Rextinkleton's 2018 Tundra Build and BS
Discussion in '2.5 Gen Builds (2014-2021)' started by Rextinkleton93, Jan 25, 2018.
  1. Apr 13, 2018 at 1:27 PM
    #121
    Need to know stuff
    Need to know stuff New Member
    2000 black Tundra TRD
    3 front 2 rear leveling
  2. Apr 13, 2018 at 11:52 PM
    #122
    TRON
    TRON Is LIVE on the GRID.
    Stefen
    Gilbert, Arizona
    IG: @ST3F3NS
    DUROBUMPS Use TRON10 for 10% Off & Free Shipping
    Probably 85% reason why I parted with my first rack and got the BAMF one :thumbsup: I love having full use of the rear window
  3. Apr 14, 2018 at 8:28 AM
    #123
    Rextinkleton93
    Rextinkleton93 [OP] New Member
    Kyle
    Chandler, AZ
    2018 Superwhite 4x4
    I think I’m building a new one today lol
    TRON[QUOTED] likes this.
  4. Apr 14, 2018 at 8:29 AM
    #124
    PLC721
    PLC721 New Member
    Patrick
    Chandler, AZ
    2018 Ram 2500 Cummins Laramie
    IG: PLC721
    Do you have to start from scratch?
  5. Apr 14, 2018 at 8:36 AM
    #125
    Rextinkleton93
    Kyle
    Chandler, AZ
    2018 Superwhite 4x4
    Nah. Just gonna cut it from the mounting plates so I’ll be able to reuse those lol. So. Yeah kinda haha. But it should be bad. It was hard to make the hinged rack. This one won’t hinge. Should be easy. Will still be pretty low, but 6 in higher
  6. Apr 14, 2018 at 8:42 AM
    #126
    PLC721
    PLC721 New Member
    Patrick
    Chandler, AZ
    IG: PLC721
    Gotcha, well I look forward to seeing it!
  7. Apr 14, 2018 at 9:58 AM
    #127
    Need to know stuff
    I painted my fender flares cause they were Grey on a black Truck
  8. Apr 15, 2018 at 4:43 PM
    #128
    Rextinkleton93
    Kyle
    Chandler, AZ
    2018 Superwhite 4x4
    April 15, 2018
    Alright, so ended up changing up my bed rack. Originally, the thought was to keep it as low as possible and have it hinge for bed access. In practice, it really wasn’t going to make getting things out that much easier and I had a lot of details to finish up. Ended up scratching that and just went ahead and whipped up a simple rack today. Not much taller, but makes it easier to access the bed, while still keeping the tent low.
    874B8EF6-7B2F-48B2-9688-90BC0BB68472.jpg 5AB0A41F-74DA-4A68-8588-451E8E094833.jpg C573EA5B-A3C6-45D5-98CC-1DEE3D31BD6C.jpg
    Ps. How do you load your tent :p
  9. Apr 16, 2018 at 10:09 AM
    #129
    PLC721
    PLC721 New Member
    Patrick
    Chandler, AZ
    IG: PLC721
    Turned out good :thumbsup:
    Rextinkleton93[OP] likes this.
  10. Apr 16, 2018 at 10:24 AM
    #130
    Rextinkleton93
    Kyle
    Chandler, AZ
    2018 Superwhite 4x4
    Thanks pat!
    Yeah I just wanted to keep it simple, but had to make it somehwhat hard. Matched the angle of the cab with the kickers off the bed sides. Makes it look bett imo then just tunes sitting at 90 degrees off the bed side. Can’t really tell in the pictures I suppose though.
  11. Apr 16, 2018 at 10:26 AM
    #131
    PLC721
    PLC721 New Member
    Patrick
    Chandler, AZ
    IG: PLC721
    No i can see the bends!
    Simple clean and effective!
  12. Apr 16, 2018 at 10:26 AM
    #132
    pschiller86
    pschiller86 2017 SR5 CrewMax
    Paul
    Temecula, CA
    Did you design that rack on your own? (I don't think I've seen it before)
  13. Apr 16, 2018 at 10:28 AM
    #133
    Rextinkleton93
    Kyle
    Chandler, AZ
    2018 Superwhite 4x4
    Yeah I came up with the idea and built it yesterday.
  14. Apr 16, 2018 at 10:29 AM
    #134
    pschiller86
    Paul
    Temecula, CA
    Great job! Does it only attach to the bed rails or also the pocket holes?
  15. Apr 16, 2018 at 10:34 AM
    #135
    Rextinkleton93
    Kyle
    Chandler, AZ
    2018 Superwhite 4x4
    Just the bed rails. I used angle at all 4 corners. Each of those angles has 2 bolts that go into the bed rails. So a total of 8 bolts.
    No need to attach it to the pocket holes IMO
    pschiller86[QUOTED] likes this.
  16. Apr 16, 2018 at 10:37 AM
    #136
    pschiller86
    Paul
    Temecula, CA
    No we just need pics of the tent open!
  17. Apr 19, 2018 at 8:04 AM
    #137
    Rextinkleton93
    Kyle
    Chandler, AZ
    2018 Superwhite 4x4
    OP slightly updated. Just finishing up some details with the RTT setup this weekend and that portion will be done.
    Probably going to go ahead and pick up new rear shocks this weekend as well. New leafs will come after that most likely.
  18. Apr 20, 2018 at 7:37 PM
    #138
    Rextinkleton93
    Kyle
    Chandler, AZ
    2018 Superwhite 4x4
    April 20th, 2018
    Went ahead and bought and installed some rear fox 2.5” with resi’s and DSC to match the front. Install was super easy (legitimately took me 40 mins from start to torquing the lugs back on).
    Not too much to say about this. 4 Bolts, rear shocks, blah blah blah. Guess we will just have to see how they preform!
  19. Apr 25, 2018 at 9:49 AM
    #139
    Rextinkleton93
    Kyle
    Chandler, AZ
    2018 Superwhite 4x4
    Going to be getting ready for Sedona tonight, and hopefully leaving tomorrow around 4 or so.
    Hopefully we will see some of you guys up there!
    PLC721 and JDL17CM4x4 like this.
  20. Apr 25, 2018 at 3:54 PM
    #140
    PLC721
    PLC721 New Member
    Patrick
    Chandler, AZ
    IG: PLC721
    Can’t wait!
  21. Apr 26, 2018 at 7:48 AM
    #141
    Rextinkleton93
    Kyle
    Chandler, AZ
    2018 Superwhite 4x4
    Really second giessing just running s bolt in rear shock at the moment. I’ve seen this from camburg before, but damn that is clean.
  22. Apr 29, 2018 at 5:37 PM
    #142
    Rextinkleton93
    Kyle
    Chandler, AZ
    2018 Superwhite 4x4
    Couple of pictures from Sedona this weekend. Truck did great, but sliders are definitely on the list.
    3B7D39F3-3BAA-472B-84DA-F61DD54346EF.jpg 15F0235D-6487-4467-A2E7-85887B5696B9.jpg DB8C2194-406A-4399-9CD4-64E9A0080442.jpg 370FD268-7742-404A-BFC0-0FFF1C4FA890.jpg
    geno0506, crochetjohn, Vizsla and 6 others like this.
  23. May 14, 2018 at 9:00 PM
    #143
    Rextinkleton93
    Kyle
    Chandler, AZ
    2018 Superwhite 4x4
    Been an uneventful past couple weeks as far as the truck goes. Hopefully get some goodies going soon though.
    Currently battling back problems (I’m 24 this fu*king sucks) and have barely been able to move.
    Would like to get the sway bar off and start looking at some leaf springs here shortly.
    TRON and Brian0414 like this.
  24. May 15, 2018 at 9:03 PM
    #144
    KevinK
    Back in Arizona. Again.
    Tundras to Sedona
    I’m barely catching up on stuff after Sedona. It was awesome seeing you out there! Wish I hadn’t broken the truck so early in the week, I wanted to get on some trails with you guys. Next time fo sho!
  25. Jul 23, 2018 at 10:28 PM
    #145
    Rextinkleton93
    Kyle
    Chandler, AZ
    2018 Superwhite 4x4
    Not much to update on the truck. Picked up a powertank off Craigslist today for a STEAL. Color is not ideal, but talking to powertank I am good to paint it, and they will send me all new stickers for the tank.
    Also picked up some vinyl to wrap some of the interior chrome (ac vents, cup holder surround and maybe some other things). It will be my first time wrapping so we will see how it goes.
    Hoping to get some lights on the truck soon, but have a bunch of vacations to pay for which is an okay trade off :D
    Vizsla and Brian0414 like this.
  26. Aug 12, 2018 at 2:33 PM
    #146
    Rextinkleton93
    Kyle
    Chandler, AZ
    2018 Superwhite 4x4
    Got the powertank all taken care of, no more purple. Couple coats of Steel-it and some new stickers from powertank and she’s ready to go!
    pdiddy, Vizsla and Black Wolf like this.
  27. Aug 12, 2018 at 3:41 PM
    #147
    Came out great! I've been looking on Craigs List for a while now.
  28. Aug 12, 2018 at 4:27 PM
    #148
    HighDesertSurfer
    HighDesertSurfer Surf The Dirt
    New Mexico
    2018 SuperWhite DC TRD OR
    Leer shell
    Just read this whole thread...so nice...great overlander build, Kyle!
  29. Aug 12, 2018 at 4:43 PM
    #149
    Kind of weird, just found a complete 15lb kit for $450 on CList. Hmmm.....
  30. Aug 12, 2018 at 4:57 PM
    #150
    Rextinkleton93
    Kyle
    Chandler, AZ
    2018 Superwhite 4x4
    Sounds like it’s meant to be :D
