Bilstein 5100's in front with stock springs enough to level?
Discussion in 'Suspension' started by rustynail11, Mar 7, 2018.
  1. Mar 7, 2018 at 7:25 AM
    rustynail11
    rustynail11 [OP] New Member
    Scott
    Mansfield,TX (DFW Area)
    2017 Grey Tundra TRD
    So after a few Jeeps and now in to a 17 Tundra CM TRD I have finally determined what my real needs are when it comes to off-roading and mods. In my head I am always going to a bunch a really cool offroad stuff but in reality I never get around to it. I am planning a Moab trip but nothing really technical, going to get in to some backcountry and for the scenery. So while I would love to spend the money to get all the expensive cool stuff I just don't do enough off-roading to justify the costs. The time I spend off road is mostly on the beach, dirt roads, and a little bit of light to moderate stuff and 90% of my driving is on the pavement with a crappy ass commute.
    With that said I don't want a lift because of cost and concerned about losing MPG but I would like to level and have been looking at the Bilstein 5100's. Would the 5100's in front with stock springs be enough to level or is there anything else I would need to add? Can I do front only or do I need to rear as well? I would like the 6112's but they are way over current budget.
    I am currently running the stock TRD wheels and tires. Will keep the wheels but when tires wear out will go larger but only big enough that I don't need to lift or do any other modding.
    Thought and opinions are appreciated as always.
    Taterhawk, MDHinSD and 831Tun like this.
  2. Mar 7, 2018 at 7:27 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    5100 at top setting gets your truck level and measures the same as a PRO. Nothing else is required.
  3. Mar 7, 2018 at 8:19 AM
    71_340
    71_340 The German
    Hans
    FLW, MO
    I am also somewhat interested in leveling my truck because I eventually want to put 275/60-20 tires on mine. Excuse my ignorance but how does a mere shock absorber upgrade raise the front of the truck? Could you post a link to the Bilstein 5100 shocks needed to do that?
    Thanks,
    Hans
  4. Mar 7, 2018 at 8:26 AM
    RickC
    RickC NOT a new member
    Rick
    Knoxville TN
    2017 CrewMax Platinum 4x4 5.7
    SCS Wheels, Line-X, WeatherTech, UnderCover Flex bed cover
  5. Mar 7, 2018 at 9:09 AM
    Trikerider
    Trikerider New Member
    2015 Limited CM
    I am in the same boat, when tires wear out I plan to be going with the Billy 5100s and hoping to fit 275/65r20s on stock limited rims. Did some research but wasn't able to find a definitive answer if they will fit or not but will find out. Plan to set the front shocks at the 1.3" lift, not max height, so when I haul firewood in the back I'm not excessively nose high and front end geometry isn't too far out of whack. The stock black shocks suck and am very much looking forward to replacing them.
    mattyd170 and MDHinSD like this.
  6. Mar 7, 2018 at 9:50 AM
    NickyF25
    NickyF25 New Member
    SE Pa
    2017 Platinum 4x4 Silver Sky-Sold
    I replaced my stock Platinum shocks with 5100s all around at about 5k miles and have been very happy with them. The fronts are at the middle setting which leaves a little rake which is what I wanted. I have 285/65/18 KO2s on SCS SR8's (+25 offset) which fit with no trimming or modification needed, and find the ride with my setup to be better than what I had stock. I did lose a little MPG with the tires but not enough to care.
  7. Mar 7, 2018 at 10:09 AM
    RickC
    Rick
    Knoxville TN
    Nicky, you have any pics of that setup? I recently went with SR8s with that same tire size and my plan is to level out using 5100s too. Would love to see the stance you came out with using that setup.
  8. Mar 7, 2018 at 10:35 AM
    NickyF25
    NickyF25 New Member
    SE Pa
    Unfortunately I don't. My truck is currently covered in snow as we are in the middle of the noreaster in SE PA. I will try to take some in the next few days once things get cleared up and post them.
    RickC[QUOTED] and Taco-Blender like this.
  9. Mar 7, 2018 at 2:13 PM
    Rica25
    Ricardo
    Tulare
    This is at highest setting in front with 5100s tires are 275/65/18
    ekertz, rv740, 9am53 and 3 others like this.
  10. Mar 8, 2018 at 4:22 PM
    sr5shark
    Alan
    Walnut Creek, CA
    2016 SR5
    I have 5100's on the middle setting with 1 coachbuilder shim on each side. Total lift in front is 2" and is level with the back (I did not want to add blocks or shackles to the back). The ride (IMO) is better that with the stock TRD shocks. (Currently running the stock 275/65 18's)
    rv740, 16 blue crewmax, GHOST and 6 others like this.
  11. Mar 8, 2018 at 4:54 PM
    Kmaiboy
    Kmaiboy New Member
    2018 White TRD Sport CM
    Looks really good how much did that setup cost? Did you just do the front?
  12. Mar 8, 2018 at 5:06 PM
    sr5shark
    Alan
    Walnut Creek, CA
    2016 SR5
    Thanks. I did 5100's on all four corners. Shocks were ~$400 from Amazon (my install was scheduled and at the last minute I decided to return the spacer lift I had purchased and go with the 5100's) and the install for all 4 was ~$600. I could have paid less for the install but decided it was better to take my truck to someone who specializes in building off-road vehicles. I am really happy with how it turned out.
    Thanks - it is a slow process but it's getting there. :)
    MDHinSD and SouthBoundSteve like this.
  13. Mar 8, 2018 at 6:49 PM
    Js18tundra
    Js18tundra New Member
    18 Tundra sr5 TRD 4x4
    Diamondback se tonneau
    5100’s up front, middle setting, two cb shins on the drivers side, one on the passenger, 285/75/18 duratrac7B3A24D9-50F2-443F-BFF6-106F4D72FB67.jpg
  14. Mar 9, 2018 at 3:41 AM
    71_340
    71_340 The German
    Hans
    FLW, MO
    Nice stance! Must be warm where you live because your grass is already growing and green.
  15. Mar 9, 2018 at 3:48 AM
    Wvmoonshiner
    Wvmoonshiner 2020 T4R Venture SE
    Chuck
    West Virginia
    2020 T4R Venture Midnight black
    Duratrac 275/70x18 Bilstein 5100's front and rear1E0E696C-C5A6-4C81-BA3D-F5F140F150C0.jpg
    Sleeper16plat, ekertz, iWoosa and 9 others like this.
  16. Mar 9, 2018 at 5:38 AM
    darkknight2014
    darkknight2014 Mods mods and more mods!!
    Phil
    New york
    2014 tundra sr5
    20" Cooper STT Pros on md rims, quadfire lights, pro grille, leather interior, navi, retrofitted headlights, blacked out chrome, TRD sway bar, hypertech interceptor, k&n air intake, Banks exhaust
    My 5100's are at middle setting and i put 5100's on the rears. Truck came out leveled and looks good.
  17. Mar 10, 2018 at 7:27 AM
    NickyF25
    NickyF25 New Member
    SE Pa
    Here are a couple of pics that gives a pretty good view of the stance.IMG_0469.jpg IMG_0470.jpg
    khunk, Redbeard87, Stroke250 and 5 others like this.
  18. Mar 10, 2018 at 9:18 AM
    SnrDisregardo
    SnrDisregardo New Member
    Wade
    IL
    2018 Platinum CrewMax 4x4
    I like your steps. What brand are those?
  19. Mar 10, 2018 at 9:57 AM
    Js18tundra
    Go rhino rb20’s
    SnrDisregardo[QUOTED] likes this.
  20. Aug 24, 2018 at 12:03 PM
    iamsmokey
    iamsmokey Smokey the Tundra
    Oahu, HI
    2018 Cement SR5 Off-Road 4x4 Crewmax
    How is the ride quality at highest setting in your opinion?
  21. Aug 24, 2018 at 12:52 PM
    Rica25
    Ricardo
    Tulare
    Little stiff.... but not by much feels more controllable also added front sway bar and 1/2 inch spacer on top of the 5100
  22. Aug 24, 2018 at 12:53 PM
    Rica25
    Ricardo
    Tulare
  23. Aug 24, 2018 at 1:51 PM
    iamsmokey
    Oahu, HI
    Awesome. Still on stock UCA’s and stuff? How does it feel off-road?
  24. Aug 24, 2018 at 1:58 PM
    Rica25
    Ricardo
    Tulare
    Stock uca ....will be upgrading soon .......off road is good but I dont do any hardcore off roading maybe just dirt roads
  25. Aug 24, 2018 at 5:47 PM
    iamsmokey
    Oahu, HI
    Awesome I’m hoping to use he same UCA for now that’s why and am hoping to be in the right alignment specs
  26. Aug 24, 2018 at 5:51 PM
    Rica25
    Ricardo
    Tulare
    Alignment has not been an issue and now I'm on 295 70 18 Nitto Ridge Grapplers
    MDHinSD likes this.
  27. Oct 6, 2018 at 1:27 AM
    mattyd170
    mattyd170 New Member
    Albuquerque, NM
    2020 Tundra Limited Crewmax with Leer shell. Calvary Blue
    TRD Front Suspension, Bilstein Rear, TRD rear sway bar kit, 35" tires, working on stereo.
    Very nice. exactly the set up i wanted to see and I am going to do, except I have 20's.
    sr5shark[QUOTED] likes this.
  28. Mar 10, 2019 at 1:22 AM
    MDHinSD
    MDHinSD New Member
    Michael
    SoCal SD North County
    2017 Black Tundra CrewMax 4X4 TRD
    Blackout Grill
    Same setup for me also!!
  29. Mar 10, 2019 at 1:29 AM
    MDHinSD
    MDHinSD New Member
    Michael
    Blackout Grill
    Thanks!! Lokks great!
  30. Mar 10, 2019 at 3:01 AM
    Yota707
    Yota707 New Member
    Bay Area
    2015 Tundra TRD
    Auto detail, vinyl wrap specialist. Truck has a 300gal fresh water tank for spot free water while detailing and a Honda pressure washer
    I’m trying to get as close to the Pro as possible. So setting the 5100 on top setting will be the same measurement as the Pro? Does the rear need anything else or the 5100 all around gets be as close to the Pro as possible?
