Glass breakage sensor install and setup
Discussion in '2.5 Gen Tundras (2014-2021)' started by Sting Ray, Dec 30, 2017.
  1. Dec 30, 2017 at 2:24 PM
    Sting Ray
    Sting Ray [OP] New Member
    Ray
    Vegas
    2017 SR5 Crewmax
    Not enough space here...
    I have a 2017 SR5 Crewmax. It has the factory alarm installed and I activated it with techstream (since the dealer wanted like $500 to do it). I pulled off this panel when I installed my NSV lightbar and found this wiring harness not plugged into anything. A few people have told me it goes to the glass breakage sensor (which I don't have installed on my truck) I'm told it acts as some sort of microphone of sorts so if someone smashes a window it sets off the alarm?
    My question is can I just install the glass breakage sensor, set it up with techstream?, and call it a day? Or is there more to it then that?
    avssuc and Mountun Goat like this.
  2. Dec 30, 2017 at 2:44 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    I believe that’s all you need to do.
    Skippy and Sting Ray[OP] like this.
  3. Dec 31, 2017 at 6:56 PM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    Bump...nobody has done this?
  4. Dec 31, 2017 at 7:14 PM
    SoCalDave
    SoCalDave New Member
    Dave
    2016 DC 4x4
    If I remember correctly, you install the sensor, module and hood sensor bypass(unless you're installing it).
    Sting Ray[OP] likes this.
  5. Dec 31, 2017 at 7:17 PM
    trainracer
    trainracer New Member
  6. Dec 31, 2017 at 8:17 PM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
  7. Dec 31, 2017 at 8:18 PM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    Have you done it?
  8. Dec 31, 2017 at 9:23 PM
    trainracer
    the gbs came with the gbs ecu
    Sting Ray[QUOTED][OP] likes this.
  9. Dec 31, 2017 at 9:42 PM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    Awesome! Curious when you tap on the window with the key for the ops check, it really sets it off just by doing that?
  10. Dec 31, 2017 at 9:45 PM
    trainracer
    yes I have mine set to 9 and dirt bikes next to my truck will set off the alarm
  11. Dec 31, 2017 at 9:47 PM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    lol I'm
    In the Air Force so having it set that high would mean my battery would die every day from all the jets taking off lol.
    BamaMan44 and NewImprovedRon like this.
  12. Dec 31, 2017 at 10:57 PM
    SoCalDave
    Dave
    2016 DC 4x4
    Yeah, about a year ago so not too fresh. Think the module goes under the driver side dash.
    Keys tapping on the glass will set it off.
  13. Dec 31, 2017 at 11:33 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    what is the factory alarm? didn't know that was even a option.
  14. Jan 1, 2018 at 7:20 AM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    Your truck probably has it installed but usually the dealer charger to activate it. If you have techstream and an obd cable you can do it yourself.
    bulldog93 likes this.
  15. Jan 1, 2018 at 8:33 AM
    Les7311
    Les7311 Look up, what do you see
    2008 Blue Tundra TRD 4x4
    Scribed to this.....
  16. Jan 1, 2018 at 8:38 AM
    Stulloh
    Stulloh New Member
    Dallas
    18 Tundra TSS
    So ....you are saying it’s already there ...I just need to activate?
  17. Jan 1, 2018 at 10:39 AM
    Stulloh
    Stulloh New Member
    Dallas
    18 Tundra TSS
    So I ran outside ...jumped in, locked it , sat there for a minute , got a red / lock icon on gauges, opened door.....nada
  18. Jan 1, 2018 at 10:47 AM
    classic17
    classic17 New Member
    2017 SR5 4X4
    If the Tundra is like other Toyota models, the Toyota RS3200 plus and Glass Breakage Sensor kit (PT398-34142) will install both the alarm and the gbs on your truck. But you will need a techstream or have the dealer to turn the alarm on.
    This kit will also install the gbs on trucks that already have the alarm. You do not need to turn anything on, just plug-n-play. Again, if it's like other models. And I would be surprised if it's different.
    The reason I'm saying other models is because I've installed these kits in the Highlander and Sienna.
  19. Jan 1, 2018 at 3:31 PM
    tacomawv
    tacomawv New Member
    Richard
    So a 2014 SR has an alarm and it just needs to be activated. I am going to have to look into this.
  20. Jan 1, 2018 at 5:28 PM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
  21. Jan 1, 2018 at 7:56 PM
    Danimal86
    Daniel
    Sacramento, CA
    Thanks guys! I had no idea there was even an option for one. I think i have an old obdII to usb cable sitting around somewhere. Where can i get a copy of techstream? Last time i tried to use techstream was trying to program a key on a toyota matrix. It was a pain in the ass. Stupid software would only run on 32bit OS. Still the same?
  22. Jan 1, 2018 at 8:53 PM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    You can find pirated copies online for free. I didn't want to deal with viruses and all that crap. I bought the latest version off eBay with a cable for $50. Works like a champ.
    619Tundra likes this.
  23. Jan 2, 2018 at 8:06 AM
    Al92toyo
    Al92toyo New Member
    Alex
    2018 White Tundra Crew Max Platinum 4x4
    I just ordered an '18 CM Platinum. Do you know if there is an updated Techstream version out there for the 18s yet that I can pick up? I'd like to do this same mod to mine.
  24. Jan 2, 2018 at 4:01 PM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    Just pick up the latest version. 12.30.017 this is the one I bought. IMG_6025.jpg
  25. Jan 2, 2018 at 4:06 PM
    Al92toyo
    Al92toyo New Member
    Alex
    Sweet, I'll have to pick one up. You have an '18?
  26. Jan 2, 2018 at 5:01 PM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    17, but it's all the same.
  27. Jan 2, 2018 at 5:11 PM
    ldale
    ldale New Member
    Txk Tx
    17' Limited Silver Sky Metalic
    Tonno Pro LowPro , TRD Sway Bar, Helwig Leaf Pack
    Just bought one also......side note offered $40 and it was accepted.
  28. Jan 2, 2018 at 5:11 PM
    ldale
    ldale New Member
    Txk Tx
    Thanks for the heads up.
  29. Jan 4, 2018 at 2:33 PM
    tacomawv
    tacomawv New Member
    Richard
    Does the truck have to have the engine immobilizer option. How do you tell if you have that. I have a 14 SR with a 4.6.
  30. Jan 8, 2018 at 3:12 PM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    Got my gbs in the mail today. Probably won't have time to install until the weekend.
    @trainracer do you have a pic of where you mounted the ecu? The pics in the directions are not the best.
    froggy78 likes this.
