Disappointing Quality on 2018
Discussion in '2.5 Gen Tundras (2014-2021)' started by JBang, Feb 3, 2018.
  1. Feb 4, 2018 at 6:28 AM
    Just need to add Pudges' maple syrup.
  2. Feb 4, 2018 at 6:36 AM
    If I were ever to buy a new Tundra I would special order it to my liking. The way I want it although special orders are nothing like it used to be back in day. More engine choice, gears, lockers, minor trim changes, carpet or no carpets. Real trucks back in my day had "no carpet" standard, just rubber floormats. Made it easier to hose it out. AC was an option too. Manual trannys were preferred over matics. No overheating issues. AAMCO boys bored...
  3. Feb 4, 2018 at 6:36 AM
    757TUNDRA
    757TUNDRA Not a New Member
    Illinois
    2018 Barcelona Red Metallic Platinum 4x4
    OEM Bed Cover, OEM Bed Rail System, OEM Bedmat, OEM Doorsill Protectors, OEM TRD Rear Sway Bar, OEM Color Matched Door Handles, OEM Color Matched Mirror Caps, OEM Bed Net, OEM Driver Side Grab Handle, BFG K02 LT275/60/20, WeatherTech Digifit FloorLiners, Salex OCD Console Organizer, Salex Console Tray
    Totally agree! And when they buy it and have an "issue" or find something they don't like they go straight to the forums to complain.
  4. Feb 4, 2018 at 7:01 AM
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    2018 5.7 4x4 Crewmax TSS
    I always take the demo vehicles I'm interested in down a few of our fine Shreveport/Bossier roads. The one that wins is usually the one that the dash doesn't try to leave the cab. Not that the Toyotas didn't shake or rattle but I had the other "big three" dashboards moving completely independent the rest of the interior. Two years ago I drove a Ram demo with a rock peck in the windshield and watched it run all the way across from the passenger side.
    Once I have decided, I take the one I'm going to buy out for a "shakedown" too.
  5. Feb 4, 2018 at 7:09 AM
    joonbug likes this.
  6. Feb 4, 2018 at 7:32 AM
    Hausincake?
  7. Feb 4, 2018 at 9:14 AM
    ChucklesToy
    ChucklesToy Retired
    Chuck
    Georgetown , TX
    2024 Honda Ridgeline Black Edition
    Me too! With all of the online info out nowadays, I did my research and decided before even contacting a dealer that I wanted a Platinum to replace my Silverado LTZ. Then, after using TrueCar to locate Platinums in my area, I scheduled a test drive on a Saturday morning. After taking it out on the best and worst/bumpy roads with the salesman for an hour, he put a temp tag on it and then I took it for an extended all day "test drive" to show the Mrs. It drove and handled great and no rattles at all. I did the deal that night and closed on Monday. On Sunday, I downloaded the OM and read through it and have been referencing it ever since (and provided many references to the OM on here as well to those that "are too busy to read" haha). I learned a long time ago that just because your 10 year old truck included a feature you like, don't assume the new one is the same...the new one is most likely very different (including the engine)...Example: GM 5.3L has changed a lot over the years. My 2016 Tundy is very different than my 2002 was...
  8. Feb 4, 2018 at 9:47 AM
    ToyotaTundraMike
    ToyotaTundraMike Not A New Member
    2015 Tundra
    Always lol at the ppl who make accounts here just to complain.
    These are minor issues dude go take it where you got it and have them look at it.
    Your gonna be severely disappointed if you think the grass is greener on the other side
  9. Feb 4, 2018 at 10:23 AM
    JBang
    JBang [OP] New Member
    jeff
    2018 Tundra
    Yes, back from the dealer again, 2nd time, same vibration, same buzzing from the dash, and still the window chatters when going up when wet.
    apparently the clunk is the ABS so that will never go away.
    I definitely will try a different dealer.
    going from an 02 to the 08 tundra was a huge upgrade, and now such a down grade with the 2018 - although I love all the technology!
    My 08 started to have starter issues, same old song from the dealer, couldn't observe the issue, I idled the truck for an hour and a half, fearing it won't start
    then lifter noise under load, metal shavings found in filter! which is when I went with the 2018.
    My next truck will most likely be a 2nd generation Tundra, just will have to find a diamond the the rough!
    NewImprovedRon likes this.
  10. Feb 4, 2018 at 12:47 PM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    Well thats unfortunate 16 TRD they did for me. Looks like you got it resolved. :thumbsup:
  11. Feb 4, 2018 at 8:53 PM
    71_340
    71_340 The German
    Hans
    FLW, MO
    And here I thought I am the only one who downloads the owner manual and reads most of it prior to picking up my new truck. And I also try to take extended test drives with at least two vehicles (went to two different dealers before buying my Tundra). I mostly did it to see if I can achieve sticker MPG after reading all the fuel consumption horror stories.
    ChucklesToy[QUOTED] likes this.
  12. Feb 5, 2018 at 12:42 AM
    easleycrawler
    Travis
    Easley, South Carolina
    2020 Limited DC 4X4 CEMENT
    SON OF A BITCH.
    Watt maker and ColoradoTJ like this.
  13. Feb 5, 2018 at 2:09 AM
    Auriarte02
    Auriarte02 New Member
    AJ
    2018 Sand Tundra TRD Limited
    ADS 2.5" Coilovers with Clickers ADS 2.5" Piggybacks MCM Uniball UCA's and Shackles Chrome Delete Coming soon to Color Match Quick Sand ( wrapped front bumper caps ) 2018 Honeycomb Platinum/Sport Grille on order ( Color Match bulge and surround) 35x12.5x20 Nitto Ridge Grapplers w/ KMC 20x9 Wheels +25MM offset
    i'm having a lot of issues with my head unit. It is always freezing and anytime i make a phone call it will turn black and restart. POS
  14. Feb 5, 2018 at 8:14 AM
    Laz1388
    Laz1388 New Member
    Laz
    South Florida
    2019 1794 MGM
    Windows tinted, Spray-on bed liner, Chrome Delete, Roll-N-Lock retractable cover, Painted fender flares, TRD PRO Suspension, Front and Rear TRD Sway bar, Magnaflow Exhaust, ReadyLift 6" lift, Bronze KMC XD Grenade wheels 20X9-18, Toyo Open Country R/T 37X12.5-20
    I had Similar Issues with my previous Tundra 2014 Limited, It took the dealer several software updates to cure the issue
    Auriarte02[QUOTED] likes this.
