  1. Sep 15, 2025 at 9:12 AM
    Upshot Knothole
    Upshot Knothole New Member
    Thatchery
    PDX OR
    2003 SR5 V8 AC TRD 4x4
    I mainly replaced mine because the tether was broken, solving the CEL was a bonus.
  2. Sep 15, 2025 at 9:14 AM
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
    Tried that but but oring was cracked. Tried to find one at the hardware store and eventually just replaced the cap...$20 and done.
    BroHon[QUOTED] likes this.
  3. Sep 15, 2025 at 9:18 AM
    Dblock500
    Dblock500 New Member
    DMV
    2002 SR5 AC 4.7 V8 4WD
    My tether was gone too, so replacing it and having a functioning tether was the added bonus for me
  4. Sep 15, 2025 at 9:19 AM
    Chris948
    Chris948 New Member
    DFW
    2006 DC
    replaced mine just for a new tether. A real wtf design when there have been clearly better ones around for many years.
  5. Sep 15, 2025 at 9:35 AM
    I've pulled it and it doesn't seem to do anything. I'm guessing trailer wiring?
    Sirfive, KNABORES and BroHon[QUOTED] like this.
  6. Sep 15, 2025 at 10:55 AM
    Yep! Correct kit for your truck can be found using this lookup tool. https://aisinaftermarket.com/online
    I'm late to the party, but with your swaybar (I think you deleted yours) unbolted, plant a foot on the LCA, put your body weight into it, and push downwards. You should be able to assert enough pressure to get the downward travel required for aligning the hole. Don't use screwdrivers or anything to align, too much risk of galling or scratching the shock bushing.
    Right? I think wood dash looks more-premium with the metal-capped ones. All-black looks cheap to me. I also prefer the light pattern on the silver-rimmed ones, looks a bit less like someone 3D printed the shits in their basement.
    EyeSpyA1stGenTundra likes this.
  7. Sep 15, 2025 at 11:02 AM
    So I did some testing with the multimeter and with the eyes on my non-working headlights. I suspected the "upgrade harness" wasn't getting trigger, or the relays were bad. They are definitely getting trigger signal, the relays are not clicking on and there's quite a bit of surface tarnish on the copper contacts. I cleaned them all up and tried again and still nothing. Either significant internal corrosion, or just outright relay failure. Plugged the LED projector bulbs into the factory harness straight up and they are functioning normal. I will probably remove the upgrade harness and toss in the parts pile. Probably don't need it anyway with just the LED projectors now.
  8. Sep 15, 2025 at 11:03 AM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Believe that's tow package stuff. My truck has it as well.
    bmf4069[QUOTED] and Sirfive like this.
  9. Sep 15, 2025 at 11:15 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Sketch! :laugh:
  10. Sep 15, 2025 at 12:18 PM
    ToyotaDude
    ToyotaDude Member
    Do you prefer the projectors to the 100 Amp Halogens or haven't run em yet?
  11. Sep 15, 2025 at 12:35 PM
    I’ve been running the LED mini projectors for almost 2 years now. They are superior to the 100w halogens as low beams. Bright, whiter light without being blue or whatever. Great cutoff. I coupled them with LED Phillips 9006 fogs and the light fill is excellent. Best headlight setup I’ve ever had on my FGT. The high beams suck on the LED minis though, the 100w halogen smoked em there. I have a 3 row 20” LED light bar and ditch pods for extra light when I need it. I went ahead and pulled the “upgrade” headlight harness out since it doesn’t work and I don’t really need it with these LEDs.
  12. Sep 15, 2025 at 12:36 PM
  13. Sep 15, 2025 at 2:47 PM
    ToyotaDude
    ToyotaDude Member
    Nice light bar placement. Source?
  14. Sep 15, 2025 at 2:55 PM
  15. Sep 15, 2025 at 3:00 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Today I added some tie downs to my bed
    and black plasti-derped the white parts of the sheet metal that were exposed from the body lift.
    Before
    After
  16. Sep 15, 2025 at 3:20 PM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    What’s up f*ckers. Been a minute. Did an oil change and washed it.
    Coming up on a big overhaul soon. TB/WP, power steering pump, revalve the rear shocks, LBJ, uniballs, valve cover gaskets, finish these damn puddle lights :rofl:
  17. Sep 15, 2025 at 3:43 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    But do your fog lights and hi beams still work?
    You might need one of those LED box thingies. If so, I have one I'll give ya.
    Edit: looks like everything is in working order.
  18. Sep 15, 2025 at 3:46 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Just in time for Merus! :D:cool:
    khooiii[QUOTED] and FrenchToasty like this.
  19. Sep 15, 2025 at 4:02 PM
    That's a 2003+ issue with the LEDs. 2000 don't give a shit.
  20. Sep 15, 2025 at 4:10 PM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    Just the revalve. Trying to unlock a few mph with a more plush tuning and for traction. A little too stiff and the rear end is dancing on the surface of gravel roads. Little sketchy haha. I’m just stacking parts for now.
  21. Sep 15, 2025 at 7:12 PM
    Upshot Knothole
    Thatchery
    PDX OR
    Got the fog light surrounds that ARB told me would fit my bumper. They don't fit my bumper.
    I think this bumper is probably pre 2005. The fog light surrounds are designed for round fog lights, and none of the fog lights that ARB currently sells will fit it. When digging around on either ih8mud or some land cruiser forum, I read that for a short time ARB bumpers were designed for some pricey IPF fog lights and then went back to standardized ones. So I'm wondering if this is one of those weird IPF fog light bumpers. Waiting to hear back from them before I start drilling and cutting to make these housings fit.
    oscardog86 and G_unit3000 like this.
  22. Sep 15, 2025 at 10:10 PM
    Bought2Pull
    Bought2Pull New Member
    Greg
    WV
    2006 Tundra 4 door
    Well yesterday I had to do a double.
    Had to pick up a mattress for my dad which was one of the most stressful things I've had to do in a while. I had to go to an aunt's house on a busy street with blind curve, single lane side and roads behind it, just not a good place to bring a trailer. My dad demanded to go. Fall-prone and walking on a cane, imagine HIM trying to get up into my Tundra. Of course this resulted in yells and threats "YOU JUST DON'T WANT ME GOING!!!"
    We were actually in the process of cleaning out the backseat for him (back seat and rear floorboard is completely covered with tools) when he lost his sh** and demanded to ride in the truck bed and when I pointed out the absurdity of that order he stormed off, as fast as a man with a cane can go. Naturally he ordered me completely out of his life at that point.....
    I'm very glad he didn't go as I wouldn't have been able to load the mattress but instead have to try to keep him from falling over and breaking a hip. He'd want to stay all day and chat with my cousin (his niece) when I had a second job to do plus him demanding I park where he says and when that didn't work out, yelling at me for "DOING IT WRONG!!!!" I've learned the hard way, it's best he doesn't go.
    However the wife and I were able to pick up the mattress and get it back.
    Then I went over to help a client return the largest flat screen TV I have ever seen (or lifted). Some 85 inches across! Thing was HUGE.
    Returned it to the store, picked up the new one, repeated the process in reverse. No AC in client's house.....things got a bit stuffy.
    Once home client called "the TV won't turn on." I replied, "did you plug it in?" :rofl:
    Joking with him of course but I was serious when I added "I am the TV mover, not the TV maker worker."
    So pulled the single axle trailer twice in one day, two completely different missions.
  23. Sep 16, 2025 at 3:01 AM
    NickB_01TRD
    KY
    You didnt have to run resistors or similar with yours? Had to do some trickery on my 01 to make them work.
  24. Sep 16, 2025 at 3:12 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I had to on my 03 as well. I think it comes down to which LEDs we use. I think some have built in resistors.
  25. Sep 16, 2025 at 5:08 AM
    These come with a converter box for them. The fogs have no resistors.
  26. Sep 16, 2025 at 5:12 AM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    That’s cool. I had to take mine to a sorcerer and give an offering for mine to work.
    BroHon, bmf4069 and KNABORES[QUOTED] like this.
  27. Sep 16, 2025 at 6:01 AM
    oscardog86
    oscardog86 New Member
    Southern California
    So I got my Radflo Coilovers installed and the JBA UCAs installed yesterday. Ran out of light so gotta torque everything down today after work. But its sitting on its own weight.
    Definitely wanna reduce the preload on them, I got too much lift where its sitting now. So gonna adjust that today as well. Hoping to get around an inch up front to be close to matching my rear.
    Hub to fender in the rear is about 22" and up front is about 23". My front was around 21" with the 6112s.
    Alignment is waaay off so gonna get it to a shop before I actually drive it anywhere. Ill post pics up soon! Thanks again for all the help guys
    For Greasing my JBA UCA they recommended a MOLY EP LITHIUM GREASE. Can the moly grease I use for my driveshaft suffice? Itd be nice to use the same grease around oil change time to do my driveshaft and my UCA at the same time using the same stuff.
    bmf4069, Filthyphil and des2mtn like this.
  28. Sep 16, 2025 at 6:14 AM
    They will settle some, so adjustment should maybe be lowering the front half of what you want.
    bmf4069 and oscardog86[QUOTED] like this.
  29. Sep 16, 2025 at 6:29 AM
    CC80guy
    CC80guy New Member
    Larry
    Lehighton, PA
    You guys do know there is a built in gas cap holder on the back of the fuel door, right? Before anybody gets their panties in a knot that off-brand cap isn't from the Tundra. Just there for illustrative purposes.
  30. Sep 16, 2025 at 6:30 AM
    oscardog86
    Southern California
    I didnt even know our gas caps came with a tether. I just use the cap holder like you do.
    BroHon and The Black Mamba like this.
