Has anyone had the shifter back light burn out?
Discussion in '2nd Gen Tundras (2007-2013)' started by BigT, Jan 19, 2016.
  1. Jan 19, 2016 at 9:33 AM
    BigT
    BigT [OP] New Member
    2008 Toyota Tundra S
    Nitto Trail Grapplers,Gear rims,Westin bumper,leveling kit, Flow Master Exhaust,
    I just noticed on my T that the back light on my shifter has burned out, anyone else come across this and is it possible to replace it? I know you can still see it on the dash but is still nice to have it on.
  2. Feb 12, 2016 at 1:21 PM
    Nor7
    Nor7 Chilton Manual Guy
    2007 Tundra Limited CM, 5.7L
    Are you talking about the light behind the dash or the light on your center console?
  3. Feb 12, 2016 at 1:32 PM
    Nor7
    If you have the center console it's pretty easy, the covers just pop off and you should be able to get to it then.
    Detach the 12 clips and remove the console panel.
    Remove the clip.
    • Detach the 6 clips and remove the console panel.
    • w/Trailer Towing System:
      Disconnect the connector
  4. Feb 12, 2016 at 1:36 PM
    Nor7
    Oh, and you may have to take this part out too.
  5. Feb 12, 2016 at 3:08 PM
    BigT
    That is awesome. Thanks a lot!
  6. Jul 8, 2022 at 10:48 PM
    Jabba the Slut
    Jabba the Slut New Member
    Black 2010 Tundra Platinum
    I had this bulb burn out on my 2010. I believe it is the same bulb as the one in the driver's foot well. For some reason, I swapped out the bulb, verified the new one worked, but when I buttoned everything back up, it was again not illuminating the gear markers. Swapped the bulb back to the original and found that the original works too, but apparently only when the panels are removed.
  7. Sep 15, 2024 at 2:59 AM
    cmb46
    cmb46 New Member
    2008 Tundra
    So is the light under this?
