UCA Options...
Discussion in 'Suspension' started by TRD PRO 17, Feb 15, 2018.
What UCA option would you choose?
  1. JBA OFFROAD
    36 vote(s)
    48.6%
  2. SPC
    29 vote(s)
    39.2%
  3. OEM
    9 vote(s)
    12.2%
  1. Feb 15, 2018 at 2:39 PM
    TRD PRO 17
    TRD PRO 17 [OP] New Member
    Tyler
    2015 Inferno Crewmax TRD PRO
    Okay...
    I have a 2015 TRD PRO and am currently running @Coachbuilder1 shims shackles and bump stop extensions. I will soon be installing his steering kit when I install my @SCSPerformance Ray10's.
    While I am getting the above done I would like to upgrade my UCA's also. I have been particularly looking at JBA OFFROAD and am about 90% sure that is what I'm going to go with. If I were to go with another aftermarket UCA it would be SPC. I know that it isn't absolutely necessary to do but I figure it wouldn't be a bad idea to upgrade them as well.
    So, my question is...
    What would you do?
    Jetplanetundra and dcsleeper408 like this.
  2. Feb 15, 2018 at 2:43 PM
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    @BlueBottle has camburg ball joints for sale.
  3. Feb 15, 2018 at 2:53 PM
    joem1cha3l
    joem1cha3l New Member
    Albany, NY
    2016 Double Cab SR5 Blazing Blue Pearl
    BOSS Suspension, DB Customz Grill, 35's, Spyder, Tint, Color matched corners
    Depends how much maintenance you want to do with them too...
    I run SPCs and I’m happy but I don’t off-road. It was for alignment purposes solely after I installed my lift
    Paul B likes this.
  4. Feb 15, 2018 at 2:58 PM
    TheBeast
    TheBeast The Beach
    I myself like Total Chaos :)
  5. Feb 15, 2018 at 3:00 PM
    TRD PRO 17
    Tyler
    I don’t mind greasing them.
  6. Feb 15, 2018 at 3:01 PM
    TRD PRO 17
    Tyler
    Sticking with ball joint style. They salt The roads too much in the winter for me to even want to try a uniball setup.
    Paul B and Mountun Goat like this.
  7. Feb 15, 2018 at 3:51 PM
    crishard
    crishard Occasional Member
    Cris
    2014 Barcelona Red CM
    3" level in front, ICI Bumper & Skid, 12k lb winch, UCAs, Radtech 2.5s, Kenda 35s, Dual Batteries, 3500w inverter
    I'm considering upgrading my UCAs within the next year & am trying to learn what I can. Why would the salt hurt the uniballs? I thought that they were practically bomb proof.
    I have read that some people get some noise from the uniballs. From the liners maybe?
  8. Feb 15, 2018 at 3:54 PM
    Aurora CO
    SPCs next on my list. Not fancy looking. No labeling. Gets the job done.
    Rica25 likes this.
  9. Feb 15, 2018 at 3:56 PM
    Noodle
    Noodle That Guy
    Files creek
    2016 Tundra Limited TRD DC Inferno
    Following due to the fact I’m leaning towards JBA myself. Sharp looking Inferno @TRD PRO 17 :thumbsup:
  10. Feb 15, 2018 at 4:13 PM
    n2deep
    n2deep Pavement Princess
    Wondering the reason you are planning CB Steering kit?
  11. Feb 15, 2018 at 4:19 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Actually someone already bought em... ahem jp...
  12. Feb 15, 2018 at 4:26 PM
    TRD PRO 17
    Tyler
    Much appreciated @Noodle. I really like the look of them and they seem to be extremely strong/beefy. Everyone that has them who I have talked to in the Tundra and Tacoma world loves them!
    @n2deep for the extra degree of travel they allow over the stock tie rods.
  13. Feb 15, 2018 at 10:07 PM
    n2deep
    Haven't noticed the tie rods limiting travel. But interesting.
  14. Feb 15, 2018 at 10:11 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Coachbuilder tie rods are great but they can limit caster. Because they're straight and beefy they can hit the lower spring perch. and you may find you can't get more than 3* caster.
    Sunnier likes this.
  15. Feb 15, 2018 at 10:19 PM
    TexasTundra27
    TexasTundra27 Moby Dick
    Mark
    2011 Tundra CM 4x4 5.7
    Icon stage 3, Icon billet UCAs, 5.29s, ARB lockers F+R, Coachbuilder +2s and shims, Rago fab ditch light brackets and bed stiffeners, Rago Fabrication sliders, ARE camper, 17x9 XDs and 37/12.5/17 stt pros, DT long tubes, xpipe with dual magnaflows, Full skids, TrailToys front and rear bumpers
    If you don’t want uniballs because of the salt, then you probably don’t want to run his steering kit. They’re essentially the same thing, OEM tie rods are pretty damn stout.
    831Tun likes this.
  16. Feb 15, 2018 at 10:25 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Good point, I hadn't even thought of it and I'm running 'em.
    TexasTundra27[QUOTED] likes this.
  17. Feb 16, 2018 at 2:28 AM
    [DELETED]
    [DELETED] New Member
    Jeff
    Voted SPC as that is what I ran on my '12 DC. I'll be running the Camburg uni-balls on the '18 CM.
    No complaints with the SPCs. They just worked.
  18. Feb 16, 2018 at 9:08 AM
    Mr. Rogers
    Mr. Rogers New Member
    Forsyth, Ga.
    2017 MGM Tundra TRD 4x4 SR5
    Toytec/Eibach 3"coilovers, JBA uca's, 1" rear blocks with bilstein 5100's, Nitto RG's 295/70/18
    I went with the JBA's because they're priced right, and i like the red.
    Rica25, Texas Bandit, Ryuu and 3 others like this.
  19. Feb 17, 2018 at 11:49 PM
    Kwikfish
    Kwikfish Get your poop in a group!
    Tri cities,WA
    16 CM SSM
    Im leaning twards the JBA's on my new to me tundra,but had SPC's on my tacoma and they worked fine.not sure what lift im going with uet so that may change my mind for the adjustment you can get from the spc's
  20. Feb 18, 2018 at 12:27 AM
    boostedtrdpro
    boostedtrdpro voided warranty
    Jeremy
    2019 SC TRD Pro CM 040 2020 Sequoia TRD Pro 040
    Total Chaos Uni-ball FTW!
  21. Feb 18, 2018 at 8:40 PM
    Kwikfish
    Tri cities,WA
    16 CM SSM
    Mr rogers how dod your alignment turn out with the JBA's?
  22. Feb 18, 2018 at 8:42 PM
    15'TeRD
    15'TeRD New Member
    Tony
    San Diego
    15 TRD Double Cab
    Nothing special
    Is that the toytec ultimate coiliver.? If so gue is the ride.?
  23. Feb 18, 2018 at 8:45 PM
    boostedtrdpro
    Jeremy
    It's the ToyTec Boss kit. It's a very nice ride. Pleased with my decision on that kit.
  24. Feb 19, 2018 at 5:46 AM
    [DELETED]
    Jeff
    ...bout to be running these. Just don't think I'll be disappointed.
    Rica25 and SoCal619 like this.
  25. Feb 19, 2018 at 7:00 AM
    V-TRAIN
    V-TRAIN New Member
    2015 TUNDRA LIMITED
    i would get the jba. i used to have total chaos on my tacoma and they were fantastic, i just like the shield on the top and the boot on the bottom on the jba.
    it is better protection from the elements.
    Sunnier likes this.
  26. Feb 19, 2018 at 7:13 AM
    chphilo
    chphilo Tundra addict
    Western PA
    2010 Toyota Tundra TRD 5.7 4x4 CM
    I went with the OME and SPC set-up mainly because they are maintenance-free. I've had them for almost four years with zero issues with absolutely zero maintenance. The truck went through PA winters with plenty of salt/chemical. (This picture was taken shortly after the installation.
    Mountun Goat and boostedtrdpro like this.
  27. Feb 19, 2018 at 9:09 AM
    Samoan Thor
    Samoan Thor God is technically an alien
    Limited 2014 crewmax 4X4
    Kings F&R, no sway bars
    I vote total chaos for performance, its one of those subjects everyone has had different experiences when talking about uniballs and salty areas, some have had no problems some had problems. If youre worried about that then the icon delta joint has a high angle ball joint design that functions like a uniball and is enclosed not exposed to the elements.
  28. Feb 19, 2018 at 9:36 AM
    OBXTundra
    OBXTundra Member
    Southeast USA
    2018 Nissan Armada, 4x4
    JBA here. Installed maybe 5 months and 2000 miles ago. The JBA ball joint will not be a limiting factor for travel unless you're planning to go LT. I'm sure you've read up on the JBA ball joint by now, if not....
    • Up travel is 40 deg off of center line of the ball joint.
    • Down travel is 50 deg off of center line.
    • Full range of motion is 90 deg.
    Texas Bandit, Ryuu, Noodle and 4 others like this.
  29. Feb 19, 2018 at 8:38 PM
    Kwikfish
    Tri cities,WA
    16 CM SSM
    And i heard people getting good alignment numbers woth the JBA's as well,bonus the joint can be found at most any parts store
  30. Feb 20, 2018 at 4:27 AM
    TRD PRO 17
    Tyler
    Nice!
    I’ve been eyeing them for quite some time so I think I’m pretty set on going with the JBA’s when it’s time!
