Wheel well rivits.
Discussion in 'General Tundra Discussion' started by smooosh, Nov 24, 2017.
  1. Nov 24, 2017 at 1:35 PM
    smooosh
    smooosh [OP] This place costs me too much $
    2018 TRD Offroad Limited Crewmax.
    Ongoing project
    Does anyone know how to get these rivits out of the wheel well so I can remove the cover and get to the bottom of the bed rails? I got a couple out by reaching around and pinching them but most I will not be able to reach that way. I tried using a panel tool but it’s not pushing the tabs in enough.
  2. Nov 25, 2017 at 4:24 AM
    whiteTRD'02
    whiteTRD'02 New Member
    Smoooch, looks like the center piece with the odd shaped hole, unscrews from the outer part. If so, leave a couple threads in the hole and pull. I don't have your model, so I'm guessing.
  3. Nov 25, 2017 at 5:41 AM
    smooosh
    Ongoing project
    Thanks for the guess. It doesn’t. I should have take a picture of one of the grommets that I did remove by reaching my hand around back. I’m going to swing by Toyota today and ask them or buy some more so I can break them.
  4. Nov 25, 2017 at 5:49 AM
    whiteTRD'02
    Hang tight! Before you break 'em, someone here might know. At least your thread gets bumped.
  5. Nov 25, 2017 at 6:13 AM
    whiteTRD'02
    Anyways, you've got to get the center pin out
  6. Nov 25, 2017 at 6:23 AM
    You should be able to take a small flat head and get around the exterior circle by popping it up.
    whiteTRD'02 likes this.
  7. Nov 25, 2017 at 7:12 AM
    smooosh
    Ongoing project
    Here are some pitctures of the gromit. It has 2 tabs on the side that are easy to push it from the back but you can’t get to the back of most of them to push them in.
  8. Nov 25, 2017 at 7:25 AM
    whiteTRD'02
    Looks like sean266 is right!! Try prying it out.
  9. Nov 25, 2017 at 7:27 AM
    Theyfzman
    Theyfzman New Member
    Pa
    08 TRD
    They are pretty much one time use clips any auto body supply place should have them take one with you auveco is who makes replacements. Don’t go to toyo they They ridiculously over priced. A box from the AB store will be roughly $11-13 bucks for a box of 25. They charge like $2.50 a clip at toyo
    smooosh[OP] likes this.
  10. Nov 25, 2017 at 7:28 AM
    Theyfzman
    Pa
    08 TRD
    Take a razor knife and slice off the head and the rest pops out the other side
    Wynnded and smooosh[OP] like this.
