Mounting Maxtrax to toyota bed system ?
Discussion in 'Recovery & Gear' started by TheBeast, Nov 3, 2017.
  1. Nov 3, 2017 at 12:26 PM
    TheBeast
    TheBeast [OP] The Beach
  2. Nov 3, 2017 at 12:31 PM
    Toytec Lifts
    Toytec Lifts New Member
    Denver, CO.
  3. Nov 3, 2017 at 12:54 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    #homebuilt #known
  4. Nov 3, 2017 at 12:56 PM
    TheBeast
    sweet ! yeah I want to set it that way.
  5. Nov 3, 2017 at 1:17 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    Mine are TredPros and it barely fits under my tonneau and over the wheel well. It's actually tilted a tiny bit.
    dcsleeper408 and 831Tun like this.
  6. Apr 13, 2018 at 7:26 PM
    Flyinryank
    Flyinryank New Member
    Las Vegas, NV
    White 2015 CM 4x4
    Hmmmmm These look like they’d work well for maxtrax or rotopax because they rest against the bed and the floor. Pics are on a Tacoma though.
  7. Apr 13, 2018 at 7:34 PM
    Flyinryank
    Las Vegas, NV
    White 2015 CM 4x4
    I know people have just been making their own maxtrax bed rail mounts from things at the hardware store BUT
    I wonder if this will work?
    https://rotopax.com/toyota-nissan-truck-plate.html
    Drill appropriately spaced holes (as long as they are long enough) and use the maxtrax bolt down kit. Everyone says these are not strong enough for loaded rotopax but I’m sure they’d be sufficient for the weight of maxtrax right?
    831Tun likes this.
  8. Apr 13, 2018 at 7:42 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    I think @GodlessPro has/ had something like that?
    joonbug likes this.
  9. Apr 13, 2018 at 8:07 PM
    TheBeast
    that is nice
    dcsleeper408 and Sunnier like this.
  10. Apr 13, 2018 at 8:23 PM
    Vizsla
    Vizsla ☠️☠️☠️
    I tried making them a few different ways, but nothing seemed like yeah that’s right.
    Sunnier and TheBeast[OP] like this.
  11. Apr 13, 2018 at 8:24 PM
    TheBeast
    whoever makes TRED pro mounts first will get BEAST money
    Marty McFly and Sunnier like this.
  12. Apr 13, 2018 at 9:11 PM
    Sunnier
    Sunny
    San Diego, CA
    @renosauce @Bannock452
    Marty McFly likes this.
  13. Apr 13, 2018 at 10:28 PM
    Bannock452
    Bannock452 New Member
    Brandon
    Murrieta, CA
    2016 White Crewmax 4x4 SR5
    King coilovers 35x12.50-18
    Hmm only 16lbs for 2 trax can’t need that much support. Hard part is there’s really nothing to mount on the lower part. Needs some kind of triangulation to be solid. I’ll try to think of some ideas for you guys.
    Sub’d
    Sunnier[QUOTED] and joonbug like this.
  14. Apr 13, 2018 at 10:41 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    Also keep in mind when those tracks get mud all in them, they weigh like a thousand lbs.
    NewImprovedRon and TheBeast[OP] like this.
  15. Apr 13, 2018 at 11:01 PM
    Bannock452
    Brandon
    Murrieta, CA
    That is very true. Totally forgot to think about that part. Thanks for the heads up!
    Erichudgins and joonbug[QUOTED] like this.
  16. Apr 16, 2018 at 1:10 PM
    renosauce
    renosauce New Member
    Stanley
    2005 DC Tundra
    DC LT
    Im pretty sure this is not an issue of weight..strait from the Toyota brochure.
    Includes four tie-down bed cleats made of sturdy die-cast aluminum,
    accommodating a maximum load of 880 lb. (220 lb. each)
    I think a well thought out mount would work well muddy or not.
    Curious though what sort of orientation would you want to see?
    Sunnier likes this.
  17. Oct 3, 2018 at 11:14 AM
    Snal~
    Snal~ New Member
    Larry
    2018 SR5 Dbl Cab 4wd Barcelona Red
    Little late to this thread, but I'm trying to design a rigid plate (or frame) that will mount to the two holes at the bed standards (via well-nut or rivet-nut) and to brackets that will be mounted on the lower side behind the existing bed cargo hooks. A no-drill mount is what I'm after. I'm installing a tonneau on my truck, and would like to design this for holding fuel tanks and recovery gear without having to put locks on everything (since it'll be hidden under the tonneau).
  18. Jan 9, 2019 at 11:50 AM
    Flyinryank
    Las Vegas, NV
    White 2015 CM 4x4
  19. Jan 9, 2019 at 1:44 PM
    TheBeast
    nice. do the maxtrax pins work with TRED PRO ?
  20. Jan 30, 2019 at 8:00 AM
    DiegoC
    DiegoC New car smell
    Diego
    2016 White Tundra Limited
    ReadyLift SST 3/1 Level Lift W/ sum 35's
    What is the purpose of the MaxTrax?
  21. Jan 30, 2019 at 8:18 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
  22. Jan 30, 2019 at 8:28 AM
    Jeff_1974
    Jeff_1974 Cookeville, TN
    Jeff
    Tennessee
    2010 supercharged rock warrior dc
    Supercharger Bama Exhaust Bully dog tune Bed extender Roll up Bed cover Bed carpet 18” Method wheels Falken wildpeak 285 75 18 P & P rock sliders Weather tech floor mats Sdhq pre runner bumper Warn 9.5 xp synthetic winch Icon 2.5” lift Iron cross rear bumper RCI al skids Trd brake pads Trd front sway bar Deaver u748 leaf springs Marathon seat covers
  23. Feb 5, 2019 at 4:17 PM
    brimy311
    brimy311 New Member
    Kalamazoo
    2018 Tundra Platinum
    We’re currently working on a solution that will mount the tred pro boards as well as the maxtrax ones!
    monaco730, Jeff_1974 and TheBeast[OP] like this.
  24. Feb 5, 2019 at 4:23 PM
    TheBeast
    great news !. standing by for group buy :D
  25. Jul 29, 2019 at 8:57 PM
    kylerocker10
    kylerocker10 New Member
    I had the Rago mounts on my Tacoma and they work great with 4 Maxtrax mounted and are lockable. I plan on putting them on my Tundra next time I go to dunes or snow. They are also height adjustable.
