Dash Noise
Discussion in '2nd Gen Tundras (2007-2013)' started by bakersTRD, Nov 25, 2014.
  1. Nov 25, 2014 at 4:32 PM
    bakersTRD
    bakersTRD [OP] New Member
    Rich
    Latrobe, Pa
    2012 Barcelona Red Tundra DC 4x4
    Weather Tech floor mats, Trifecta bed cover, BedRug bedliner, factory bug shield, side steps, Rock Warrior shift knob, Pro Comp Prorunner SS leveling kit and rear shocks
    I recently started hearing a noise coming from the dash. It sounds like a "cracking" or plastic hitting against something. It seems to happen when the truck is cold and the outside temp is cold as well. Any ideas as to what it may be?
  2. Nov 25, 2014 at 7:39 PM
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    Yes, its a tab thats touching your windshield.When it gets cold that rubber and plastic in the dash and outside gets cold and creeks like crazy. Mine does it when it gets cold and is quiet when its not. There is athread about how to fix it somewhere but it involves taking out the outside part of the dash.
  3. Nov 25, 2014 at 9:42 PM
    T-Rex266 Moderator Staff Member
    My current, and last Tundra did that too...annoying? Sure..but this cold is only temporary so I just ignore it and turn up the music
    ODSteve likes this.
  4. Nov 26, 2014 at 3:12 PM
    bakersTRD
    Rich
    Latrobe, Pa
    Well, now I know it's not just mine that's making the noise. Thanks for the info.
    T-Rex266 and ODSteve like this.
  5. Nov 27, 2014 at 7:59 PM
    bakersTRD
    Rich
    Latrobe, Pa
    I think I found the service bulletin for the dash fix.
  6. Nov 28, 2014 at 9:27 AM
    Only applies to 03-07 though...
  7. Nov 28, 2014 at 6:13 PM
    bakersTRD
    Rich
    Latrobe, Pa
    Yeah, wasn't sure if it would apply to the 2nd gen Tundra because it said it covered the 07
  8. Nov 28, 2014 at 8:31 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    After you posted this i noticed some noise. It isn't that bad though. If it gets worse i might do something, but not now.
  9. Nov 29, 2014 at 5:47 PM
    bakersTRD
    Rich
    Latrobe, Pa
    Had the truck out today. Temp was in mid 50's. There was a little noise, but not as bad as the other day when temp was in the 30's
  10. Dec 3, 2014 at 6:47 PM
    TEXASTUNDRA
    TEXASTUNDRA Formerly 06BLUEDBLSPORT
    Rockwall Texas
    2012 Tundra SR5 DC 4x4 5.7 FFV Silver Sky Metallic
    Volant Cold Air Intake, Flowmaster True Dual 40 Series, Raptor series side steps, Tow Mirrors, 8K HIDs, Interior lights and Bed Lamp LEDs, MB TKO rims, OME 613 Shocks and Coils, Bilstein 5100 Rear Shocks and TOYTEC AAL, Fearless Fabrication Front Bumper
    My truck hasn't done it in the past but recently since it has gotten cold in Lubbock I too am hearing the same noise. Sure I hate it but what can you do, stuff will shrink and expand with climate changes
  11. Dec 24, 2014 at 10:59 AM
    rebmo
    rebmo 2020 Crewmax Limited 4wd Silver/Black
    Rural SE Wisconsin
    2020 CM LImited 5.7L V8 4WD
    Is it sagging too? They start to sag on the right side up near the windshield pillar.
  12. Nov 6, 2015 at 10:01 PM
    csuviper
    Broomfield, CO
    Ok I'm bringing this up again because the noise is very bad since it got cold this week. Here is a clip where I held the phone up near the window.
    https://youtu.be/Xnbt1BRIh4k
  13. Nov 6, 2015 at 10:02 PM
    csuviper
    Broomfield, CO
    I will be investigating ways to eliminate the noise and report back
  14. Dec 22, 2015 at 10:09 PM
    swede78
    swede78 Not so new member
    Lars
    westminster co
    2019 tundra platinum mgm crew max
    Nothing yet
    i found my interior noise, kind of like a bird chirping. it was the outside trim where the wipers arms attach, the trim was rubbing along the bottom side of the window. for a quick fix i taped it down with electrical tape, have not heard the noise for about a week now.
  15. Dec 22, 2015 at 10:43 PM
    csuviper
    Broomfield, CO
    My cold weather noise mysteriously disappeared without me doing anything. Even in the very cold of this last storm it was fine.
    Do you have pics of how you taped them?
  16. Dec 23, 2015 at 7:39 AM
    Grizzly660
    Grizzly660 21 Army Green Sport
    North Dakota
    2021 Army Green Sport
    20 inch XD Hoss wheels with Nitto EXO Grappler Wetokole seat covers
    My 15 crewmax makes a creeking noise to the center console area as well as up by the Windshield on the passenger side. And it's cold here in North Dakota. Turning the radio up only works for so long.
  17. Dec 28, 2015 at 3:10 PM
    Dwell
    Dwell New Member
    Would you happen to have a pic of where you taped? My 07 Tundra makes the noise when cold outside. Thanks
  18. Jan 12, 2016 at 6:13 AM
    JMACK
    JMACK New Member
    My 2015 just started some kind of noise like this as well. This is the coldest we've had since I got it. Mine almost sounds like it's some kind of heater door or something I can count the amount of times it slaps, 4, like it's back and forth. After that it's good. Strange.
  19. Nov 4, 2018 at 4:01 AM
    wwolvverine
    wwolvverine New Member
    2018 Tundra 1794
    I have the same snapping noise coming from windshield. I have seen the wiper cowel solution and it seems legit fix. But my noise is coming from upper windshield more to corner of pillar and grip handle. I certainly do not want to take headliner out by myself. Really p-ssed off Toyota does not solve this problem since it has been going on for so long. Practically all toyota forums complain about this.
  20. Nov 9, 2018 at 8:39 AM
    Slick McFavorite
    Slick McFavorite New Member
    Tyler
    2014 White Tundra Platinum
    My 14 platinum (got it this summer) is doing this. First day I've driven it under 40F weather. Crackling just like in that video csuviper posted. It was a very consistently crackling as the truck was warming up on my way to work, until I hit a couple of steel construction work plates in the road. Jarred the truck pretty good as you would expect and every single crackle stopped immediately. Didn't fade away, it just stopped. We'll see what happens tomorrow morning when I take it out cold again.
  21. Nov 24, 2018 at 7:06 AM
    Kyleoconnor22
    Kyleoconnor22 New Member
    Kyle
    2010 Black Tundra CrewMax
    My 2010 Crewmax makes this noise all year round, I found online it could be the rubber gasket between the ECM and the firewall.
  22. Nov 24, 2018 at 7:38 AM
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    Bak Revolver, BedRug, Undercover Swingcase, PopLock, Bilstein 5160(rear), Firestone RideRite, TRD rear sway bar, Coachbuilder +2 rear shackles, Andersen 5” aluminum adjustable hitch, TRD dual exhaust, VLEDS interior leds including the footwell kit, TundraTex FRAC mod, VLEDS LPR backup tag mount led, Husky X-Act mats, Color matched cup holder bezel (silver), Ceramic 20% tint all around, 50% Ceramic windshield, Color Matched door handles & mirror caps, The “Stubby” antenna, AMP Research steps, VLEDS 6”step lights, ToyTec/5100 Bilstein coil overs, 700lbs red ToyTec springs (2.75” lift), 20x9 +18 Method 306 custom painted and custom fit center caps, Gorilla spline lugs, Bridgestone Revo 3s 285/60R20, TRD skid plate, RaptorLiner “Red” tow hooks, 19 Pro black LED headlights, VLEDS Triton V6 turns, Rigid SAE D series fog lamps, 19 TRD hood scoop, 2019 TRD Pro grille, Coachbuilder bumper shims, X-Pel protect under mud guards, Opti Coat Ceramic, Opti Coat Sealed. And some snakes and sparklers, because they are my favorite!
    It’s probably the clips that hold the windshield in place while the urethan dries. It’s really not hard to fix, but you do have to drop the front of the headliner down.
  23. Nov 24, 2018 at 7:43 AM
    Dswenson3423
    Dswenson3423 New Member
    Derrick
    Loudon, TN
    2018 Quicksand CM SR5
    I was about to post about a buzzing noise in the cab. Seems to be on the passenger side when I give it gas, it when coasting. 2018 CM SR5 with 5k miles. It’s super annoying. Taking it in this week for an oil change and recall. Also gonna see if they can find the problem because I can’t.
  24. Nov 29, 2018 at 7:40 PM
    Bmxrider1331
    Bmxrider1331 New Member
    Brendan
    NEW JERSEY
    2013 tundra 4x4 4.6....
    3 inch toytec eibach kit on 35s
    When my trucks off my vents or somthing in my dash groans. And when I leave my vents on a certain one they fold back to a position when trucks off. I find it funny LOL kinda annoying tho but whatever
  25. Nov 30, 2018 at 6:04 AM
    Dswenson3423
    Derrick
    Loudon, TN
    At the dealer now. They are saying it’s the intake and it’s normal. Said it’s nothing to worry about. They don’t know if there is a fix so I sent him back to figure out a fix for it. It’s annoying as hell to hear a buzzing noise every time you give it gas. I think they are full of shit.
    wwolvverine likes this.
  26. Nov 30, 2018 at 6:12 AM
    Dswenson3423
    Derrick
    Loudon, TN
    I’m fairly new to Toyota and just bought this truck in July. So is a buzzing noise in the dash a common characteristic in these trucks? Not something I would expect from a truck with 5k miles on it.
  27. Nov 30, 2018 at 8:06 AM
    Bmxrider1331
    Brendan
    NEW JERSEY
    Mine sounds like that too. I have a 2013
  28. Dec 16, 2018 at 12:11 PM
    Slick McFavorite
    Tyler
    Anybody know what these clips on the underside of the hood are? I took pictures of them with the hood closed, but if you open it and flick them they make a noise that I would imagine might be heard from the inside of the truck. Potential culprit perhaps?
  29. Dec 18, 2018 at 8:12 AM
    TTCrewmax
    TTCrewmax New Member
    Windshield wiper fluid nozzles. Could be.
  30. Dec 18, 2018 at 9:00 AM
    Slick McFavorite
    Tyler
    Well that was the easiest test ever lol. You're right. I'm going to tape those suckers down and see what happens.
