Toytec Shackle Squeak Noise - Finally Fixed! (Spoiler: Wasn’t The Bushings)
Discussion in 'Suspension' started by Bulldog_tundra, Nov 3, 2017.
  1. Nov 3, 2017 at 10:27 AM
    Bulldog_tundra
    Bulldog_tundra [OP] New Member
    USA
    2006 Double Cab
    Bilstein 5100 (Top Notch Front) 1” Rear Block Flowmaster 40 w/ 3” Tip Bumperplugs Front Plate Delete
    So ever since my Tundra was lifted it’s had an extremely annoying squeak / noise coming from the shackle area on any surface, even worse on bumps. First Toytec told me I needed their bushings to fix it, negative. Put them on and they were literally oozing out with grease and it still squeaked.
    Well, I removed the spare and looked around and sure enough there was a bed bolt on each side hitting the shackle. One thing to note, I have them installed at 1.25”, if they were installed at 1.5” they might not hit.
    Anyway, a Dremel with a 426 disc later the bolt is grounded down and the squeak is gone. I can finally roll my rear window down and drive through a parking lot without it sounding like a hoopty.
  2. Nov 3, 2017 at 10:44 AM
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
    dang... talk about a tight clearance (that's what she said). good find :thumbsup:
  3. Nov 3, 2017 at 11:06 AM
    TheBeast
    TheBeast The Beach
    I'v heard of that issue before. I myself have a creaking sound coming from the rear passenger side and it's annoying as hell but I still have stock leafs/shackles so probably different issue.
    Bulldog_tundra[OP] likes this.
  4. Nov 3, 2017 at 11:27 AM
    buckeyes1975
    Kevin
    OH-IO
    2008 Limited Double Cab
    Good to know. Thanks
  5. Dec 28, 2017 at 4:33 PM
    HBdirtbag
    HBdirtbag New Member
    Walnut Creek, CA
    2017 limited cm
    Good call. I kept thinking it was my spare!!
  6. Jul 30, 2018 at 5:14 PM
    mart1nezdaniel
    mart1nezdaniel AZ
    Arizona
    Tundra TRD PRO 2017
    why doesnt anyone use the top (1.5") setting on these?
  7. Jul 30, 2018 at 5:17 PM
    TheBeast
    TheBeast The Beach
    I think it is for Tacoma only
  8. Jul 30, 2018 at 5:22 PM
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    I did.
    Stroke250 likes this.
  9. Jul 30, 2018 at 5:26 PM
    boostedtrdpro
    boostedtrdpro voided warranty
    Jeremy
    2024 GMC Sierra 2500HD AT4X 2020 Sequoia TRD Pro 040
    I'm @ 1.5" setting as well, mine was squeaking like a pig too on the lower setting. Rubbing the bed bolt. That and the Line-X guys finger tightened my bed bolts. Lazy asses!
  10. Jul 30, 2018 at 5:28 PM
    mart1nezdaniel
    mart1nezdaniel AZ
    Arizona
    Tundra TRD PRO 2017
    Cool, and what do you have up front? spacers? shims?
  11. Jul 30, 2018 at 5:28 PM
    mart1nezdaniel
    mart1nezdaniel AZ
    Arizona
    Tundra TRD PRO 2017
    anyone use thread locker on these?
  12. Jul 30, 2018 at 5:31 PM
    Stroke250
    Stroke250 New Member
    Todd
    Idaho
    2023 Ford F-350
    On the shackle bolts? It’s not needed as they use a locking type nut.
  13. Jul 30, 2018 at 5:32 PM
    boostedtrdpro
    Jeremy
    Stroke250 and chugs like this.
  14. Jul 30, 2018 at 5:33 PM
    Stroke250
    Todd
    Idaho
    2023 Ford F-350
    Top setting on mine.
    boostedtrdpro likes this.
  15. Sep 17, 2021 at 3:33 PM
    @TUNDRACRUZ
    @TUNDRACRUZ New Member
    2019 Tundra TRD off-road
    3/2 ReadyLIFT
    I have the same exact issue on my Tundra after a 3/2 ReadyLIFT. Someone please explain to me in detail on how to fix this I also think it has something to do with the spare tire. Please PLEASE help
  16. Sep 17, 2021 at 3:52 PM
    See post #1
    @TUNDRACRUZ[QUOTED] likes this.
  17. Sep 17, 2021 at 4:03 PM
    Army_of_One
    Army_of_One New Member
    2019 MGM 4X4 CrewMax, 2005 Cement 4x4 Double Cab
    OEM+
    I'm stock with the rear right squeak. Just checked to see if there's a clearance issue, plenty of clearance with the bolt. The spare tire however, is really loud when I I lift the rear up and down.
    @TUNDRACRUZ likes this.
  18. Sep 17, 2021 at 5:01 PM
    @TUNDRACRUZ
    3/2 ReadyLIFT
    I just realized he had a 2006 and I have a 2019. I wonder if it’s going to be the same result.
  19. Sep 17, 2021 at 5:06 PM
    Same. The bed studs can interfere with the Toytec shackles set at 1".
  20. Sep 20, 2021 at 5:56 AM
    @TUNDRACRUZ
    3/2 ReadyLIFT
    Okay, I just took a video while driving and I think the clunking noise is coming from the front and then there’s a squeaking noise coming from the back
  21. Oct 2, 2021 at 3:58 AM
    Blkdmax
    Blkdmax New Member
    Tennessee
    2021 Cement CrewMax 4x4
    Same thing happened to my 2017, no need to be grinding anything away. Just take the bolt out and add a couple steel washers to the top as a spacer and reinstall the bolt.
    SoCalTundy likes this.
