Throttle controller or ammo?
Discussion in 'General Tundra Discussion' started by Ccrames, Feb 6, 2018.
Which would you choose?
  1. Ammo
    100.0%
  2. Throttle controller
    0 vote(s)
    0.0%
  1. Feb 6, 2018 at 10:04 PM
    Ccrames
    Ccrames [OP] 2014 SSM CM 5.7
    Nor Cal
    Bilstein 5100s, Method Standard 18x9 +18 offset, 285/65R18 Toyo A/T2 Xtreme, trailer brake controller, bed liner, camper shell. All were on the truck at time of purchase.
    What do you guys think, should I get a Pedal Commander for about $300 or buy 600 rounds of 5.56x45mm? The Pedal Commander seems pretty cool from what I've read, and a friend who has one on his '16 Tacoma says he likes it, but is it better than a decent amount of ammo? I honestly can't make up my mind, so you guys tell me what you think I should do! Or maybe I should just save the money for that huge gas+insurance bill... But that's not very fun:rolleyes:
  2. Feb 6, 2018 at 10:29 PM
    Keep saving...get a Magnuson SC :burnrubber:
    mudslinger79 and Prostar 190 like this.
  3. Feb 6, 2018 at 10:29 PM
    Other option.. daptune some on here swear by it... IMO
  4. Feb 6, 2018 at 10:50 PM
    Ccrames
    Nor Cal
    Haha yep the SC would be awesome, but I want to keep both my wallet and my Toyota reliability :p
    Who can do the DAP tune and where would I have to go to get it done? Also I heard it's in the $600ish range, does that sound about right? Thanks
  5. Feb 6, 2018 at 11:27 PM
    Stewie
    Stewie New Member
    2016 Crew Max
    Peddle commander is a waste of money IMO. If you want to change the throttle mapping just hit the tow haul button.
    If these are your only two choices, buy the ammo.
    NewImprovedRon and tomsinamerica like this.
  6. Feb 6, 2018 at 11:34 PM
    Ccrames
    Nor Cal
    I may consider the dap tune if its not too expensive and won't sacrifice reliability/engine life, although if both the pedal commander and the tune will have nearly the same effect as tow/haul mode, I might as well use my tow haul button for free (other than the decrease in mpgs) and itch my trigger finger instead!
    NewImprovedRon likes this.
  7. Feb 6, 2018 at 11:48 PM
    Stewie
    Stewie New Member
    2016 Crew Max
    The tune will net a HP and TQ increase. Pedal commander wont.
  8. Feb 7, 2018 at 12:10 AM
    aperezsh
    aperezsh Blessed are the peacemakers
    Ali
    cal-exit landed in GA
    16 Tundra SR5 4x4 Crew Max Magnetic Gray Metallic
    A little this and that...Broke now
    Ammo!!!!!!!!!!!!!!!!!!!!!
    Eclipsed & Floating likes this.
  9. Feb 7, 2018 at 12:51 AM
    Ccrames
    Nor Cal
    Well based on your comments, and having tested out tow/haul without a load, im gonna go with the ammo. I don't know why I haven't tried the tow/haul thing before. I know that low end torque and throttle response is kinda the point of it but I'm still surprised at the push you back in your seat feeling you get from it without even mashing the throttle.
    Eclipsed & Floating and aperezsh like this.
  10. Feb 7, 2018 at 1:30 AM
    Casper3
    Casper3 New Member
    Jay
    CT/OH
    2017 Super White 5.7 SR5 TRD off road
  11. Feb 7, 2018 at 7:28 AM
    Eclipsed & Floating
    Eclipsed & Floating Over it.........
    I’m right where I need to be
    Voluptuous Whitey
    X2, 3, 4, and :infantry:
    Shoot out the tires of trucks that are faster
    Ccrames[OP] likes this.
  12. Feb 7, 2018 at 7:28 AM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Neither. Get bullydog bdx. That throttle commander is a rip off!
  13. Feb 7, 2018 at 7:32 AM
    Smiley
    Smiley New Member
    08 Tundra TRD
    Take some more firearms trainng.
  14. Feb 7, 2018 at 8:45 AM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    The peddle commander is like a Big Mac. It's great, but tomorrow, you'll just be hungry again. It remaps the peddle curve. Once you develop muscle memory for the new setup, it will be like you never added it.
