First oil DIY oil change. Here’s what I learned.
Discussion in 'General Tundra Discussion' started by BTBAKER, Mar 10, 2018.
  1. Mar 10, 2018 at 10:13 AM
    BTBAKER
    BTBAKER [OP] .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    My Tundra is a 2017 Limited. At 5000 I brought my Tundra to the dealer for its first oil change. This goes against my better judgement but the allure of FREE brought me in.
    This time at 10,000 I was stocked and fully prepared to do it myself.
    The MOTIVX filter tool and drain tool made this an absolute breeze! I literally did not spill any oil. You can do a search to find these tools.
    But, here is what I learned.
    The skid plate is not a big deal at all. It’s literally 5 minutes off and 5 minutes on. Although I think I will be purchasing the RCI skid because of the access port to the filter housing. Not having to drop the skid would make this job so damn easy.
    The dealership put about 8.5 quarts of oil in my truck. I will post a picture of the oil that came out. The full container is higher than what Mobil fills them so you can see it was to much. It calls for 7.9 with filter but 7.5 was perfect and right about half way between marks. I check my oil regularly and after leaving the dealer it was above the top dot but I let it ride since it wasn’t terrible.
    They also tightened EVERYTHING from skid bolts to filter housing WAY to tight. I torqued everything to spec.
    Specs I found were
    22 ft lbs on drain bolt
    18 ft lbs on filter housing
    9 ft lbs on filter cap.
    Anyone on the fence I will confirm this was an easy job that took 1.5 hours beginning to end and that is with my anal ass cleaning everything and double checking everything. It’s also confirmed to me that the quick lube bone heads could care less about how an oil change is done in my truck.
    Good luck!
    USCG2005, WFD473, Ely010606 and 12 others like this.
  2. Mar 10, 2018 at 10:23 AM
    15whtrd
    15whtrd Mr. Blonde
    Good job. Is your truck a ffv?
    I’m surprised they changed the oil at 5000 miles. I took mine in for its first oil change at 5000. They gave me the impression that they were going to change it, as well as grease my driveshaft and rotate my tires. When I got it back and looked at the dipstick it was still old oil. I checked the zurk fittings, the paint wasn’t even scraped off. You can’t grease them without doing so first. Although in the paperwork said they greased it.
    I questioned them and they told me 10k was the interval. I knew that but I still wanted it at 5K. I have not been back for service since. I went home and did it myself. You can also tell they are not careful when rotating the tires. Everything was over torqued as well as scratches inside the Lugnut holes.
    I’ll stick to major repairs for warranty work and that’s it. As for oil quantity I just put in 8 quarts. Close enough. It’s always right at the top dod. That’s where I like it.
  3. Mar 10, 2018 at 10:26 AM
    ninjajay
    ninjajay Posting from the toilet
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    Toytec/Radflo Lift, Ambit RS02 18x9+0, Bridgestone Revo 3 295/70/18
    Toyotacare specifies every 5k for FFV, 10k for non-FFV oil changes
  4. Mar 10, 2018 at 10:26 AM
    seniramsu
    seniramsu Pro Runnin
    Nate
    VA
    2017 TRD Pro Tundra Wht
    Man thank you very much. I am about to roll up the sleeves for my first oil change on my baby and you have def put my mind at ease. Thank you kind sir!!!
    BTBAKER[OP] likes this.
  5. Mar 10, 2018 at 10:28 AM
    BTBAKER
    BTBAKER [OP] .
    Brad
    Castle Rock
    Good point. I greased my prop shaft and the paint was still on mine as well. They claimed they did it but they DID NOT!
    15whtrd[QUOTED] and Black Wolf like this.
  6. Mar 10, 2018 at 10:29 AM
    BTBAKER
    BTBAKER [OP] .
    Brad
    Castle Rock
    It’s cake! On the skid take the front 3 screws off, the. The two front bolts and then the back two outsides and finally the middle. Shift the skid towards the drive side and it come right off. Reverse when going on.
    TTund16 likes this.
  7. Mar 10, 2018 at 10:31 AM
    BTBAKER
    BTBAKER [OP] .
    Brad
    Castle Rock
  8. Mar 10, 2018 at 10:31 AM
    I do my own lube job. Somewhat of a pain but I know it's getting done.
  9. Mar 10, 2018 at 10:32 AM
    BTBAKER
    BTBAKER [OP] .
    Brad
    Castle Rock
  10. Mar 10, 2018 at 10:33 AM
    seniramsu
    Nate
    VA
    Will do. Thank you again. Time to get er done as they say!!!
  11. Mar 10, 2018 at 10:40 AM
    BTBAKER
    BTBAKER [OP] .
    Brad
    Castle Rock
    Yep, FFV engine.
    15whtrd[QUOTED] likes this.
  12. Mar 10, 2018 at 1:56 PM
    seniramsu
    Nate
    VA
    So I think this is a win for Toyota because I did not have to remove the skid...
  13. Mar 10, 2018 at 1:57 PM
    seniramsu
    Nate
    VA
    I must say it got a little messy but I learned from my mistakes. Thanks again for the help Mr Baker!!!
  14. Mar 10, 2018 at 2:08 PM
    What are the zip ties for?
  15. Mar 10, 2018 at 2:08 PM
    seniramsu
    Nate
    VA
    A connection for a light bar that I removed
  16. Mar 10, 2018 at 2:09 PM
  17. Mar 10, 2018 at 2:21 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    I'm due for an oil change, tire rotation soon. I plan to do it myself even though I said I wouldn't do it myself again cuz it's kind of a pain in the ass. I also am nearing 30k so I need to change my diff oils soon too. I'll do that myself too.
    Oh and I need to change my brake fluid. Never needed to do this before. I may pay for that or buy some kind of tool to make it a one man job
  18. Mar 10, 2018 at 2:26 PM
    Pudge
    CT
    Anyone know what futomo valve we need for these tundra. Guess I'll order one of those for the upcoming change. Will make future changed easier. Thanks
  19. Mar 10, 2018 at 2:28 PM
    Believe FN103
    15whtrd and Pudge[QUOTED] like this.
  20. Mar 10, 2018 at 2:28 PM
    Pudge
    CT
    Thank you sir!
  21. Mar 10, 2018 at 2:29 PM
    I also order the little tab lock the clear tube and nipple cover
  22. Mar 10, 2018 at 2:30 PM
    There are diff ones mind u
    Pudge likes this.
  23. Mar 10, 2018 at 2:30 PM
    Go to actual site to see
  24. Mar 10, 2018 at 2:31 PM
    Pudge
    CT
    I'm there now buddy. Thank you
  25. Mar 10, 2018 at 2:33 PM
    Yes Sir!
    Pudge[QUOTED] likes this.
  26. Mar 10, 2018 at 2:41 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Great job!
    I prefer to do my own Oil Changes; Usually too busy to go wait somewhere. It also makes me look under the hood and inspect things. You will get it done in less than an hour next time.
    https://www.youtube.com/watch?v=qztuEucrNBc
  27. Mar 10, 2018 at 2:43 PM
    seniramsu
    Nate
    VA
    :rofl::rofl::rofl: Exactly how it feels!!!
    Trooper2, shtinthenads and 15whtrd like this.
  28. Mar 10, 2018 at 2:51 PM
    Trooper2
    JR
    Not sure what Toyota recommends but I have never changed the Brake fluid in any vehicle that I have owned, nor do I know anyone that has.
  29. Mar 10, 2018 at 3:14 PM
    Pudge
    CT
    Toyota says 24-36k miles a full brake fluid change in 3rd gen tundra. Maybe I can wait longer since I don't tow but figured I'd start looking into it
  30. Mar 10, 2018 at 4:27 PM
    ninjajay
    Spoolston, TX
    On my last truck I did every 3 years, which seemed fine
    Pudge likes this.
