Believe i have finally found some comfort in my Limited seats
Discussion in '2.5 Gen Tundras (2014-2021)' started by Berettafan, Mar 4, 2018.
  1. Mar 4, 2018 at 12:38 PM
    Berettafan
    Berettafan [OP] New Member
    2017 CM
    I've hated the seats in my '17 Limited for some time. I've gone so far as to swap the drivers seat to factory cloth, then tried cutting up the OE cushion and adding different foam (I bought 4 different types of foam from various vendors) and then buying a new OE seat cushion after that didn't work.
    Well yesterday I got it in my head that I was going to try the simplest of solutions and I'm pleased to say I've got an acceptable result. Not great, but acceptable.
    I simply added a batting material in between the cushion and the heater elements. Also, and this I think is key, I took the metal rod out of the middle seam in the seat bottom. I also put the same batting material in the upper part of the seat back. I used 3m spray glue to hold it while I fitted the OE leather covers back on.
    I don't recall where I bought it but it's a delicate material that feels like it would do very little. however I've found in seats a little goes a long way.
    I did try using 1" high density foam (good quality stuff) first and it felt way overstuffed and was horrible. Might've been better if I used the middle rod on the seat bottom but likely would've still been too much.
    So it turns out the simplest of solutions was likely the best route. I do really like the factory cloth material itself but I'm just not anxious to worry about cleaning it and the leather does look nice.
  2. Mar 4, 2018 at 1:35 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Good info.
  3. Mar 4, 2018 at 1:56 PM
    BuckWallace
    BuckWallace Ball don't lie.
    Oregon
    Sierra 3500 AT4 L8T
    You wouldn't happen to have pictures of where you put/how much you used, would you? I, too, hate the seats in my limited and would love to do something about it.
  4. Mar 4, 2018 at 2:18 PM
    16TRD
    16TRD New Member
    Norcal
    2016 White crewmax
    Anyone else thats hates their limited seat ill trade your for my cloth ones
  5. Mar 4, 2018 at 2:37 PM
    seniramsu
    seniramsu Pro Runnin
    Nate
    VA
    2017 TRD Pro Tundra Wht
    Just sounds like you haven’t properly broken them in....:cool::cool::cool:
    rebmo and Hightide like this.
  6. Mar 4, 2018 at 2:43 PM
    payyourtoll
    payyourtoll New Member
    Tampa, FL
    this is exactly why I kneel when driving, never sit.
  7. Mar 4, 2018 at 3:04 PM
    hogpiolet
    hogpiolet New Member
    Jimmie
    2018 tundra Platnium
    none
    I felt my platinum seats were very stiff when I got the truck but they have broken in very nice,just need more ass time
    Faht Nocker and Watt maker like this.
  8. Mar 22, 2018 at 10:09 AM
    Berettafan
    2017 CM
    Continue to be pleased with the change.
    Put some cotton batting between seat cushion and cover then do not re-attach the middle hog rings.
  9. Mar 25, 2019 at 7:01 PM
    Gaspssr
    Gaspssr New Member
    2019 cement grey limited 5.7
    Afe pro dry filter with trd accelerator.
    Hey man did you have any pics of your upgrade? My issue is with the back of the seat, it shoves my middle back out causing it to cramp. Seems like cutting the foam out would help this but you didn’t get any benefit??
    AggiePhil likes this.
  10. Mar 26, 2019 at 4:28 AM
    Berettafan
    2017 CM
    I haven't worked out how to fix that issue yet. I initially tried adding foam to the top half of the seat but didn't like how that felt.
  11. Mar 26, 2019 at 4:39 AM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    Almost all the complaints I have heard about seats pertained to the Limited seats. Are they different than the other trim levels?
    I don't like leather and was stoked to see the TRD Sport came with cloth (Standard SR5 seats). My seats are very comfortable.
  12. Mar 26, 2019 at 5:14 AM
    Rngr188
    Rngr188 Ranked the best new member of all time
    Chad
    Harrison AR
    2020 1794 MGM TRD OR
    Are you still running cloth?
  13. Mar 26, 2019 at 7:13 AM
    Gaspssr
    Gaspssr New Member
    I was told the limited leather is the same that’s in the TRD Pro but maybe I’m wrong.
  14. Mar 26, 2019 at 8:39 AM
    Spitfire
    Spitfire New Member
    Long Island
    2018 Cement Limited Trd off road
    i like the limited seats.. drove 16 hrs home last summer and was comfortable.. i don't want to be sitting on a soft leather couch when i'm driving
  15. Mar 26, 2019 at 8:44 AM
    Racingjohndeere55
    Racingjohndeere55 New Member
  16. Sep 27, 2020 at 8:51 AM
    Avi8or
    Avi8or New Member
    Johann
    MO
    2020 Limited Crewmax
    I took Berettafans lead and picked up some cotton batting. Got mine at Walmart for $5.
    I have hip bursitis on my right side so was looking for a flatter seat. So I lopped off the bolsters on both sides of the foam prior to adding the cotton. I put down a half sheet on the back of the seat and two full sheets on top of that.
    I did not replace any hog rings yet. I want to see how this goes before adding those back in. This setup leaves the bolster leather a little floppy, but it doesn’t bother me. The flatness of the seat was the primary goal. Seat is quite a bit softer and more importantly 1980’s flat.
    I do plan to add the driver grab handle to prevent sliding out when exiting.
    AggiePhil and pickeledpigsfeet like this.
