(1st Gen) What's your MPG?
Discussion in '1st Gen Tundras (2000-2006)' started by lsaami, Nov 18, 2018.
What is your Average MPG?
  1. 7 City
    0 vote(s)
    0.0%
  2. 8 City
    0.6%
  3. 9 City
    1.3%
  4. 10 City
    3.2%
  5. 11 City
    6.5%
  6. 12 City
    10.3%
  7. 13 City
    17.4%
  8. 14 City
    12.3%
  9. 15 City
    14.2%
  10. 11 Hwy
    0.6%
  11. 12 Hwy
    4.5%
  12. 13 Hwy
    3.9%
  13. 14 Hwy
    7.7%
  14. 15 Hwy
    17.4%
  15. 16 Hwy
    21.3%
  16. 17 Hwy
    13.5%
  17. 18 Hwy
    14.2%
  18. 19 Hwy
    5.2%
  19. 20 Hwy
    2.6%
  20. 21 Hwy
    1.3%
Multiple votes are allowed.
  1. Oct 31, 2022 at 11:52 AM
    #91
    stevechumo
    stevechumo New Member
    Different tires, worn out tires and bad alignment can affect the mpg. With Sea Foam, you need to do it a several times by putting it in the gas tank and the intake to see the improvement.
    Bad injector or coils or worn out timing belt and driver can also affect mpg.
  2. Oct 31, 2022 at 12:37 PM
    #92
    Zombie poll!
  3. Oct 31, 2022 at 1:08 PM
    #93
    SharkDog
    SharkDog New Member
    Denver
    2006 Gray DC Tundra SR5
    Dobinson Twin Tubes. Stock.
    What happens at 11?
  4. Nov 3, 2022 at 10:44 AM
    #94
    2004LimitedTundra
    2004LimitedTundra New Member
    2004 Black Tundra Limited
    I'll probably try more seafoam, the only issue I can really find is my tires are all a bit low on air but i doubt that'd cause a big difference but i'll fill them up when I get a chance. Everything else seems to be in good condition though.
  5. Nov 3, 2022 at 10:45 AM
    #95
    2004LimitedTundra
    11 is just what it was getting when I first bought the truck roughly a year ago.
  6. Nov 3, 2022 at 11:20 AM
    #96
    SharkDog
    SharkDog New Member
    Denver
    Got ya. Winter gas is worse, too. If you get winters.
  7. Nov 3, 2022 at 11:20 AM
    #97
    Braixen Infection
    Braixen Infection New Member
    2002 Toyota Tundra SR5 4x4 V8
    N/A
    My last two tanks in city were 16.5mpg. I think that’s really good! Just stock everything and driving like a granny for the most part lol.
    Filthyphil likes this.
  8. Nov 9, 2022 at 7:52 AM
    #98
    DesertRoads
    DesertRoads Telecom Guy
    Utah's West Desert
    2005 DC SR5 V8 4WD LSD & TOW PKG
    LED Lights Galore. Mostly Stock
    I average 15 mpg in Utah. I also have oversized tires. So I am getting what I expect from my Truck.
  9. Nov 15, 2022 at 10:29 AM
    #99
    ericryder
    ericryder Nailbender
    Eric
    HILLSBOROUGH
    '04 SR5 3.4 5 speed access cab
    Head unit and door speakers aluminum ladder rack
    Getting 19 (calc) on the three fillups I've checked since buying it with about 146K. Have had an aluminum ladder rack on for half that time, and probably 300# of tools onboard. Mixed roadways.
  10. Mar 21, 2025 at 6:16 PM
    #100
    Travtastic411
    Travtastic411 New Member
    Its possible to get up past 20 mpg, maybe 24mpg. I've done it with multiple vehicles. I got my outback from 19 mpg to 29 mpg. My 2000 tundra is around 20 now.
    Full synthetic 5-30 or 5-20 for engine oil. Full synthetic in front and rear differentials (lighter weight if not towing). Get full synthetic grease, grease everything you can including all the U-joints, front cv shafts too. Also grease the wheel bearings with mobile synthetic grease. I've drilled and tapped zerk fittings into the wheel hubs on my outback. Inflate all tires to 45-50 PSI. (This is harder on your suspension, but saves enough to justify). Get a high flow air filter, oil filter, etc. Full synthetic trans fluid and filter as well.
    Port and polish the the inside of your intake manifold if you want a big increase in power, typically efficiency as well, exhaust helps too. (I've done exhaust manifold but the intake always gave me a dramatic difference).
    Do a neutral roll test and make sure none of your brake calipers are hanging up, grease the sliders, etc. Skinnier road tires will help as well, all terrain, not so good for efficiency.
    If you have higher mileage, use "compression restore " in the bottle. It's actually proven to work if you look it up on YouTube, multiple people test it. There's also products that clean your 02 sensors and cat converters as well.
    I also want to put the electric cooling fan in mine eventually, decrease engine drag. This is almost everything i can think of...
    Never over 55-65 mph, use cruise control religiously. I'd love to eventually bolt up a manual transmission, that has a dramatic effect on mpg.
  11. Mar 21, 2025 at 8:02 PM
    #101
    Necro reply with tons of misinformation there, @Travtastic411. If you're not a bot, say cheeseballs.
    Toyota's OEM filters are already high-flow. Fuel, air, and oil. Testing shows they don't trap as much stuff as many aftermarket do, and that's exactly how Toyota designed them.
    It's actually not at all possible with the V8s in these trucks, for 4WD at least, 2WD maybe you can hit 20, you're not getting 24.
    The trans filter isn't actually a filter in many (if not all) years of these trucks. It's perforated metal. There is vertually no reason to drop the trans pan in these trucks (2000-2006), you're asking for problems in doing so, advising others to do so is irresponsible at best.
    Intake manifold, at least for 2005-2006 is plastic and can't be ported/polished safely.
    Cat cleaner is snake oil, gimmick in a bottle, compression restore is equally a joke.
    The manual trans vs. auto trans myth has been busted, repeatedly. Modern electronic transmissions will win over a human shifting, with light trucks and cars, all day long. This has been true for 20-30 years now.
    I can appreciate the sentiment of your first post here, assuming you're a human, but it's riddled with bad info.
  12. Mar 22, 2025 at 7:22 PM
    #102
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    Put on some 32” 10ply mud terrains last week and my mileage has been varying around 13mpg now. Ouch
    des2mtn likes this.
  13. Mar 22, 2025 at 7:29 PM
    #103
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Please, do share about this Outback. I'd love to know more...
    shifty` likes this.
  14. Mar 23, 2025 at 6:59 AM
    #104
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    Shifty, i totally agree with you about cheesball’s posting, but it does make me curious on just how many MPGs are realistically possible for our v8 trucks. Tire size makes a HUGE impact, and it’s very rare for anyone here on the forum to run-
    -stock sized tires.
    -a highway tread tire.
    -P rated tires.
    -narrower than stock tires.
    I’d really like the know the mpg results from a 1st gen running that specific tire combo. Perhaps breaking past 20mpg is possible going that route? But i’m guessing you’d have to be driving down a headwind free flat highway with the cruise control set at 50mph.
  15. Mar 23, 2025 at 10:34 AM
    #105
    Headwind, downhill, 16" wheel with skinny tires, overinflated, at 60mph avg, no braking, for 300 miles, on a V8/2WD, I could see someone potentially netting 22mpg.
  16. Mar 23, 2025 at 11:12 AM
    #106
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    New goal?
    My personal best: 225mi/10.9gal = 20.6mpg (60mph, freeway, flat'ish land).
    Above results from: 265/65r17 OEM size tires, 2wd v8 but a tonneau cover and 4.10 gears.
    The gears and tonneau seem to net me about 1-1.5mpg more at freeway speeds.
  17. Mar 23, 2025 at 2:53 PM
    #107
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    There was a poster once here, may he RIP, that swore black trucks got the best gas mileage, factor that in also.
  18. Sep 14, 2025 at 8:52 PM
    #108
    Bought2Pull
    Bought2Pull New Member
    Greg
    WV
    2006 Tundra 4 door
    I suspect mine would get that clean (not towing), interstate, flat country.
  19. Sep 14, 2025 at 9:10 PM
    #109
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    Who tf has ever seen a 3.58 gear ratio? I’ve heard tale of a 3.73 that will fit, but havent found one.
    The titan had a 2.92, but because of a recall i got a brand new 3.36, and that truck just purrs along under 1800rpm @ 70. Best i’ve gotten was 24 mpg but its at 300k and averages around 19-20 but its 2wd.
    455h0le_dachshund likes this.
  20. Sep 14, 2025 at 9:31 PM
    #110
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Depends on which truck.
    My daily driver 03 gets about 15/19mpg city/hwy.
    While my off-road/camping rig 06 get about 12/12mpg city/hwy.
    Redoak likes this.
  21. Sep 14, 2025 at 9:33 PM
    #111
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Might've been one of the five lugger Toyota pickups or Tacomas with 4 banger. But I think the 5 luggers came with the 8.0 rear end. The first gen Tacoma TRD off-roads (e-locker), both 4x4 and prerunner also had the 8.0.
    With AI, you never know if it's accurate info.
  22. Sep 14, 2025 at 9:44 PM
    #112
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    I dont think taco’s got 8.4’s(8.0 with the big acles & girdle). Just some t100’s?
  23. Sep 14, 2025 at 9:56 PM
    #113
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    The non e-locker prerunners and 4x4's I'm pretty sure were 8.4 (6 lugs)
    I'm also pretty sure all the 4x4 T100's were 8.4 rear.
    But what I do know for sure, is the front locker I bought and had planned on using in my 06, fit the front diff of 1G Tacoma and T100. My buddy has it in his Taco now.
  24. Sep 14, 2025 at 10:02 PM
    #114
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
  25. Sep 14, 2025 at 10:09 PM
    #115
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    With that much effort, you might as well go LT while you're at it. But I think the effort would be better suited going SAS.
    Hey while you're down here, you wanna hit some junkyards?
    Weird that LCE called it a 5.4L V8 Tundra. Makes me question the validity of the page. JK what they said about the 8.0 and 8.4 checks out with what I remember from Tacomaworld. Specifically about the 8.4 actually being an 8 or whatever
  26. Sep 15, 2025 at 3:12 AM
    #116
    mrsparkle
    mrsparkle New Member
    2002 access cab 4x4 35 10.5 17 Kendas stock gearing for now dont drive like I hate the truck and I get 18mpg on I5. I did the math for tire size does 8% sound right with 35s
    Redoak and 455h0le_dachshund like this.
  27. Sep 15, 2025 at 3:27 AM
    #117
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
  28. Sep 15, 2025 at 3:34 AM
    #118
    mrsparkle
    Just drive it like an old man. Pretty simple. I know an old dude that I've ridden with often he gets 22mph highway in a 06 double cab with an all terrain tire
  29. Sep 15, 2025 at 3:43 AM
    #119
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    No, it's closer to 14%. I have the same tires.
  30. Sep 15, 2025 at 3:47 AM
    #120
    mrsparkle
    So I'm getting better right? More like 20?
