Radio antenna replacement?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Rski85, Feb 9, 2018.
  1. Feb 9, 2018 at 7:48 PM
    Rski85
    Rski85 [OP] New Member
    Well second day of owning the 18 cm I noticed the huge old school antenna, is there any good or better replacement for it? I looked on Amazon and there is tons!! Which one gives great reception for FM and XM and for hd radio?
  2. Feb 9, 2018 at 8:48 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    I believe it was @matluth that bought several and tested 'em. I went with antenna X,,,, I think.
    Wvmoonshiner likes this.
  3. Feb 9, 2018 at 8:49 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
  4. Feb 9, 2018 at 9:03 PM
    ChucklesToy
    ChucklesToy New Member
    Chuck
    Round Rock, TX
    2024 Tundra Limited 4X4 Nightshade Blueprint
    BAK MX4, PPF,Tint, AMP PowerSteps, TRD Options+
    831Tun and Black Wolf like this.
  5. Feb 9, 2018 at 9:03 PM
    Aurora CO
    It's all trial and error. Quite frankly all the shorty's don't come anywhere close to OEM. They can't. Too short. Placement and Physics. Has nothing to do with old school. Going to go back to OEM as soon as I can find it. Besides I like my XM.
  6. Feb 9, 2018 at 9:05 PM
    ChucklesToy
    Chuck
    Round Rock, TX
    After I had the TRD Pro shocks installed which leveled my truck, the OEM antenna hit the garage door, but just a little. I talked to the guys at The Antenna Source and they recommended the 27" with noise cancellation wire and it works great!
    http://www.theantennasource.com/TOYOTA/TUNDRA/Tundra 2015-2018.html#1A
    SuaveRC and Black Wolf[QUOTED] like this.
  7. Feb 9, 2018 at 9:06 PM
    Aurora CO
    That antenna should work just fine.
    ChucklesToy[QUOTED] likes this.
  8. Feb 9, 2018 at 9:56 PM
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Too many…scratch that…not done yet.
    Additionally, I'll add that your station's broadcast power (dBu), terrain, elevation can all contribute to the reception, or lack thereof. Of course, your proximity to the station's tower(s) also impacts reception.
    I added the Stubby from theantennasource.com last year and have had no issues. That said, I live just outside of Atlanta and I'm pretty close to some powerful stations.
    Check out this page...
    http://www.v-soft.com/on-line-based-software/zipsignal
    Lists all your local stations by zip, and shows their broadcast strength.
  9. Feb 10, 2018 at 1:38 AM
    Aurora CO
    Yeah, once you get up in the mountains here in CO where reception can be great with any antenna and then drop down into a canyon, reception can get dicey at best making stubbies nothing more than miniature flag poles.
  10. Feb 14, 2018 at 5:45 AM
    mscroggi
    mscroggi New Member
    All true. But if you are using XM, you can just go with a stubby since XM doesn't use that antenna. After reading some discussions, I bought a mid-size stubby from antennamastsrus.com. I was surprised it worked as well as it did.. I live in a flat landscape so I don't think it is difficult to get acceptable antenna performance. Since I listen to satellite anyway, I don't really care much about the terrestrial radio antenna, but I wanted one that was as good as it could be, without worrying about it being broken off at a car-wash.
  11. Feb 14, 2018 at 5:59 AM
    SuaveRC
    SuaveRC New Member
  12. Feb 14, 2018 at 6:18 AM
    mlucas555
    mlucas555 New Member
    Mark
    San Antonio, Tx
    2016 MGM Double Cab
    Still rocking the stock height.
    I went with one of the 50 cal antennas. I mainly use Xm, but still get an ok signal with the little 50 cal one. I am in San Antonio, so that may help with why I am still getting a signal. I wanted it more for the looks than function.
    SuaveRC and Black Wolf like this.
  13. Feb 14, 2018 at 6:29 AM
    Aurora CO
    Yeah, I like my XM. All the stubbies I tried out with my stock radio worked ok in town. It's just when up in mts they can get iffy which is to be expected.
    mlucas555 likes this.
  14. Feb 14, 2018 at 7:08 AM
    canadianguy
    canadianguy New Member
    Kevin
    Lloydminster Alberta
    2017 SR5 trd off-road
    All the usual stuff!
    I had a shorty antenna but switched back to the stock one for parking reasons. Your antenna is that high because is a over height guide. I wouldn’t wanna scratch my roof in underground parking or in a parkade pulling under those steel pipes that hang down.
    Black Wolf likes this.
  15. Feb 14, 2018 at 8:07 AM
    71_340
    71_340 The German
    Hans
    FLW, MO
    To the OP,
    You didn't notice the antenna when you looked at the truck and test drove it?
    From reading all this I guess the bottom line is that the OEM antenna works best as far as reception is concerned, I really don't understand what the big deal about it is anyway. My wife's BMW has a short AM/FM antenna from the factory but it also has an amplifier to compensate for being short. If you really hate your regular antenna that much but still want good reception An amplified antenna is probably the way to go.
  16. Feb 14, 2018 at 8:16 AM
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
  17. Feb 14, 2018 at 8:21 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
  18. Oct 13, 2018 at 6:47 PM
    FirstTruck
    FirstTruck New Member
    18 Tundra MGM CM TRD Sport
    Stock, for now
    Besides not having an alarm, no remote starter, no key fob and no start button, I hate that antenna as well. Has anyone attempted to relocate it and use a roof one with an ampflifier?
  19. Oct 13, 2018 at 6:57 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Are you sure you don't have an alarm? Try opining you door when it's locked.
    NewImprovedRon likes this.
  20. Oct 13, 2018 at 8:26 PM
    FirstTruck
    Stock, for now
    So youre saying that the truck might have alarm?! Great news. I will try tomorrow. So while inside the truck I should lock it, wait for some kind of light on the dash and finally open the door?
    Thank you
  21. Oct 13, 2018 at 10:47 PM
    TRD-tv
    TRD-tv Menace2Ohio
    Cleveland OH
    2012 MGM Tundra TRD
    No joke I'd be really interested in a manual telescoping antenna if they had one that worked lol
    Just keep it out until I know I gotta hit a parking garage. That's the only reason I have a shorty
  22. Oct 14, 2018 at 10:00 AM
    FirstTruck
    Stock, for now
    Sorry OP for highjacking your thread. Wasnt meant to be. Lets go back to the antenna topic. Lets find a way to delete de 3’ long mast and install a roof antenna with an amp. I have been searching for options. Maybe the one from Camry or highlander could work. Not sure. As I understand that antenna is only for AM and FM radio. Could be wrong.
