Rough Country 30" lightbar
Discussion in 'Lighting' started by Patriot, Aug 3, 2017.
  1. Dec 20, 2017 at 6:14 AM
    #91
    Where ya live ? I'm from Harlingen Tx love me some SPI!!! Now I'm in Houston...just FYI... I was driving on Surfside on the beach had headlights high beams on fogs on at the time I also had a 42" behind grille also my RC 30" beach police said to turn off light bars I said I'm off road he said no that it was an extension of the highway..so I turned off..went on my way he went his so I turned back on he came back n gave a harsh warning to turn off
  2. Dec 20, 2017 at 6:32 AM
    #92
    rustynail11
    rustynail11 New Member
    Scott
    Mansfield,TX (DFW Area)
    2017 Grey Tundra TRD
    I am in Dallas and head down to Padre Island National Seashore (Corpus area) quite a bit. It is a haul but well worth it. Cops are right beach is considered highway in TX and same rules apply but at PINS they leave you alone as long as you aren't driving like an A$$hole or drunk. There are not towns or houses anywhere near there so it is a little different than Seaside. I have never had a problem running auxiliary lights and in the middle of the night you see several vehicles heading down the beach all lit up.
  3. Dec 26, 2017 at 4:04 PM
    #93
    easleycrawler
    Travis
    Easley, South Carolina
    17 Tundra SR5 DC Black 5.7
    I got my light last week. I cut the bottom out and got the mounts put on. My question is, do I use the 2 spacers that are in the bag with the Allen screws? The reason I ask, is I used one on the driver's side, the mount was really close to the light on the passenger side, do I spread the mount away from the light and put the spacer in? And I'm assuming, all that extra hardware is not used?
    geno0506 likes this.
  4. Dec 29, 2017 at 6:36 AM
    #94
    Stulloh
    Stulloh New Member
    Dallas
    18 Tundra TSS
    How bad was the install....I’m not real electrical astute
  5. Dec 29, 2017 at 6:44 AM
    #95
    Patriot
    Patriot [OP] Member
    Western NC, “Boondocks”
    It’s pretty easy and very basic. Already has an in-line switch relay. The only minor challenge is running it through the rubber gasket located on your firewall, the switch. I used a coat hanger, wrapped the wire with electrical tape and it slipped right through the rubber gasket with a little silicone sprayed on the wire before pulling it through to the interior of the truck. Then hook up your neg black ground wire to your battery and then your red pos, in this order.
    You can do it.:thumbsup:
    Stulloh[QUOTED] likes this.
  6. Jan 4, 2018 at 8:44 AM
    #96
    TTU19
    TTU19 Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
    This is still on my things to do list. I already have a switch to use in my dash, is it pretty easy to wire to that one?
  7. Jan 5, 2018 at 10:31 AM
    #97
    easleycrawler
    Travis
    My switch finally came in and I got it wired up.
  8. Jan 28, 2018 at 6:43 PM
    #98
    RW-3
    RW-3 May the Mods be with you
    Rob
    16 Black TRD CM 4x4
    Lights: 2018 OEM Black Chrome LED’s Morimoto XB Fogs Interior LED upgrade - VLED’s LED reverse / cargo - VLED’s Footwell lights, vanity lights, break lights, rear turn signals, 3rd break light - All VLED’s 30” Rough Country light bar hidden in bumper w/ Rago Fab Brackets Matt Gecko LED bed lights (red & white) and hood lights Exterior: Truxedo Lo Pro QT WeatherTech in-channel window deflectors Interior: Husky X-Act Contour front & rear Front, back and rear windows all tinted 10% Ceramic Heat Film on Windshield 70% OCD console organizer OCD console tray TRD 4x4 inserts on Husky mats by Achuop Tacoma TRD Pro shift knob with TRD leather boot AJT Design vent ring trim - chrome delete Center console wireless charger Drivers side grab handle Performance: Dirty Deeds BA Muffler 12” Budget Standard System TRD Rear Sway Bar AFE Pro Dry S Air Filter Bilstein 6112 1.9” clip Bilstein 5100 - rear Coachbuilder +1’s Nitto Ridge Grapplers 285/70/18 Audio: Infinity dash speakers Tech12Volts custom center dash speaker Hertz Uno door speakers JL Audio RD 900/5 amp 2 JL Audio 10w-0 v3 10” subs in custom Tech12Volts box Protection: McGuard Tailgate Anti theft lock OEM tailgate lock w/ Dynamat TRD Pro skid plate SNS ARB sensor guards Misc: TRD key fob case AJT Designs Rear diff breather mod Fortin remote start with Car Link CL6 TRD battery bracket by Coupe TRD valve stem caps TRD interior handle inserts by abomb60 (Adam)
    Got mine installed today! Put it behind the bumper with brackets from Rago fab. Couldn’t bring myself to take a saw to the bumper. Pics aren’t the best but here’s what I could get after the install ECBC0C8A-823D-4736-A7E8-6191281780EA.jpgAD87425F-D632-4F66-B69A-FE2D273124DB.jpg38FE1B65-54ED-4731-A1B6-6EEE871BBF42.jpgF703103D-7254-437D-AE9B-A7852BBC7D66.jpg
  9. Jan 28, 2018 at 7:15 PM
    #99
    easleycrawler
    Travis
    Wish I had of known about those mounts before I installed mine.
    RW-3[QUOTED] likes this.
  10. Jan 28, 2018 at 10:54 PM
    #100
    Patriot
    Patriot [OP] Member
    @RW-3 or @easleycrawler How much do you want for your RC light bar protective lens cover since you won’t be using it? I put the cover back on mine up when not in use to keep it clean. Send me a PM me if your interested in getting rid of it. :thumbsup:
  11. Jan 28, 2018 at 11:10 PM
    #101
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    I like the subtlety of it.
  12. Jan 28, 2018 at 11:51 PM
    #102
    easleycrawler
    Travis
    I'm gonna hold on to mine. But if I decide I'm never gonna use it, I'll let you know.
  13. Jan 29, 2018 at 3:04 AM
    #103
    Patriot
    Patriot [OP] Member
    Hey thanks neighbor, I appreciate it!
  14. Jan 29, 2018 at 6:10 PM
    #104
    easleycrawler
    Travis
    Well, I've had mine installed for about a month now and it's got a good bit of moisture in it. Guess I'll be contacting rough country tomorrow.
  15. Jan 29, 2018 at 6:40 PM
    #105
    RW-3
    Rob
    16 Black TRD CM 4x4
    Aw man, that is not cool at all!! Keep us posted on how they handle it.
  16. Jan 29, 2018 at 6:41 PM
    #106
    Really? Had mine almost yr and a half no issues
    Patriot[OP] likes this.
  17. Jan 29, 2018 at 7:14 PM
    #107
    easleycrawler
    Travis
    Yeah I was disappointed.
    I'll get some pics tomorrow.
  18. Jan 29, 2018 at 7:40 PM
    #108
    easleycrawler
    Travis
    I just dug through my deleted emails and found the order confirmation email. I replied back to it, describing my issue and asking what I need to do, to get a replacement. I'll keep this thread updated.
    RW-3 likes this.
  19. Jan 29, 2018 at 10:31 PM
    #109
    Patriot
    Patriot [OP] Member
    @easleycrawler - I bet they’ll replace it as long as your within the 3 yr warranty. :thumbsup: Thanks for keeping us posted!
  20. Jan 29, 2018 at 10:36 PM
    #110
    easleycrawler
    Travis
    I'm hoping so. I just bought it back in the middle of December.
  21. Jan 29, 2018 at 10:54 PM
    #111
    Patriot
    Patriot [OP] Member
    I’d follow up with a call as well, they should make it right, I bet they will. :thumbsup:
  22. Jan 30, 2018 at 5:09 AM
    #112
    easleycrawler
    Travis
    Here is the moisture.
  23. Jan 30, 2018 at 5:19 AM
    #113
    DaBoro54
    DaBoro54 Beach Fisher
    Leveling kit, 285/70R18 EXOs
    Wow. That’s a good amount
  24. Jan 30, 2018 at 5:59 AM
    #114
    Dejohnson8034
    Dejohnson8034 New Member
    Prosper, Texas
    2017 Tundra Limited
    I installed one this last Saturday; so far so good.
  25. Jan 30, 2018 at 6:45 AM
    #115
    Patriot
    Patriot [OP] Member
    Does it work? Have your turned it on to see if the moisture will clear or disapate? Just curious. None the less, I would call and request they send you a replacement. I can’t see how they won’t. Good luck, keep us posted.:thumbsup:
  26. Jan 30, 2018 at 5:18 PM
    #116
    RW-3
    Rob
    16 Black TRD CM 4x4
    Let’s see some pics!!
  27. Jan 30, 2018 at 6:06 PM
    #117
    easleycrawler
    Travis
    Yeah it works. I haven't left it on long enough to see if it would dry out though.
  28. Jan 30, 2018 at 9:29 PM
    #118
    Patriot
    Patriot [OP] Member
    Did you call hear back from R/C on replacement under warranty?
  29. Jan 30, 2018 at 10:40 PM
    #119
    easleycrawler
    Travis
    I sent the email, never got a response. So I called them. They said they received my email and are in the process of getting a resolution together. So we'll see.:notsure:
  30. Jan 31, 2018 at 12:03 PM
    #120
    easleycrawler
    Travis
    I got a response. They said there is a breather screw on the side. They said to take the screw out, run the light for a little bit and leave the screw out for a day or two and it should dry out. We'll see.
    aztundraguy likes this.
