Replacement leaf springs 2002 Tundra
Discussion in 'Suspension' started by Cbb129, Mar 17, 2018.
  1. Mar 17, 2018 at 8:00 AM
    Cbb129
    Cbb129 [OP] New Member
    2002 Blue Tundra SR5
    Hi all !! I just bought a 2002 Tundra SR5 Access Cab. Mechanic says right rear leaf spring clamp is broken, so looking to replace both sides with new leaf springs. Truck used pretty much as a passenger vehicle to tote dirt bike around, no heavy duty off roading or towing. Looking for suggestions to replace springs, but also keep the cost down. Also what hardware and sizes to order, i.e. ubolts, shackles, etc. Thanks.
    831Tun likes this.
  2. Mar 17, 2018 at 9:15 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Wrecking yard. But, if just a clamp is broken can you replace that instead of new leafs?
    Sunnier and Bbombs like this.
  3. Mar 17, 2018 at 11:17 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    The Icon add a leafs ride pretty nice and come with new clamps.
  4. Mar 17, 2018 at 1:19 PM
    Cbb129
    Do they raise the rear end ? Want to retain stock height.
  5. Mar 20, 2018 at 6:57 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    Alcan will make an excellent replacement set that is 1/2 the price of OEM, stock height & payload.
    mtntop likes this.
  6. Mar 20, 2018 at 7:43 AM
    mtntop
    mtntop New Member
    2004 4x4 Access Cab SR5
    This^^^^^
    I put em on my 2004 and they are worlds better than the OEMs
    Sunnier and Rex Kramer like this.
  7. Mar 20, 2018 at 9:11 AM
    Festerw
    Festerw New Member
    04 Tundra DC
    On my 04 they brought it to maybe 3/4" over stock.
  8. Mar 20, 2018 at 11:45 AM
    Rex Kramer
    Georgia
    I have used Alcan replacement leaf packs twice for Toyota trucks, they are
    so much better than OEM and you can specify added lift & capacity if you want.
    Sunnier likes this.
  9. Mar 20, 2018 at 5:45 PM
    Brown Bear
    Brown Bear New Member
    Nor cal
    03 TRD offroad
    -6" RCD lift in front. -Custom leaf springs in rear 4" lift. -17" race line, raptor wheels. -35" Goodyear Duratrac. -4.88 gears. -ARB rear air locker. -ARB air compressor and tank. -Custom front sway bar quick disconnect -Custom one piece driveshaft -Black Oak Led 40 watt ditch lights.
    You could have you leafs rebuilt if you have spring shop near you. You might even be able to find a machine shops that can rebuild them.
  10. Mar 21, 2018 at 1:48 PM
    mtntop
    mtntop New Member
    Alcan can build em to increase lift, or in my case stock height. They ride smooth but can carry much heavier loads than OEM without the sag. I think they are called progressive??
    Rex Kramer likes this.
