22 Years With My 2002 SR5 Regular Cab
Discussion in '1st Gen Tundras (2000-2006)' started by M14 EBR, May 25, 2025.
  1. May 25, 2025 at 7:38 AM
    M14 EBR
    M14 EBR [OP] Oh No, Rex Kramer!
    My 2002 became my dedicated work truck soon after I bought it in 2003 when it had 17,000 miles.
    I've always had a 2nd vehicle to drive so I could easily separate tax deductible business mileage from everything else. The 2nd vehicle(s) also helped keep total mileage low... it should hit 200,000 miles this year.
    Mods include: Anytime fog lights, Amber LED fog lights, LED headlight bulbs in OEM housings, a Toyota 6-disc changer / cassette player with factory amp, Wet Okole seat covers, 2005 taillights & alloys, JBA short tube headers, TRD off road front coil springs, TRD/Kazuma LSD, a Hellwig/TRD rear sway bar, over the rail Line-X ...
    The place I lived at for a full decade had an exposed concrete parking pad that received no shade, the summer heat coming off the concrete baked most of the rubber suspension and drive live components making them dry and brittle.
    All it took for these rubber parts to fail about 3 years ago was an accident avoidance emergency stop with all four wheels temporarily locked up as I slid diagonally across a bumpy section of roadway leaving the Prius that turned in front of me at the last second in a cloud of tire smoke unscathed. I was on a service call more than an hour from home at the time... I safely made my way home on 4 flat spotted tires and with a lot of new vibrations and wobbles.
    Repairs associated with that event: 4 new tires, 4 new shocks, upper and lower control arms with ball joints, steering rack bushings, drive shaft assembly, sway bar end link bushings and re-centering the rear sway bar because it had shifted to one side.
    The repairs restored that Cadillac ride that I looked forward to after a hard days work.
    I will be updating and adding to the post over time...
  2. May 25, 2025 at 8:49 AM
    M14 EBR
    I don't have production numbers, but I know that Toyota did not make many 4.7L 4WD regular cab long bed Tundra in 2002. My SR5 has the factory towing package, but it does not have ABS.
    bmf4069, The Black Mamba and JJcksn12 like this.
  3. May 25, 2025 at 9:47 AM
    M14 EBR
    I have had three different caps on the bed of my truck, the Leer high top lasted 16 years before the fiberglass began to crack.
    Leer replaced the cap with a really nice new cab height cap under warranty because they no longer make the high top for these trucks...
    the ceiling on this new cap was too low for the work I do so I ordered a custom A.R.E. cap and ended up selling the new Leer for cheap. The huge aluminum A.R.E. high wedge DCU Truck Hero cap I have on the truck now is awesome, I wish I had it from day one.
    Dook55, bmf4069, BroHon and 4 others like this.
  4. May 25, 2025 at 1:40 PM
    M14 EBR
    Maintenance:
    Valve cover gaskets, spark plug tube seals, spark plugs, PCV valve & grommet changed out at 187,000 miles... this is the first time the valve covers have been off the engine, and the non ventilated side looks pristine with no staining at all. Oil had been dripping on the passenger side header for more than a year...
    A few months and 5,000 miles after the vale cover, pcv valve, and spark plug service pictured above was completed I performed the timing belt service... The original radiator was replaced in 2018.
    I changed the oil and filter during the timing belt service, and I am running synthetic oil for the very first time.
    I also replace vacuum lines while I was at it, two of them have been discontinued.
    bmf4069, BroHon, Kimosabe and 5 others like this.
  5. May 29, 2025 at 3:53 PM
    Bought2Pull
    Bought2Pull New Member
    Greg
    WV
    2006 Tundra 4 door
    Don't you just love the word "discontinued?" LOL
    Did you make your own?
    M14 EBR[QUOTED][OP] likes this.
  6. May 29, 2025 at 7:47 PM
    M14 EBR
    I tightly wrapped the ends of one with strips of heavy duty duct tape, I then repurposed a section of old line to replace the horseshoe shaped hose the red arrow is pointing to. Both were sprayed with AT-205 Re-Seal to soften them up, these repairs are working well.
    Bought2Pull[QUOTED] likes this.
  7. May 29, 2025 at 8:22 PM
    Bought2Pull
    Greg
    WV
    2006 Tundra 4 door
    "If it's stupid but it works, it's not 'stupid.'"
    I once fixed a dishwasher whose supply hose was no longer made with a piece of transmission hose. More flexible than fuel line hose (and thus able to fit over the plastic nozzles of the dishwasher) that hose repair is still going strong a decade later. :)
  8. May 30, 2025 at 3:49 AM
    bfunke
    bfunke Tundra Curmudgeon
    shifty` and M14 EBR[OP] like this.
  9. Sep 9, 2025 at 3:14 PM
    M14 EBR
    I have 31.75mm Hellwig front sway bar kit for my 2002 that I will install soon, I believe the factory front sway bar is 24mm. Part number: 7697
    Bought2Pull likes this.
