Illuminated ignition ring
Discussion in 'Lighting' started by Jaydawg, Jan 2, 2016.
  1. Jan 2, 2016 at 2:37 PM
    Jaydawg
    Jaydawg [OP] New Member
    Hey Guys,
    I know a number of newer trim levels (limited, pro etc) have illuminated entry system like foot lights and illuminated ignition rings. I was just curious what colour does the ignition ring light up?
    I've tried searching online and through these forums but couldn't find an answer.
    Thanks and nice forum!
  2. Jan 2, 2016 at 3:29 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Welcome! I have a 2012 TRD Rock Warrior without the light so I can't help you there. Are you considering a swap to yours so you have the illuminated ring?
    zachzap361 and Rica25 like this.
  3. Jan 2, 2016 at 4:15 PM
    Jaydawg
    Thanks... The platform is nice and familiar here since I have an account over a TW. Yeah I'm looking to put an illuminated ring into a Tacoma. I see through some cross referencing that both trucks share the non illuminated version so it should swap over just fine, but not sure what colour the light is.
    I don't actually have a Tundra, although the last year or so I've been keeping a close eye on them... They look pretty bad ass with some of the mods you guys do to them.
    because_wumbo-truck likes this.
  4. Jan 2, 2016 at 4:57 PM
    T-Rex266 Moderator Staff Member
    Mine does - 2014 limited. Like a blue LED similar to my interior LED lights.
  5. Jan 2, 2016 at 5:02 PM
    Jaydawg
    Awesome thanks! I was hoping it would be blue but white would be my second choice. I guess I could always solder in a new LED if I wanted blue though.
    Rica25 likes this.
  6. Jan 2, 2016 at 5:04 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I thought that I read that there are two options that you can have with the (Tundra) ignition. One is the illuminated ring. I can't recall what the other one is at the moment, but I want to say that it's a security function of some sort. I bet @LOTSOFTOYS knows. The same may or may not be true for the Tacomas.
  7. Jan 2, 2016 at 5:08 PM
    Jaydawg
    The ring is attached to what Toyota calls a transponder amplifier. Basically it reads the information from the chip in your key. However the illuminated version does that too, but also has the light.
    Wynnded[QUOTED] likes this.
  8. Jan 2, 2016 at 6:47 PM
    AMRE2ME2
    AMRE2ME2 New Member
    2016 DC 4x4 Limited TRD
    Learn something new. I've got a limited but never noticed the lighted ring. Once you find the hole, it becomes second nature where to stick your key!
  9. Jan 2, 2016 at 7:06 PM
    Giggity
    MentalBill, Geo4x4, Ostrich and 4 others like this.
  10. Jan 2, 2016 at 8:10 PM
    Aurora CO
    Lighted rings can be pretty kinky. :headbang:
    D4x4TRD and 831Tun like this.
  11. Jan 3, 2016 at 2:44 AM
    chphilo
    chphilo Tundra addict
    Western PA
    2010 Toyota Tundra TRD 5.7 4x4 CM
    I have 2010 SR5, off-road, and it has illuminated ring. Perhaps Toyota took this away and limited to the upper trims, sort of like the dual climate control.
  12. Jan 3, 2016 at 6:33 AM
    Virgils12
    Virgils12 New Member
    Camburg Fox factory 2.5" lift Xd monsters with 295/70/18 nitto terra graplerrs Corsa cat back Weather tech liners Wet okole covers
    My 12 sr5 has dual climate control but no ring? Would like to have it tho.
    D4x4TRD likes this.
  13. Apr 10, 2016 at 8:47 PM
    csuviper
    Broomfield, CO
    Rica25 and NewImprovedRon like this.
  14. Apr 11, 2016 at 1:25 PM
    csuviper
    Broomfield, CO
    It's just glow in the dark so probably not that bright. At $6 it might be worth a shot.
  15. Apr 11, 2016 at 6:01 PM
    swede78
    swede78 Not so new member
    Lars
    westminster co
    2019 tundra platinum mgm crew max
    Nothing yet
    2008 dbl cab sr5, illuminated key ring and duel climate control
    Rica25 likes this.
  16. Dec 13, 2017 at 4:00 PM
    ccdawnpatrol
    ccdawnpatrol New Member
    Salt Lake City, UT
    2017 SR5 MGM CM 4x4 5.7L
    So I do not have an illuminated ignition ring. I can't seem to find anything online. Anyone heard of a mod/addition for this? If so, can you provide a link? Thanks!
  17. Dec 13, 2017 at 4:12 PM
    TXRailRoadBandit73 YOTAS,RAILROADIN',RĂ–KnRĂ–LLN',BEER,MAX/GEMMA
    Rica25 likes this.
  18. Dec 13, 2017 at 4:17 PM
    ccdawnpatrol
    Salt Lake City, UT
    You know if anyone sells an ignition system from a higher end model? Maybe someone that has different colors too? This may not be at the top of anyone's list for mods, but should be standard for any model IMO.
  19. Dec 13, 2017 at 4:19 PM
    I want one now!!!!
    ccdawnpatrol[QUOTED] likes this.
  20. Dec 13, 2017 at 5:21 PM
    boardude
    boardude I am Batman
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    My Pro doesn't have an illuminated ignition
    ccdawnpatrol likes this.
  21. Dec 13, 2017 at 5:22 PM
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Just get one of these
  22. Dec 13, 2017 at 5:59 PM
    Stumpjumper
    Stumpjumper New Member
    Fate, Tx
    2017 Tundra TSS 4x4
    And you don't need any flour
  23. Dec 13, 2017 at 8:07 PM
  24. Dec 13, 2017 at 8:35 PM
    Taco-Blender
    Taco-Blender Old Guys Rule
    AZ
    2010 DC 4x4
    2010 SR5. Mine has the white illumination ring. Also has the dual zone climate control, no auto temp/thermostat though.
  25. Dec 13, 2017 at 8:39 PM
    Eclipsed & Floating
    Eclipsed & Floating Over it.........
    I’m right where I need to be
    Voluptuous Whitey
    I’ll come help you install it if the money is right
  26. Dec 13, 2017 at 9:36 PM
    ccdawnpatrol
    Salt Lake City, UT
  27. Dec 14, 2017 at 4:13 AM
    TruckLife900
    TruckLife900 I'd rather B hunting
    2013 White SR5
  28. Dec 14, 2017 at 5:47 AM
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Wait, who's paying who? And for what?
  29. Dec 14, 2017 at 5:52 AM
    Eclipsed & Floating
    Voluptuous Whitey
    I can assure you that I’m not offering you any money....
    How’s that suspension riding, btw?
  30. Dec 14, 2017 at 6:55 AM
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    I feel like that's a service I should charge for.
    Suspension is super plush! The rear kinda bucks a little from the AAL so can't wait to get the rear in order for the full effect
