What length roof rack crossbars on a cap?
Discussion in 'Tonneau Covers, Caps and Shells' started by pbcolt, Nov 6, 2017.
  1. Nov 6, 2017 at 2:19 PM
    pbcolt
    pbcolt [OP] New Member
    San Diego
    2022 SR5 TRD-OR CMSB Lunar Rock
    What length corssbars are you all putting on your shells? Thinking about adding a Rhino Rack set-up and debating between 59" or 65" crossbars..
  2. Nov 6, 2017 at 2:34 PM
    HTGreen
    HTGreen New Member
    Halsey
    Central Virginia
    2018 SR5 TRD Tundra Quicksand
    My recommendation is to get rails that are as wide as the vehicle, which is 79 inched as to avoid hitting the side of the truck when loading from the side, If this is to wide for you, get ones at least as wide as the top of the cap they are mounted on, for the same reason.
  3. Nov 7, 2017 at 8:13 PM
    RangerBP
    RangerBP SC Expat. Go gamecocks.
    2017 4x4 DC, Silver Sky
    I just put 66" yakima bars on a snugtop on a '17. The beam on those is about the same as the truck itself. They stick out ~3" from the top of the shell, which tapers a bit from the width of the bed.
    veg hed likes this.
  4. Nov 7, 2017 at 8:27 PM
    veg hed
    veg hed Thug
    Utah
    2016 Ta-Tundra Barcelona Red
    I have Thule 65" load bars on my Tundra cap and they fit perfect. I have 58" load bars on my Tacoma but they looked too small for the Tundra so I bought some new 65s. I would NOT go any bigger than 65s. IMO 79" would be too big and hang over the side too much.
    Check out this link. You can actually see the Tacoma in the background.
    https://www.tundras.com/threads/thule-roof-rack-installed.7527/
  5. Nov 7, 2017 at 8:30 PM
    Agitated1
    Agitated1 Newish Member
    Los Angeles
    2017 Tundra Crewmax TRD 4x4 Quicksand
    TRD Pro Grill King Coilovers with compression adjuster Tint 5% Rear, 30% front and 70% windshield Husky X-Act Floor liners BA Muffler 8in standard system Truck Covers USA retractable bed cover Yakima bed rails
    I’ve got 60” bars on my Yakima bed rails. Not sure if you can see it but it is about 2” on each side from the end of the bed.
  6. Nov 8, 2017 at 4:51 AM
    AlexWV
    AlexWV Trophy Husband
    Alex
    WV
    2014 White SR5 TRD CrewMax
    ARE CX Series shell Rhino Rack cargo basket Leveling Kit 35x12.5 Thunderer TracGrip tires Rough Country 30" light bar
    I don't know why mine is so much less, but the rails on my cap are only like 46" apart. Not a great picture, but that's what it looks like. image2.jpg
  7. Mar 21, 2025 at 11:08 AM
    csgaddy
    csgaddy New Member
    I'm needing to get some new crossbars. I had Thule LB65 but they don't make them anymore. Looking at SquareBar EVO 60 or Thule ProBar Evo 69 anyone have any suggestions on which to go with?
