I’m concerned: popping noises coming from front driveer side
Discussion in 'Suspension' started by Eclipsed & Floating, Feb 22, 2018.
  1. Feb 22, 2018 at 8:41 AM
    Eclipsed & Floating
    Eclipsed & Floating [OP] Over it.........
    I’m right where I need to be
    Voluptuous Whitey
    Just driving. Not standing still
  2. Feb 22, 2018 at 8:50 AM
    Eclipsed & Floating
    Voluptuous Whitey
    Huh????????
    Remember, I’m not very well equipped to speak Truckssian
  3. Feb 22, 2018 at 9:02 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    UTTUNDRA meant turning the wheel while standing still, not just standing still. Have you tried it?
  4. Feb 22, 2018 at 9:11 AM
    Sorry homie. I have been more busy than a hooker on nickel night.
    How are the coilover Upper mount bolts? All three tight and still in place? I’m sure they are if toytec did the install.
    Coilover pop is nothing new, but hard to diagnose at times. I don’t thing you have a problem, other than spring pop. Dual rate coil overs can be a PITA with spring noise, but cured more easily.
    So let’s test something out. Have any WD40 or spray lube?
  5. Feb 22, 2018 at 9:15 AM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    I don't know if RCI could have the same problem, but the issue with the TRD is not that it was too loose. It is that it was tight against the frame, and popping sounds could be heard as the steel frame flexed. The solution was to loosen the 2 rear mounting bolts, and sandwich some high density foam tape between the frame cross-member and the lip of the plate, and then tightening it back down. The difference was night and day. I was all ready to start shot-gunning my wheel bearings and CV's.
  6. Feb 22, 2018 at 11:52 AM
    Eclipsed & Floating
    Voluptuous Whitey
    I knew what he meant. Yes, I have
    joonbug[QUOTED] likes this.
  7. Feb 22, 2018 at 11:53 AM
    Eclipsed & Floating
    Voluptuous Whitey
    Sure do. Where do we start spraying?
  8. Feb 22, 2018 at 11:54 AM
    Eclipsed & Floating
    Voluptuous Whitey
    I thought you were referring to rubbing. Good thought....I’ll crank them down too
  9. Feb 22, 2018 at 12:23 PM
    Wash your coilovers off good.
    Spray the coil adjustment nut and the bottom coil plate. It may take several applications turn wheels back and fourth several times to work in the WD40. This will evaporate over time, but a good and easy way to tell if your getting coil spring popping.
    T-Rex266 and Sunnier like this.
  10. Feb 22, 2018 at 12:25 PM
    If that solves the problem, we can discuss how to fix it long term.
  11. Feb 22, 2018 at 1:22 PM
    Spvrtan
    Spvrtan Amateur fabricator
    Kris
    San Diego, CA
    Black '14 CM SR5 w/ SC; 40s on 17s; 5.29s
    Check your LCA balljoints for play. Jack up a side by the LCA and put a pry bar between the balljoint bracket and the LCA and pry a bit to see if the bracket moves.
  12. Feb 22, 2018 at 1:24 PM
  13. Feb 22, 2018 at 2:04 PM
    LOTSOFTOYS
    LOTSOFTOYS Toyota Whisperer
    Jace
    Mile high
    2005 Tundra DBL cab
    Just one pop when going over bumps or click click click when rolling?
  14. Feb 22, 2018 at 2:42 PM
    Vizsla
    Vizsla pretend2send
    I’ll add an easy one, do your shocks have a heim or ball mount at the bottom? Your weather kills them fast.
    ColoradoTJ likes this.
  15. Feb 22, 2018 at 4:25 PM
    Eclipsed & Floating
    Voluptuous Whitey
    More of a click click click that increases in intensity depending on the angle at which I’m turning. Doesn’t happen when the wheels aren’t turning.
    havent had a chance to really inspect due to work and nasty weather but I’m not exactly sure if I found the culprit that I’d even know it. I can install plug and play stuff but outside of that I’m pretty clueless
  16. Feb 22, 2018 at 4:28 PM
    Eclipsed & Floating
    Voluptuous Whitey
    Not sure I know what a helm joint is but here’s a pic
  17. Feb 22, 2018 at 5:47 PM
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Sounds like a xv axle or something rubbing the backing plate maybe but that would be all the time most likely not just straight and right
    UTTundra likes this.
  18. Feb 22, 2018 at 6:43 PM
    Eclipsed & Floating
    Voluptuous Whitey
    It seems to be quieter at faster speeds but now it’s now doing it turning left as well. The tighter the turn the harder it pops
  19. Feb 22, 2018 at 6:56 PM
    If this noise is more of a clicking noise, that is not CO spring pop.
    If it sounds rotational, it would have to be in the drivetrain somewhere.
    Watt maker likes this.
  20. Feb 22, 2018 at 6:58 PM
    #50
    Eclipsed & Floating
    Voluptuous Whitey
    It’s less click, more popping. Straight at higher speeds I can’t hear it. Slow down and turning it seems to be worsening, or staying the same but my awareness is much more heightened
    My limited knowledge was pointing at CV in my head, but again, I’m not very savy
    831Tun likes this.
  21. Feb 22, 2018 at 7:01 PM
    #51
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    Post a video.
    Send noods.
  22. Feb 22, 2018 at 7:02 PM
    #52
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    I’m guessing CV. Similar sound on my Tacoma. Had two go at different times. Grab the cv and see if one has more movement than the other.
  23. Feb 22, 2018 at 7:02 PM
    #53
    Eclipsed & Floating
    Voluptuous Whitey
    Video=difficult to hear
    Noods=scary to the younger crowds
  24. Feb 22, 2018 at 7:03 PM
    #54
    Eclipsed & Floating
    Voluptuous Whitey
    At 30,000 miles? I was thinking the same but seems a little early for it
  25. Feb 22, 2018 at 7:18 PM
    #55
    Have you tried lubing the coil spring where I ask you to? That would eliminate spring pop.
    There is a lot of scenarios that can cause this, and eliminating one at a time is the best troubleshooting technique.
  26. Feb 22, 2018 at 7:19 PM
    #56
    Eclipsed & Floating
    Voluptuous Whitey
    I wish. It’s 3 degrees, dumping snow, and I’ve been working all day
  27. Feb 22, 2018 at 7:20 PM
    #57
    Well I guess the trip down to the dealership tomorrow might get you some answers.
  28. Feb 22, 2018 at 7:29 PM
    #58
    Eclipsed & Floating
    Voluptuous Whitey
    If I can do it. I’m contemplating just hanging tight and checking what you’ve recommended along with the others that have chimed in. That wouldn’t happen until Sunday so I hope the weather gets better! I don’t have a garage to use and there’s a foot of snow in my driveway :frusty:
    Chris, I tell ya....it’s starting to wear on me and I’m probably going to making some moves sooner than I thought, and not just because of this
  29. Feb 22, 2018 at 7:58 PM
    #59
    Drive to Aurora and get it to Jace. You get special attention being a forum guy :thumbsup:
  30. Feb 23, 2018 at 9:13 AM
    #60
    Eclipsed & Floating
    Voluptuous Whitey
    Trucks at the dealership. If CV issues exist it’ll be covered under warranty. If it’s due to wheeling then I might be pinched
    They did get me a rental because they said it sounds CV related and I didn’t tell them about off roading :D
