Can 2018 headlights be adjusted?
Discussion in 'Lighting' started by Trevman2, Jan 3, 2018.
  1. Jan 3, 2018 at 6:45 PM
    Trevman2
    Trevman2 [OP] New Member
    I got my headlights swapped out but I don't like the offset between them and the adjustment from the interior only does so much. Is there a way to adjust them like old school headlights?
    First pic is low beam and second is high:
  2. Jan 4, 2018 at 7:28 AM
    iHacker
    iHacker SW TRD PRO
    TRD PRO Super White CM
    2019 TRD PRO LED Headlights, 2019 TRD PRO Rigid LED Fog lights, All LED Interior, LED Cargo Lights, Bed LED Lights, Undercover Flex, Husky Weather beater floormats, FORTIN EVO ONE remote start, TDR Cold Air Intake, Tundra tail gate inserts, Pop & Lock...
    They have leveling gear same as your old halogens, just level them to 0 in the in cab switch, then follow the next process
    Here a great video As reference to aim them correctly
    https://youtu.be/GWvSWBlAwnI
  3. Jan 4, 2018 at 9:00 AM
    dsimonl
    dsimonl New Member
    2017 Tundra DC Limited MGM
    Amp Research Powersteps and Bedstep, 2018 LED headlights, LineX Platinum, Baja Designs fog lights, Driver side grab handle, SwingCase
    Confirmed the above instructions. I installed the 2018 LEDs and adjusted with just a long phillips screwdriver as above. My passenger side ended up a few inches higher when the high beams were level.
    geno0506 and iHacker like this.
  4. Jan 4, 2018 at 10:58 AM
    MGMTundra251
    MGMTundra251 New Member
    2020 Platinum 4x4 MGM
    can it be adjusted side-to-side?
  5. Jan 4, 2018 at 11:00 AM
    iHacker
    iHacker SW TRD PRO
    I guess not from the outside of headlight housing, just UP and DOWN
  6. Jan 4, 2018 at 11:18 AM
    MGMTundra251
    I thought so, but had to ask
  7. Jan 4, 2018 at 3:13 PM
    Triton19X2
    Triton19X2 New Member
    2021 Silver 1794 Crewmax 4X4
    Mine came out fine...didnt you just get it back from hitting a deer?? There may be some slight damage from that still lingering that was not able to be seen by the body shop....Just a thought
  8. Jan 6, 2018 at 9:55 AM
    Trevman2
    Yes i did. Im gonna try iHackers adjustment recommendation above first to see what i get.
  9. Jan 7, 2018 at 5:00 PM
    JeremyGSU
    JeremyGSU New Member
    Jeremy
    2016 Tundra
    I just put my '18 headlights on my '16. My drivers light was way lower than my passenger. I adjusted mine to about your offset. Really, the drivers side is supposed to be lower than the passenger to not blind on-coming drivers.
    To adjust them you can also use a 1/4 wrench. I couldn't fit a flat head in the gear level as easy to adjust them.
    1_thirsty_tundra likes this.
  10. Jan 8, 2018 at 7:59 AM
    MGMTundra251
    Do you have a pic of the metal cap? My lights are already installed and I cannot see it. Thanks.
  11. Jan 8, 2018 at 8:50 PM
    iHacker
    iHacker SW TRD PRO
    Thanks for the input on this I really never took enough time to play around with the headlight assembly, I was so exited to install them right after boxes arrived, I never noticed the mentioned cap, and now I’m too lazy to take the front end of my truck again man I removed everything hundreds of times, now just waiting to see what the internal inspection you’re doing bring for us, possibly LED DRL switchbacks, color changing modules, power increase for the Hi Lo beams? Or in the best place a full Morimoto M-LED Projector retrofit let me tell you I’m very exited now. Keep up the good job as everything coming from Morimoto and Retrofit Source
  12. Jan 8, 2018 at 9:00 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Where is the L-R adj ok 18 leds?
    MGMTundra251 likes this.
  13. Jan 9, 2018 at 10:47 AM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    :worthless:
  14. Jan 9, 2018 at 11:28 AM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Thank you! Is it a 10mm bolt?
  15. Jan 9, 2018 at 11:37 AM
    MGMTundra251
    Do you have to remove the light or battery to access this bolt once it is installed?
  16. Apr 16, 2018 at 4:53 AM
    etco2thomas
    etco2thomas New Member
    ‘17 Tundra CM SR5
    Borla exhaust 20” RC LED light bar Bull bar
    Can someone post of a pic of the light not installed, where you can adjust the up/down level of the headlights?
  17. Apr 17, 2018 at 11:07 PM
    geno0506
    geno0506 New Member
    Michael
    When I adjust my 2018's, I adjust with only the low beams, correct?
  18. Apr 25, 2018 at 7:34 PM
    Y0TA PR0
    Y0TA PR0 Dirt biking & fishing
    Rafael
    2017 TRD PRO
    WELCOME!
  19. Apr 26, 2018 at 5:58 AM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    It's the white knob in the center (not the yellow circle) that you turn clock/counterclockwise before closing it up. Or if after installation, you access it from the top using a Phillips screwdriver through the funnel/tunnel as shown above the knob.
    Newm likes this.
  20. Dec 14, 2018 at 3:16 PM
    Cthulhu
    My driver’s side headlight was high...fixed it in about 2 minutes. Super easy, barely an inconvenience!! ;)
