Did I toast it?
Discussion in '1st Gen Tundras (2000-2006)' started by SawyerK, Sep 14, 2025 at 3:57 PM.
  1. Sep 15, 2025 at 2:12 PM
    bfunke
    bfunke Tundra Curmudgeon
    I just pull my tranny dipstick on my 2000. So many things simpler and better in the early Tundra days!
  2. Sep 15, 2025 at 2:19 PM
    Chris948
    Chris948 New Member
    DFW
    2006 DC
    to be fair if you somehow don’t notice the oil which has a dipstick is about 4 quarts over…..
    Joking, “sealed” transmissions suck.
  3. Sep 15, 2025 at 2:22 PM
    Yeah, had OP checked the oil after the oil change, probably would have noticed the overfilled oil. Could have deduced the mistake prior to driving.
  4. Sep 15, 2025 at 2:28 PM
    This is what I did wrong. I did a spill and fill, and didn't check real well when I refilled. My first gear was acting very strange, then just disappeared. After adding more and cycling through the gears while checking fluid levels it came back. Granted I'm a lowly 4spd but it may have some bearing on the situation.
    SawyerK[OP] likes this.
  5. Sep 15, 2025 at 3:30 PM
    Yeah, hydraulic system at play, both with power steering and with transmissions. You really HAVE to cycle the fluid thru to push air bubbles and such around. With power steering, you cycle lock-to-lock a few times with the wheels in the air to help push air bubbles thru the system, and free them up into the reservoir. With transmission, you shift through the gears to help push fluid thru all the passages to help just the same, shifting from P to 1st or 2nd gear, back and forth a few times.
    Granted, it's not always the solve. But a transmission uses hydraulic fluid just like brakes and power steering. It will fail to function properly if there's air anywhere in the system. Do I think it's causing his D-solenoind issue, or missing gear? Possibly. It could also be too-little fluid, if he's not following the procedure correctly, at least getting in the ballpark. Or it could be he's totally fucked that solenoid, but I'm having a hard time believing it if it was truly only a block of driving.
    SawyerK[OP] and The Black Mamba like this.
  6. Sep 15, 2025 at 8:31 PM
    SawyerK
    SawyerK [OP] New Member
    Sawyer
    2005 Tundra SR5 V8
    Good 2 hear! I'm gonna try that.
  7. Sep 15, 2025 at 8:32 PM
    SawyerK
    Sawyer
    2005 Tundra SR5 V8
    Yah I was really not paying attention that day. Definitely should have noticed that. Well, the good news is I'm all the more familiar with my transmission now.
    Jack McCarthy and Chris948 like this.
  8. Sep 15, 2025 at 8:35 PM
    SawyerK
    Sawyer
    2005 Tundra SR5 V8
    Good point. I have checked that and deduced that must be a solenoid cause everything else has been ruled out. But yeah it looks to be an easy enough swap out. Here's hoping anyway.
  9. Sep 15, 2025 at 8:46 PM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    only between the third and seventh beers.
    Maybe put a sticker on that trans pan, i’m not trying to get banned, but you can imagine, there are some pretty good ones out there. You earned it.
  10. Sep 15, 2025 at 8:56 PM
    SawyerK
    Sawyer
    2005 Tundra SR5 V8
    Hahaha!!!!!
    Love a good sticker! I'm a visual learner after all.
