Chris' 1794 Build
Discussion in '2.5 Gen Builds (2014-2021)' started by Cfincke, Jan 8, 2017.
  1. Oct 14, 2017 at 8:28 PM
    blue16
    blue16 New Member
    steve
    Mesa AZ
    2016 tundra
    Your truck is sweet. Great job
    Cfincke[OP] likes this.
  2. Oct 14, 2017 at 8:45 PM
    Cfincke
    Cfincke [OP] Mall Crawler but capable
    San Antonio
    2014 Tundra 1794 CM 5.7 4x4 sunset bronze
    5.29s, Auburn LSD, 37x12.50R18, Icon coilovers and shocks, SPC UCA's, Tech 12 Volts sound system, Enve Grill
    It is a single row light bar, got the bar and the mounting brackets from Rago Fabrications.
    Here is a photo with the fogs, low beams and the 30" bar all on.
    BlueBottle[QUOTED] likes this.
  3. Oct 14, 2017 at 8:45 PM
    Cfincke
    San Antonio
    Thanks
    blue16[QUOTED] likes this.
  4. Oct 14, 2017 at 9:46 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Wow that thing is bright. Which light is that on their site?
  5. Oct 15, 2017 at 6:45 AM
    Cfincke
    San Antonio
    It is their Freedom 32" light bar. I bought it with the brackets.
  6. Nov 18, 2017 at 8:28 AM
    Cfincke
    San Antonio
    After many hours of installing dynamat on the inner and outer door skins, back wall and the floor, I spent a whole day running all the cabling, wiring up the JBL harness, installing all the speakers and amps. Tech12volts put together a great JL speaker package at a great price that sounds great. He answered dozens and dozens of emails I sent him all most instantly. I picked up the subs, box and JL HD amp up locally from @1UPPER. From tech12volts I picked up the JL Fix86 with remote, RX400/4 amp, C5 speakers for the front, C2 speakers for the rear, JBL harness and the speaker adapters.
    I used 28 sheets of dynamat (101sf), have 4 sheets left from 3.5 bulk boxes I started with, 1 sheet of 1/4" dynaliner that I quartered and installed directly behind the speakers. Since my truck is also my daily driver I had to do things in stages so I could reassemble everything to drive to work. The doors took about 12 hours to dynamat inside and out using 14 sheets (51sf). I would say I achieved 90-95% coverage on the inner door skin, just cannot reach into some of the tight areas and 98-99% coverage on the door panel face. Just dynamatting helped improve the sound of the factory JBL speakers a lot, then when I installed the JL speakers I was floored by the sound difference.
    Toyotoholic likes this.
  7. Jan 1, 2018 at 2:56 PM
    Stulloh
    Stulloh New Member
    Dallas
    18 Tundra TSS
    Sweet ride
  8. Feb 21, 2018 at 7:28 PM
    Cfincke
    San Antonio
    Back in December I picked up a Magnum bumper locally and replaced my grey and chrome factory bumper. I got a great deal on it since it did not have the angle hoop that most people get.
    Had to trim an inch off of the front edge of the TRD pro skid plate as it was interfering with the bumper mounting bracket. The front center part of the skid is sandwiched between the frame and bumper bracket, plus the 2 bolt on each side at the tow hooks. I moved my Baja Design fogs over to the new bumper20171224_151158.jpg
    Coolhardy and Baja Designs like this.
  9. Feb 21, 2018 at 7:39 PM
    Cfincke
    San Antonio
    When I bought the bumper, they gave me a deal to where it was only $25 for a 36" light bar. I thru the light bar on the top of the bumper before a camping trip to Lost Maples state park. I wanted to see how I liked the location of the bar and I knew I would need it for the trip.
    Side profile of the light bar
    Set up at the camp site with my brother in law and family
    Did some hiking to see Monkey rock
  10. Feb 21, 2018 at 7:40 PM
    Aurora CO
    That pic with the rocks. The one rock looks like it's laughing at a new Titan.
    Cfincke[QUOTED][OP] likes this.
  11. Feb 21, 2018 at 7:46 PM
    Cfincke
    San Antonio
    January 10th
    A local detailing company was running a group buy for local Tundra Crew members, so I jumped on it and got the paint correction and R1 ceramic coating. 3 people work on my truck for over 5 hours, they cleaned the engine bay and interior as well. Truck looked better than it ever has. Almost 6 weeks later the engine bay is still shiny and very clean.
    Civiceg94 and Black Wolf like this.
  12. Feb 21, 2018 at 7:49 PM
    Aurora CO
    NICE^^^^^^^
  13. Feb 21, 2018 at 7:55 PM
    Cfincke
    San Antonio
    Coolhardy, Black Wolf and 1UPPER like this.
  14. Feb 21, 2018 at 8:04 PM
    Cfincke
    San Antonio
    Met up with the Austin crew in Lockheart for some BBQ.
    Inferno, white, and blue trucks with the Pro comp fender flares color matched
    SATX_ProRunner likes this.
  15. Feb 21, 2018 at 8:35 PM
    Cfincke
    San Antonio
    Back in early January I started working on a custom grille by Enve Grilles.
    Teaser photo he posted of my grille
    On February 16th it showed up and I could not wait to leave work and install it
    This thing was packaged extremely well, took half an hour to get thru the packaging paper,, tape and 4 separate layers of bubble wrap. I literally filled up both my recycle bins.
    The install requires cutting the center section out and leaving just a little bit of the center section. My plan was to remove the center cention from the painted surround. But after an hour of trying and messaging @1UPPER for advise, I said screw it in cut it with the surround still on.
    I hate these clips!
    After 20 minutes of cutting with the dremel and setting off the smoke detector in my office (garage work bench was full) I was ready to mount the grille to the surround. Phone died, so no assembly photos.
    Having the separate Bussmann fuse and relay box wired ready to easily add accessories I was able to make 2 quick wire harnesses to connect to the lights and install a switch. I immediately drove to the sunlight part of my neighborhood park to see the light output. The grille amber lights are not bright, so I may replace those one day with some more Baja Designs, but they are aesthetic lights Right now.
    When I ordered the switch for the grille pods I ordered a few more switches for future mods....
    Coolhardy and 1UPPER like this.
  16. Feb 21, 2018 at 8:45 PM
    Cfincke
    San Antonio
    Also in January I had worked with Keith @dirtydeeds to do the first ever group buy on the TRD replacement system. On February 8th this large 50+ pound box showed up at work. I had ordered the stainless steel setup with 20" mufflers and dumps. I went with dumps so there was not a tailpipe near the spare tire area so I could eventually mount a full size spare under there. The exhaust took about an hour to swap out.
    Coolhardy likes this.
  17. Feb 21, 2018 at 8:55 PM
    Cfincke
    San Antonio
    February 10th, my wife and i bought a 26 foot Jayco 264BH camper for a great price. now we are planing our Road trip to the west this time. Right now it looks like it will be to denver area, salt lake city Utah and to phoenix. Little does the wife know, there are truck stores along the route (toytec and SDHQ)
  18. Feb 22, 2018 at 4:56 AM
    inferno_pro_satx
    inferno_pro_satx New Member
    Roger
    2016 Tundra TRD Pro
    Awesome build Chris
  19. Feb 22, 2018 at 5:03 AM
    Aurora CO
    Really liking that GT...
  20. Mar 8, 2018 at 8:43 AM
    #50
    diaz24
    diaz24 New Member
    What part of Texas?
    I've been looking a Tundra Club.
  21. Mar 8, 2018 at 9:13 AM
    #51
    Cfincke
    San Antonio
    I am in the San Antonio area, we have good size group with several members on this forum also. If you are in a different city, Austin, Houston, DFW, corpus Christi all also have Tundra Crew groups on Facebook. The Texas take over was in Boerne TX
  22. Mar 17, 2018 at 7:31 AM
    #52
    supermotobobby
    supermotobobby New Member
    Bobby
    2010 Tundra C/M Limited 4x2
    How did you wire the FIX86? Do you have pics of that install?
  23. Mar 17, 2018 at 8:11 PM
    #53
    Cfincke
    San Antonio
    Installed the fix86 after the factory amp, grabbing the speaker outputs of the amp to the inputs on the fix. Then from the fix to the aftermarket amps. I used a wire harness from tech12volts so I did not have to cut any wires
  24. Mar 17, 2018 at 8:18 PM
    #54
    Cfincke
    San Antonio
    Had to replace the factory battery this week. Got a deal on an Odyssey battery
    Finally received my 16 piece RGBW rock lights. I hooked them all up and bench tested them before I mounted them all.
    Mounted 2 lights the other night in the rear wheel well and tested them out
  25. Mar 19, 2018 at 7:25 PM
    #55
    Cfincke
    San Antonio
    Have 14 RGBW lights installed so far, have 2 left to install (may need more). Still have to run the cables thru a grommet in the floor and to the control box and connect power, but after 3 nights of mounting lights and trying to keep the cabling neat, I was able to test the lights with my NOCO jump starter.IMG_20180319_211925.jpg20180319_204910.jpg
  26. Mar 21, 2018 at 7:58 PM
    #56
    Cfincke
    San Antonio
    Took the camper out for its maiden voyage back on March 3rd. Did a short trip up to Kerrville and Ingram TX to see how the truck handles and what the mileage would be. Kerrville is about 90 miles away and was mostly all highway to get there. Pulling the trailer I was driving between 60-65 MPH, did not want to push it or risk having an accident. I-10 does have a bunch of up and down gradual hills, the truck downshifted to 4th to climb the hills. On occasion it would drop down to 3rd gear and be at 4000-4200RPM to maintain speed going up the hills. I did not want to push the truck harder than that and in 3rd gear I would be down to 55-60MPH. Re-gearing to 4.88s and an LSD is now in the on my list of wants. For the 180 miles of driving we did that weekend, I got 8MPG. The 26 gallon tank was on 'E' for 15-20 miles there at the end.
    Visited the mini Stonehenge in Ingram
    2OQiDe5FIbyBARZMPO0nzDJlg_n8ZvYhN-VEKiMl_33a3e4a8f376dd01a1d5c43d2de8cf0df7979a58.jpg
    FkdFSJvAlBhGicpyNIwrUfSETNRuCT7DmbnaOrOB_6a010e9093d4a3f00166e596bf0b0e2eaa9444e4.jpg
    -oaEGHD9Lnu1omaQWNFsabFzTg1efyr94LNT7y6k_e7978483cc559988261e8c96cdd5a753777e9cb7.jpg
    This one decided to jump in the cold lake and swim
    AMSbMWEpikc_74mmo-klVn2_p4sD9sTPUamesKuU_8d7d90715cdea198a056febb8a5540f94b516bc3.jpg
  27. Apr 22, 2018 at 6:39 PM
    #57
    Cfincke
    San Antonio
    Got a few things done today:
    Mounted my new aluminum mounting plate I designed for a Bussmann RTMR waterproof fuse and relay box. This replaces the sheet metal one I made last year. I bought the RTMR from a tacomaworld member last year, it uses 100% waterproof automotive grade quick-connects rated at 30 Amps each. I mounted an 80A circuit breaker, grounding bar, heat shrink on all ring terminals. All wired with automotive GXL wire.
    Also while I had the grille off to do the install, I also installed some LED headlights I got in a trade a few months ago. Will see how I like them in the morning.
    d0zer, Sas, Coolhardy and 1 other person like this.
  28. Apr 28, 2018 at 4:21 AM
    #58
    Cfincke
    San Antonio
    Did a few photo ops last night in Pigeon forge.
  29. Apr 29, 2018 at 9:59 AM
    #59
    Cfincke
    San Antonio
    2018 Tundra Crew Tennessee takeover.
    Skippy likes this.
  30. Apr 30, 2018 at 10:51 AM
    #60
    Cfincke
    San Antonio
    Photo Dump from Tennessee Takeover
    31444782_10215545083638191_6144665403781_6acc980793227e790a672f80f53c1b415fee8628.jpg
    31466739_10215545084118203_5604409838508_aaa3a588c93cb7a462c64fe2e7aab5d5803eb7a8.jpg
    31417003_10215545084718218_6481619705709_ad631054c4ca27e0b1e6681a9540e875952779c7.jpg
    31562309_10215545085278232_3350261214583_b2fa403fd5f8755dae132e0d12c71e6426a4dfb9.jpg
    31466945_10215545086478262_7926437405479_1f972454f2262df43e91c4262002f7440b734be1.jpg
    31453751_10215545087238281_8063046652874_6b3b9b8a18224b374252564b7d8792e8d3865e5d.jpg
    31453804_10215545087518288_7363715587836_6151f2200180eee449c0ce95ab864b4ee6236e9c.jpg
    31493989_10215545089318333_7648189495396_baaaed513265e97207d963cc1f7ce310a0c356b6.jpg
    31648450_10215545090398360_2625419907822_b531e2e74c1727db4df7f5b78ac12ee0fd71c8af.jpg
    31408215_10215545090878372_1348525039800_0f7c3226433fe35c8847407a22a4e52b2f2294dc.jpg
    31501330_10215545092198405_4437182674011_8eee6c575be99296300adfbbd865d41624057d10.jpg
    31393917_10215545092758419_1841153403489_ca6a2545a386ef05341a6fecfdf6be7d60b96309.jpg
    31417070_10215545093438436_6670002017898_381093f61ed7504da8f8cc9ca20bfae4f1c366dc.jpg
    31454150_10215545094878472_7443525915671_7ccb131c4f2ee93592b76be0700443b9d6adab03.jpg
    31437359_10215545095158479_7009582133983_193908c4e034df20f3053c3505730eac94c9e3d7.jpg
    31501116_10215545096518513_4021865091744_1163ba66e780d7d1a0c2f85b38c0ed17de015ce8.jpg
    31475400_10215545097078527_7276561750688_3b7d254ce8f84a5c1f6302606936f64194fd55f4.jpg
    31493357_10215545097558539_5867175748699_17edfa3c35ef952405677feb72c244a548de46b1.jpg
    31433680_10215545097878547_6919322919516_059677e45b5ce17fb06fc756ca64637fb324b446.jpg
    31511714_10215545101078627_8189199540394_e11b74e3dc35ab54352f6ad43b67034af7122e6c.jpg
    31484195_10215545105758744_5278267103135_a458cb207c0fce329523e902b974f275a322fe19.jpg
    31408330_10215545106278757_5289535954858_e88790e2ba382598fe2cfb2dc6246637a607586d.jpg
    31435303_10215545105358734_1849288659958_bb1f8afb5c90ea71f446281d268d4333a3945866.jpg
    31408065_10215545106758769_3942984950747_5298860ffa09ea2139c1a71ac28a9d64970a5f18.jpg
    31518962_10215545107198780_8197601527217_193be43097fcfc13f75d635fdbf5ec679771646d.jpg
    31509865_10215545114158954_2147224622817_29cd32a45ba80640a6b98337159a3a92dfe0e357.jpg
    31509522_10215545114558964_9093189452104_f3cd10ebc95182a2b8c0fa88851bff494190d413.jpg
    31485987_10215545114998975_9200362900617_1974b11ba5a7d2eb7ccc12dece01e5d155627c6b.jpg
    31531159_10215545115398985_8151216979932_a89de7906c78eae811141ad60fa3147e6804ff73.jpg
    31408052_10215545115918998_2250063878098_4efaddae04d077a58213032be8f3cb93c6f7cc5b.jpg
    31497310_10215545116719018_1145891605215_9673a6782209419816622ec12c80c94d25b7a62e.jpg
    31489237_10215545117999050_3804634330337_1801410c8a14c0e2babef5e4887d65be155b0b99.jpg
    31490313_10215545119039076_8100606412461_0520a5788efa43d3b03be4a3693f40c56a240ef9.jpg
    31453943_10215545119839096_2129070264208_84450d6d1d7f2ed29dba89d783750e6006507e9b.jpg
    31670847_10215545120319108_5149666238875_48b96cbbade14d8c294e9c9b12fd073ec73f6f13.jpg
    drumzdj and 1UPPER like this.
