank looks like.
    RCI has not updated the 38 gallon gas skid. The bolts stick out. I spoke to someone at rci a few months ago and I told them I was disappointed at the design. I also informed them that their site states no protruding bolts. They said that’s the description for the 26 gallon tank.
  28. Apr 30, 2018 at 6:53 PM
    #148
    Yeah...that's unsat. The bolts need to be recessed. Dang I didn't realize the issue was with you guys' large tank skids. You would think maybe "carriage bolts" could work??? Probably too hard to get to in some places.
  29. Apr 30, 2018 at 7:39 PM
    #149
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    Yep. U need a skid for your skid.
  30. Apr 30, 2018 at 8:10 PM
    #150
    Agitated1
    Los Angeles
    Hahahaha. Yes I do!!!
Thread Status:
