Lower ball joints/part numbers
Discussion in '1st Gen Tundras (2000-2006)' started by Jasont, Oct 23, 2021.
  1. Sep 11, 2025 at 6:33 AM
    #451
    Steve4X42002
    Steve4X42002 New Member
    2002 Tundra Limited Access cab 4x4 V8
    I'm trying to follow all of this. I have a 2002 access cab 4wd. 158,000 miles and I believe the ball joints have never been replaced. I have watched videos of replacing the lower balljoints. I used the epic parts finder site. If I purchase parts 43330-39466 and 43340-39356 then I wouldn't have to deal with removing the ball joint from the socket? Is that correct? I can't find just the ball joints on the epic site. Here is my Vin so shifty can tell me how right or wrong I am.
    5TBBT48112S308744 (I think I tagged correct here) I also think I would be able to just change the ball joints if I could figure out the part number. Is replacing the entire assembly might be enough easier to make the cost difference worth it?
    Then I would also need the correct 8 new bolts which I also didn't figure out on the epic site. I hate that this question makes me sound like I don't know anything. I maintain/repair 99% of my own stuff. From House to Motorcycles, Automotive, etc. At 63 I've been fixing things for more than 50 years.
  2. Sep 11, 2025 at 8:36 AM
    #452
    Chris948
    Chris948 New Member
    DFW
    2006 DC
    I can see where you are coming from. I was confused too because in the past when I replace a ball joint, I just replace a ball joint. Not the weirdo assembly Toyota makes.
    the 4 bolts are bolted to the spindle. The ball joint part that has to separate that people complain about is a bolt to the lower control arm. The little arm on the ball joint assembly that you are looking to buy connects to the tie rod.
    the only way you could avoid removing the ball joint with various force, heat, hammer techniques is to replace the LCA with it. Which to be honest isn’t terrible but comes with its own can of worms.
  3. Sep 11, 2025 at 2:29 PM
    #453
    bfunke
    bfunke Tundra Curmudgeon
    WTF peeps. The LBJ is a ball and socket piece of hardware. Think hip joint. The ball is attached to a tapered bolt the passes through the LCC and the socket is part of a metal plate the bolts with 4 bolts to the spindle. They are a poor design in that the ball is mounted to the socket in tension. Replace every 100K and only use OEM.
    The Black Mamba, 9thlayer and des2mtn like this.
  4. Sep 11, 2025 at 4:09 PM
    #454
    9thlayer
    9thlayer New Member
    New Mexico
    2003 4.7L V8 AC 4x4 SR5
    10/4 @bfunke. We're on the same page. Turns out the shop I went to was NOT replacing the ball joints (thank the heavens) and it was just some loose bushings. ball joints are solid, still OEM, with no play currently. Still need to replace though. What's the best way to figure out which 2003 part #'s to go with? I guess it depends on month of manufacture?
  5. Sep 11, 2025 at 4:15 PM
    #455
    Upshot Knothole
    Upshot Knothole New Member
    Thatchery
    PDX OR
    2003 SR5 V8 AC TRD 4x4
    Use your vin to see which ones fit. That’s how I ordered the replacements for my 2003.
    9thlayer[QUOTED] likes this.
  6. Sep 14, 2025 at 9:50 AM
    #456
    ChattanoogaPhil
    ChattanoogaPhil New Member
    2000 4.7 AC SR5 4wd tow package
    Curious... am I the only one here who hasn't replaced LBJs? Early 2000 with 300k miles.
    G_unit3000 and The Black Mamba like this.
  7. Sep 14, 2025 at 11:08 AM
    #457
    Chris948
    Chris948 New Member
    DFW
    2006 DC
    this is after less than 100k miles.
    Even if you don’t worry about them falling apart, I like my alignment and not tearing up tires.
    https://youtube.com/shorts/TeiItm1fdsI
  8. Sep 14, 2025 at 11:22 AM
    #458
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    I went 304 on my 2000 OEMs (build date 5/9/00) before replacing for the first time. Although now that you know, you can't plead ignorance any longer
  9. Sep 14, 2025 at 11:37 AM
    #459
    G_unit3000
    G_unit3000 New Member
    Gman
    North East
    2005 Tundra DC 4x4
  10. Sep 14, 2025 at 11:41 AM
    #460
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    I've posted this before and I'll post it again. Just like mine, it's because it's a 2000 and had the one off good ball joints. The 2000 was never affected by the recall. That's why I was able to go 23 years and 304k. In fact, I have yet to find a confirmed lower ball joint failure on a 2000 with original ball joints. But I don not recommend being the first.
  11. Sep 14, 2025 at 2:00 PM
    #461
    ChattanoogaPhil
    Never had an alignment problem (alignment about every 70k with each new set of Michelins). The last set of Michelins went 70k. The current set of Michelins installed about 3 years ago with over 30k miles look good. Truck drives straight, quiet and smooth.
    Don't misunderstand, I'm not suggesting that preventative maintenance is a bad thing. I was just curious if I was the only one here at 300k miles on my Tundra with the original LBJs.
  12. Sep 14, 2025 at 2:16 PM
    #462
    ChattanoogaPhil
    G_unit3000[QUOTED] likes this.
  13. Sep 14, 2025 at 2:32 PM
    #463
    ChattanoogaPhil
    Interesting.
    Absent removal, are there reliable checks a mechanic can do to verify the condition of LBJs?
  14. Sep 14, 2025 at 2:55 PM
    #464
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    None that are 100% @G_unit3000 is a good example of a well maintained truck that checked out great at every maintenance interval and then just like that, out of nowhere, kachow.
  15. Sep 15, 2025 at 6:44 AM
    #465
    Yes. I think it was @des2mtn who shared Toyota's spec tolerance is 0.2mm of play. Yes, there are tools out there which can detect that. I'm highly skeptical any human would be able to detect that by hand, or with a jiggle test. You definitely won't be able to detect that with the load it's under. Numerous anecdotal reports from members on here (me included) that their LBJ only showed signs of play after removing it from the truck. YMMV always applies, but in my world, "better safe and reasonable than sorry" is king.
    I've been away working on our new house in midcoast Maine for the past week+, so just now seeing this and trying to work back thru posts.
    I ran your VIN thru the EPC, and it spit out the following for OEM joints, but note, as you'll see in the EPC, there are different bolt part numbers for your specific year. I'd see earlier in the thread for your bolt choices as posted by @NickB_01TRD
    There's a 25% off sale going on at the dealer I linked and if you're not an Alabama resident, they'll do no tax to go along with the typical free shipping and major discount. Note the full discount won't show until you get to the Checkout page, as seen here, this should be your price to your door if you order within the next 6-7 days from them while the sale is happening (basically ~50% off MSRP, not bad!):
    NickB_01TRD likes this.
