The TMBRR Build- Tribute to the Treefall
Discussion in '2.5 Gen Builds (2014-2021)' started by Apohl17, Feb 12, 2025.
  1. Apr 14, 2025 at 3:33 PM
    Apohl17
    Apohl17 [OP] New Member
    AJ
    OTT tune day! Set to mild with Tow/Haul to spicy. Noticed a definite improvement in throttle response, shift points, and general driveability!
  2. Apr 14, 2025 at 3:34 PM
    Apohl17
    AJ
    For those wondering why the tune was necessary
  3. Apr 14, 2025 at 3:37 PM
    Apohl17
    AJ
    New wheel day.
    255/85r17 Mickey Thompson Baja Boss a/t (35x10)
    Black rhino rapid 17x8.5, +10
  4. Apr 14, 2025 at 6:54 PM
    68 RS/SS
    68 RS/SS New Member
    MIke
    New Hampshire
    2020 TRD Sport DC
    Nice! Those Baja boss a/t’s are night and day better than ko2’s
    Apohl17[OP] likes this.
  5. May 13, 2025 at 7:20 PM
    Apohl17
    AJ
    Installed the lovely little Diode Dynamics Hitchmount Pod (C1R). Cool little unit that takes all of about 5 minutes to install, Inline with the 7 pin trailer wiring. Red running light, hot red brake, and bright white reverse assist light. Easily removed when needing access to the hitch receiver. Pretty awesome!
    PXL_20250512_144817251.jpg PXL_20250512_145345260.jpg PXL_20250512_145513510.jpg PXL_20250512_145535285.jpg PXL_20250512_145602261.jpg PXL_20250512_145654479.jpg
    Dr3wski likes this.
  6. May 19, 2025 at 5:43 AM
    Apohl17
    AJ
    Installed the RCI Transmission skid and Cat shield today. Fitment was spot on and installation went smoothly... Loving it.
    PXL_20250519_012605610.jpg PXL_20250519_004910736.jpg PXL_20250519_012600168.jpg
    TNThunder and 2014 Black tundra like this.
  7. Jun 11, 2025 at 8:15 PM
    Apohl17
    AJ
    Wrapping up phase 1 of the install of the Diode Dynamics D-Switch (and just hit 100k).
    Super impressed with this thing.
    Hooked up my new set of Diode SS3 Pro SAE Fogs, and the Morimoto 2 Banger ditch lights. I have the input sensor wires to ignition and side markers (for night mode). That way I can run backlight on the fogs as a secondary drl, and have anytime fogs at night through lo and hi beam. So many integration options!
    Mounted the controller behind the shift knob through the 1794 leather panel. That way, with the hand on the console rest, it's easy to control buttons and it's using dead space. Would highly recommend!
    PXL_20250605_035510732.jpg PXL_20250605_031815666.jpg PXL_20250605_040818794.jpg PXL_20250605_040810825.jpg
    2014 Black tundra likes this.
  8. Jun 11, 2025 at 8:18 PM
    Apohl17
    AJ
    Front end
  9. Jul 1, 2025 at 3:33 PM
    Apohl17
    AJ
    It's been a productive last few weeks. Flatbed is on!
    Picked up a Altra Fabrications aluminum tray, originally designed for a Tacoma. Modified the mounting feet to fit to the Tundra frame, to accommodate the extra width and frame curvature. Due to the difference in wheelbase, I am left with a 8" gap between the headache rack and cab - perfect for more storage down the road. I'll be building something to fill that gap next!
    PXL_20250615_014521902.jpg PXL_20250615_022247470.jpg PXL_20250615_180841710.jpg PXL_20250615_223953467.jpg PXL_20250616_212428072.jpg
  10. Jul 1, 2025 at 3:35 PM
    Apohl17
    AJ
    All aluminum construction with stainless hardware. Wisconsin winters - bring it on.
    rheosibal likes this.
  11. Jul 7, 2025 at 3:25 AM
    Apohl17
    AJ
    3/4 all-aluminum canopy is on and modified to suit!
    -folding ladder
    -Jerry can cage
    -gull Wing doors
    -Wolfbox G900 Pro digital rearview
    -unistrut rack and internal mounting system
    -Iceco. JP40 Pro fridge controlled by diode dynamics D-Switch
    -Maxtrax studs on the rear
    -Riversmith fly rod Carrier
    PXL_20250707_013858921.jpg PXL_20250707_003824914.jpg PXL_20250706_224803648.jpg
    BreyTundy likes this.
  12. Jul 15, 2025 at 5:53 PM
    Apohl17
    AJ
    Audio day!
    Removed the factory JBL sub enclosure to install the Tech12Volts ported 10" Sub box. Also wired in the Kicker Key500 JBL amp. Used 90mil Smartmat sound deadener material on the back cab wall and two front doors. 30 sq ft just covered about 75% of the surfaces.
    MASSIVE DIFFERENCE in audio performance, bass quality, range, etc.
    May buy another pack of deadener for rear doors. But wow, what an upgrade.
    PXL_20250715_185413301.jpg PXL_20250715_184536882.jpg PXL_20250715_195105425.jpg PXL_20250715_221626988.jpg PXL_20250715_225625541.jpg
  13. Jul 15, 2025 at 6:52 PM
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    Super neat to see everything come together, truck looks great! You could always do a water tank in that 8" gap behind the flat bed if you haven't filled it yet
  14. Jul 15, 2025 at 7:37 PM
    Apohl17
    AJ
    Thank you sir! I'm currently in the process of building a HDPE storage box for that area. Should be good for semi-dry storage!
    joseph_womack[QUOTED] likes this.
  15. Sep 10, 2025 at 10:59 AM
    Apohl17
    AJ
    New suspension day at 104k! Threw in a set of ARB BP-51s to combat that extra weight of the winch and bumper up front. So far I'm very pleased with the ride and support. Set to 5 comp and 7 rebound setting to start. SCAR 12k synthetic winch is in, looks pretty nice finished off with a Factory Ultrahook.
