Don't buy shit. D RING Shackle
Discussion in 'General Tundra Discussion' started by SnowroxKT, Mar 12, 2018.
  1. Mar 12, 2018 at 12:08 PM
    SnowroxKT
    SnowroxKT [OP] New Member
    Kyle
    Alaska
    Not to bash on Trail Gear, but holy shit check out the differences in these shackles.
    Trail Gear 3/4" Shackle WLL = 4.75T____5:1 Design Factor
    CM 3/4" Super Carbon Shackle WLL = 6.5T_____6:1 Design Factor
    That is over a 15 Ton difference in breaking strength.
    https://youtu.be/qiZmsRuSEjA
    Sas, nowayout, itsdchz and 2 others like this.
  2. Mar 12, 2018 at 12:12 PM
    Thanks for input!
    SnowroxKT[OP] likes this.
  3. Mar 12, 2018 at 12:17 PM
    SnowroxKT
    Kyle
    Alaska
    I was amazed at the difference. If it can stop one person from getting killed (or hurt) from a broken shackle that would be awesome.
    Kerch71, Krezz, 831Tun and 1 other person like this.
  4. Mar 12, 2018 at 12:22 PM
    Yeah I saw a YouTube post somewhere diff country guy got killed by one, brutal! Hole in face
  5. Mar 12, 2018 at 12:31 PM
    Upgrayedd
    Upgrayedd Toyotaholic
    Josh
    Northern Virginia
    2015 DC MGM SR5 4x4
    Just checked the one I have in my truck. It’s a Crosby USA made. Looks like I should maybe get one with a higher working load limit.
    TXRailRoadBandit73 likes this.
  6. Mar 12, 2018 at 4:25 PM
    SnowroxKT
    Kyle
    Alaska
    Crosby is a good brand, the CM shackle that I show in the video is a Super Carbon Alloy, compared to the standard Carbon Alloy like the one you showed a picture of.
  7. Mar 12, 2018 at 4:28 PM
    So where do we get these? Any links?
  8. Mar 12, 2018 at 4:31 PM
    SnowroxKT
    Kyle
    Alaska
    https://www.cmworks.com/Rigging/Shackles
    Anywhere that carries Columbus McKinnon shackles should have them. I got mine from Fasteners but Fastenal would probably have some too.
  9. Mar 12, 2018 at 4:45 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    This ones worse. It says unbreakable 41,850lbs. But it’s stamped 4.75 tons on the shackle, just like all the other cheap ones they sell for $13. This is going to get someone killed one day.
  10. Mar 12, 2018 at 4:50 PM
    Thanks
  11. Mar 12, 2018 at 5:05 PM
    GodlessPro
    GodlessPro Bougie BASTRD
    Matthew
    NorCal
    2018 Cement CM Limited
    Now I'm concerned about what I have in my recovery bag. I guess I better go check eventually.
    SnowroxKT[OP], Njmike13 and joonbug like this.
  12. Mar 13, 2018 at 6:41 AM
    JH5370
    JH5370 Member
    Josh
    Eastern WA
    2017 White DC TRD PRO
    Thanks for posting. I was just reading an article on this. Just goes to prove you get what you pay for and don't cheap out on stuff that can kill you.
  13. Mar 13, 2018 at 7:27 AM
    Smiley
    Smiley New Member
    08 Tundra TRD
    Buy soft shackles, save lives.
  14. Mar 13, 2018 at 8:40 AM
    GodlessPro
    Matthew
    NorCal
    What's the deal with soft shackles? :notsure:
    I'm sure like everything else there are good ones and bad ones. What should we be looking for? Are there go to brands/models?
    dcsleeper408 likes this.
  15. Mar 13, 2018 at 10:53 AM
    Redbeard321
    Redbeard321 ballin' on a budget
    2016 Tundra SR5 Double Cab
    I am assuming "soft" means an alloy of steel that has a ductile failure mode. Basically in non-engineering terms, the steel will bend before it breaks. This is always preferred over a brittle failure, which basically means it will just snap and release all the load all at once.
    Always check the stamped rating on your shackles, if they aren't stamped throw them in the trash. The American Society of Mechanical Engineers has requirements for rigging hardware and marking and labeling is one of the requirements. They should have the rated load, manufacturer, and size at a minimum. If you want some light reading on rigging hardware pick up a copy of ASME B30.26. Depending on wether or not your shackles were designed following ASME they should be designed with a factor of 5 and tested to a factor of 2 but for your own good use one with a rating 2-3 times the load you plan to put on it.
    I didn't stay at a holiday inn express last night but I do have a mechanical engineering degree.
  16. Mar 13, 2018 at 10:57 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    No, these soft shackles.
  17. Mar 13, 2018 at 11:00 AM
    Redbeard321
    oooooo DUH. Sorry, the engineer in me thinks differently. Shackles and rigging hardware are something I deal with frequently at work lifting very expensive one of a kind things.
  18. Mar 13, 2018 at 11:02 AM
    GodlessPro
    Matthew
    NorCal
    I pretend to be a mechanical engineer at work sometimes when one of the real ones isn't around, but I was asking about what Joon posted.
    Black Wolf, dcsleeper408 and joonbug like this.
  19. Mar 13, 2018 at 11:15 AM
    01erionracing
    01erionracing KJ6RKU
    Jimmy
    2000 SR5 4WD 2002 SR5 4wd 2008 CM Limited 4wd
    Got two 6.5 ton WLL today after seen this thread.
    BestGen and SnowroxKT[OP] like this.
  20. Mar 13, 2018 at 11:21 AM
    01erionracing
    Jimmy
    ebay item 182115605875. I wanted to buy 4 but they only have 3 so only 1 left now.
    NewImprovedRon likes this.
  21. Feb 12, 2019 at 1:38 PM
    TRD-tv
    TRD-tv New Member
    OHIO
    2012 MGM Tundra TRD
    My harbor freight shackle is rated for a solid 7500 lbs
    Berdine likes this.
  22. Feb 12, 2019 at 3:20 PM
    I bought this kit. I thought it looked good.
    Is it garbage? They have WLL 43/4T stamped on them.
    ALL-TOP 4x4 Recovery Gear Kit with Hitch Receiver: 3 inch x 30 ft (32,000 lbs) 100% Nylon Snatch Strap + 2" Aluminium Shackle Hitch Receiver + 3/4 Heavy Duty D Ring Shackles (2pcs) +Storage Bag https://www.amazon.com/dp/B07FL59Y51/ref=cm_sw_r_cp_apa_i_8q1yCbEFSP9JQ
    Berdine likes this.
  23. Feb 12, 2019 at 4:10 PM
    pbcolt
    pbcolt New Member
    San Diego
    2022 SR5 TRD-OR CMSB Lunar Rock
    I'm all for safety, which is why I'm trying to figure out exactly what the issue is here.
    4.75 tons is 9,500lbs - 2000lb more than gwvr for a Tundra. And that's the working load limit. The breaking strength at a factor of 5 is 47,500lbs. That's more than the "capacity" or "breaking strength" of most recovery straps and soft shackles. If the shackle is attached to a receiver, the hitch pin for that receiver is only good to 22-31,000 lbs based on what I've read. It seems like the shackle would be the last thing to fail.
    What am I missing? Trying to understand before I go shell out for a really expensive shackle.
    edit: Realized there might be a difference between using this as a rear recovery point and attaching a winch hook to it?
  24. Feb 12, 2019 at 5:03 PM
    SYRTundra315
    SYRTundra315 New Member
    Andrew
    2019 Super White Tundra CrewMax Platinum
    OEM nerf bars, BakFlip MX4, BedRug, VLED interior lights and license plate bulbs, JDM Astar turn signal and reverse bulbs.
    Shackle ratings is a genuine issue. There was a recent OSHA investigation that found many are not actually capable of the rating they claim and someone got hurt. At my work we were required to dispose of all non USA made shackles and only use US made with ratings cast/stamped into the loop. Forces can multiply rapidly depending on shock loads and if pulleys are involved so be safe and use good quality parts.
    Stormtrooper81 and TRD-tv like this.
  25. Feb 17, 2019 at 11:07 PM
    salmonator
    salmonator New Member
    Tigard, OR
    2019 Tundra SR5 4x4 DC
    Also real world shackle strength is dependent on the gap between the lug plate and the shackle- grip minus plate thickness. So depending on geometry how they are loaded.....
    I’d be more comfortable with Crosby than eBay....
  26. Feb 18, 2019 at 2:18 PM
    Cement Truck
    Cement Truck New Member
    2018 TRD Off-road CM Tundra
    In the work I do we rig and lift a lot. We only use Crosby shackles. They use good steel and manufacturing process and they test what they make. I also have only Crosby equipment in my recovery bag.
    That said, a 3/4 in shackle is rated to 4-3/4 tons as the WLL for over head lifting. Your recovery hardware WLL should exceed your winch’s rating. A 3/4in shackle is correct for up to a 9000lb winch in a single line pull. Go bigger if you think you may be using a double line pull.
    The shock loading that occurs when trying to ‘tug’ someone out of the mud is a very different thing. People do it all the time but I never will. And when I do help recover someone I only use my equipment. There are way too many crap shackles sold on the off-road websites and catalogs and Amazon. You get what you pay for.
    theraven likes this.
  27. Feb 18, 2019 at 3:13 PM
    Stormtrooper81
    Stormtrooper81 Slow and steady
    Lost coast
    2011 DC
    X2:oldglory:
  28. Feb 18, 2019 at 4:22 PM
    BestGen
    BestGen New Member
    Paul
    Haunted Turnbull Canyon CA
    '05 RCLB, 2UZ-FE, 4wd / '88 4RNR XTE 22RE/W56/RF1A
    Fabtech 2.5" coilovers, BFG KO2 34/10.5/17, 17x7.5 TE wheels, add-a-leaves, 4.56 gears, Rhino-lined
    Here's a few of mine. Bought a couple of the TJMs. I've used them a few times without issue. 4.75T WLLIMG_2723.jpg Here're a couple of others I 'borrowed' from work... IMG_2724.jpgOn the left is a cheap Chinese 2T and on the right is Japanese 8.5T WLL
  29. Feb 18, 2019 at 4:24 PM
    tbrown
    tbrown 2017 CM FFV
    Nashville, TN
    2017 TRD Blazing Blue
    Magnuson Supercharger Kooks long tube headers King 3.0 remote reservoir w/ clockers front King 3.0 triple bypass remote reservoir rear Deaver Custom leaf Method 312 Corsa Exhaust w/ custom stainless bro’s resonator tip Custom HP tune Viair 400c Dual Onboard Headlight Revolution Stealth Bar Baja design XL 80 ditch lights on SDHQ Ditch brackets Victory 4x4 sliders and bed Molle RCI Skids C4 fabrication overland front bumper Smittybilt x2o 12k winch Toyo Open Country RT 37’s Icon Billet Delta UCA’s Nitro 5.29’s ARB Air locker front and rear Switch Pros Leitner Designs Bed Rack ICS Fab Dash Mount Expedition One Dual Swing Rear Bumper Viper remote start Rosen in headrest DVD players
    Ah yes, the ones I own...looks like I’m ordering more stuff tonight
    joonbug[QUOTED] likes this.
  30. Feb 18, 2019 at 4:26 PM
    In a perfect world, winch recovery would be straight forward and easy(ish).
    Buy good equipment, inspect before each use, and discard when damaged.
    Three weeks ago I bent a shackle.
    joonbug and NewImprovedRon like this.
