2018 LED Fog Light Installation Instructions w/Pics
Discussion in '2.5 Gen Tundras (2014-2021)' started by BayRunner, Nov 11, 2017.
  1. Dec 17, 2017 at 1:37 PM
    sstoddard
    sstoddard New Member
    Shawn
    2019 Crewmax Sport
    Alarm/start (Compustar Ft7000,Rf2wl1b 2-way remotes and Drone Mobile) Tailgate inserts NSV Lightbar Tailgate actuator Blacked out decals
    Yes the fog light part is plug and play. The DRL uses it's own controller and switch. So if you don't want the DRL function you can just add them as fogs.
    Masshole likes this.
  2. Dec 17, 2017 at 4:47 PM
    Masshole
    Masshole Lovin' The Great North Woods
    New England
    2014 DC MGM 4X4 SR5 TRD
    Thanks for the knowledge!
  3. Dec 17, 2017 at 8:20 PM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I took a flathead and gently pried the fog light housing/bezel out to get to the harness. Installed my ballasts and HIDs then popped the housing back in.
  4. Dec 19, 2017 at 4:22 PM
    sstoddard
    Shawn
    2019 Crewmax Sport
    Screw driver equals :(. You can use a plastic panel pry tool in the future. Cheap at harbor freight
    NewImprovedRon likes this.
  5. Dec 19, 2017 at 4:25 PM
    sstoddard
    Shawn
    2019 Crewmax Sport
    Nice thing about Auer, is they pay labor for replacement under warranty.
  6. Dec 19, 2017 at 5:13 PM
    iHacker
    iHacker SW TRD PRO
    TRD PRO Super White CM
    2019 TRD PRO LED Headlights, 2019 TRD PRO Rigid LED Fog lights, All LED Interior, LED Cargo Lights, Bed LED Lights, Undercover Flex, Husky Weather beater floormats, FORTIN EVO ONE remote start, TDR Cold Air Intake, Tundra tail gate inserts, Pop & Lock...
    Auer is what dealerships uses as factory equipment, they manufacture and sell specifically for Toyota applications
  7. Dec 20, 2017 at 2:20 AM
    sstoddard
    Shawn
    2019 Crewmax Sport
    We use them as a reliable alternative to factory equipment. I have there led fog in my truck and have never had an issue
  8. Dec 29, 2017 at 2:37 PM
    netranger6
    netranger6 New Member
    Jeremy
    2021 Crewmax. 4x4, SR5, Blacked Out package
    None. Keeping this one stock.
  9. Dec 29, 2017 at 2:40 PM
    netranger6
    Jeremy
    If you guys go LED on the interior, let me save you a couple minutes of pure frustration. Passenger side, map light. When putting new bulb in, be careful. Disconnect battery and pry open the copper prongs that hold the bulb slightly. Otherwise, you may push the prongs up into the console. What really happens, is the prongs are part of a PC board. However, this side is only tied in by a single plastic nipple. It's easy to push that prong off the nipple. If it happens, don't waste time trying to pry it down into place. Will do more damage. Just remove the overhead console. 2 Screws in sunglass holder, pull back from the front, and down from rear. Disconnect harness, then look at the top. Pop the circuit back onto the nipple, all is good.
  10. Dec 29, 2017 at 2:43 PM
    gregfocker77520
    gregfocker77520 New Member
    luis
    2018 Graphie tundra crewmax sr5
    none yet!!
    I went the long route fearing the blue clips but my truck didn’t have the blue clips. Lol
    NewImprovedRon and netranger6 like this.
  11. Jan 20, 2018 at 4:33 PM
    Kripple
    Kripple New Member
    2017 black tundra trd
  12. Jan 20, 2018 at 5:44 PM
    Kripple
    Kripple New Member
    What the cost on the 18 fog lights
  13. Jan 28, 2018 at 9:39 AM
    ChucklesToy
    ChucklesToy New Member
    Chuck
    Round Rock, TX
    2024 Tundra Limited 4X4 Nightshade Blueprint
    BAK MX4, window tint, TRD skid plate
    @BayRunner , @BlueBottle , thank you very much for these instructions. I installed the '18 LED Fog lights and then the headlights yesterday. Your instructions helped me save time AND I did not break the clips! These types of DIY really help a lot. First, I removed the wheel well panels and replaced the fog lights, and tested operation, leaving the panels off until I could check for proper aim when the headlights were done. Next, I removed the grille and panels underneath the headlights. Removed old headlights; installed new headlights with harness from @eledobleu. Then, checked aim, adjusted driver side (which was a little higher than passenger side). Finally, reinstalled all panels and grille. Took my time (4 hours total from unbox to cleanup) and they work great!
    Thanks again!
    WodenTX, Kyk1e, misfit and 6 others like this.
  14. Feb 13, 2018 at 2:30 PM
    GrayBear
    GrayBear New Member
    Coach Rich
    2016 Magnetic Gray Tundra CrewMax
    Purchased September 4th 2016
    Those look awesome!
    Chris Valenzuela likes this.
  15. Mar 23, 2018 at 6:38 PM
    ldale
    ldale New Member
    Txk Tx
    17' Limited Silver Sky Metalic
    Tonno Pro LowPro , TRD Sway Bar, Helwig Leaf Pack
    Is there any way to tell if my fog lights have the (Blue) clip without removing the wheel well liner?
  16. Mar 23, 2018 at 10:30 PM
    BayRunner
    BayRunner [OP] I’m here, except when I’m not
    2017 Tundra Platinum
    I don't think so. The only way I was able to tell was looking through the wheel well. You have a '17, so you most likely do have one.
    ldale[QUOTED] likes this.
  17. Apr 11, 2018 at 10:18 AM
    B737
    B737 Throbbing Member
    Jersey Shore
    2015 Tundra Double Cab Limited
    I read this thread and it created some trepidation regarding the clips. there is no need for any, this is truly a 20 minute job. Remove the bolts like the OP said. Regarding the wheel well splash guard; gently use a pry tool or flat head to help each tab then simply rotate the panel down for removal. use no fore or aft force. the whole panel simply rotates down or back up into position. with the clips pried slightly up, there is nothing holding it so it just comes right out. when you install it will lock back into place.
    My '15 did not have the blue clip but you need to get back there to aim them anyways. mine lined up out of the box though.
  18. Apr 11, 2018 at 8:19 PM
    ChucklesToy
    Chuck
    Round Rock, TX
    Thanks for this info. I didn't have any issues either, but was glad that the plastic tab concern was pointed out so I could use a trim tool to move it out of the way.
  19. Apr 16, 2018 at 2:56 PM
    seniramsu
    seniramsu Pro Runnin
    Nate
    VA
    2017 TRD Pro Tundra Wht
    Did you have to do anything else besides plug in the new fog's?? I just put some 2018 oem fogs on and now my fogs don't turn on. I checked fuses and they are good. Plugged stock back in and still nada.
  20. Apr 16, 2018 at 3:47 PM
    #50
    B737
    Jersey Shore
    make sure your ignition is on, headlights are on, and fog lights are on. if you've done all that make sure you connected the harness properly to each bulb
  21. Apr 16, 2018 at 4:14 PM
    #51
    seniramsu
    Nate
    VA
    Checked and rechecked all that. Is there another way to connect them? I only see one way they can connect. The fins prevent it from going in the other way. I am stumped with this. Thank you for the info
  22. Apr 16, 2018 at 7:13 PM
    #52
    VAQuicksand
    VAQuicksand New Member
    @BayRunner Thank you so much for your post! I have a 2017 Tundra Limited, and your instructions worked perfectly.
    Couple of notes to share. My Limited did not have the blue tab. However, I still found it easier to take off the back panel before popping out the fog lights. It is very hard to negotiated it out otherwise.
    However, I'm going have to get back there to adjust the Morimoto XB LED fog lights. THey are pointing too high. Does any one know which way to turn to go down? Hopefully I can just reach through there w/o remove it all off again.
  23. Apr 17, 2018 at 6:12 PM
    #53
    BayRunner
    You are welcome @VAQuicksand ! I'm glad you were able to use his as a guide. Post a pic of your new lights. Would love to see them.
  24. Apr 20, 2018 at 5:06 AM
    #54
    VAQuicksand
    @BayRunner Tried to do a night shot but there was too much glare. Day shot here..
    One thing, I did notice with the morimotos. They are point too low, I will need to level it one evening. Unfortunately, that means I will have to take off all the panels again. Hope I can reach back there with the screwdriver to adjust the height.
  25. Apr 20, 2018 at 6:49 AM
    #55
    BayRunner
    Looks good. I like it. I wouldn't worry about having to take the panels off to aim them. Now that you have experience doing it, it will be no big deal. You now know exactly what to expect.
    VAQuicksand likes this.
  26. Apr 23, 2018 at 5:14 PM
    #56
    Chris Valenzuela
    Chris Valenzuela STREET CRAWLER
    San Antonio
    2017 tundra sr5 tss
    6 inch pro comp lift kit. 35x 12.5. 20 inch XD series rims. Flow master outlaw cat back system with dual exit, Black 3.5 inch tips. 2018 trd grill color matched. Yellow fog lights oem style. No name brand hid 10k kit. Spider black housing projectors, blacked out. Amp research electronic running boards with led.
    I wanted to do that to mine as well! Looks good man!!
  27. Jun 23, 2018 at 11:58 PM
    #57
    rds95991
    rds95991 New Member
    2018 Super White Tundra CrewMax SR5 TRD
    I'm impressed.
    LED foglights are part of the TRD Offroad Package OF for 2018 SR5's and standard on Limited and 1794 editions. I wish they had made all the lights LED (I am referring to turn signals and the rear lights. I'm looking for LED replacements for those)
    I've never had much luck working with plastic pieces. I end up breaking plastic tabs and the like as they seem to get brittle. I was afraid changing the burned out headlights in my BMW would destroy the car. But I didn't want to spend $400 per light replacing them. (You have to remove the front tire and fender well to gain access to the headlights and just after I replaced one, the other went out.)
  28. Jul 21, 2018 at 7:30 PM
    #58
    Silv333
    Silv333 Patriot
    NJ-NC-MD-NC
    2018 Cement Crewmax TRD Off Road
    Anyone know if they make yellow bulbs for the 2018 fog lights?
  29. Jul 22, 2018 at 8:27 AM
    #59
    BayRunner
    The '18 LED fogs utalize the whole light assembly and do not use a separated bulb and therefor do not offer yellow.
  30. Jul 22, 2018 at 8:30 AM
    #60
    Silv333
    Silv333 Patriot
    NJ-NC-MD-NC
    :censored: :smash: :( :mad:
