Suspension pressure washed
Discussion in '2.5 Gen Tundras (2014-2021)' started by CJ21, Nov 2, 2017.
  1. Nov 2, 2017 at 10:17 AM
    CJ21
    CJ21 [OP] CJ-21
    DELAWARE
    2016 Tundra platinum
    Clifford Alarm, 7" BDS lift with Fox coil overs, 20x12 with -44 off set fuel Mavericks , 35" TOYO Open Country Tires , Bush Wacker pocket fender flare ,2" rear Leaf springs, Bull Bar,
    image.jpg 73D147BD-EFB0-427B-97DE-A692C998392E.jpg :thumbsup:There’s a good buddy on this form that gets his suspension pressure washed once a week so I had to try it out!!
  2. Nov 2, 2017 at 10:35 AM
    I clean it with every wash. Helps maintain warranty and no cake buildup.
  3. Nov 2, 2017 at 2:10 PM
    TheBeast
    TheBeast The Beach
    I do it too, and undercarriage as well.
  4. Nov 2, 2017 at 2:28 PM
    easleycrawler
    Travis
    Easley, South Carolina
    2020 Limited DC 4X4 CEMENT
    Same here.
  5. Nov 2, 2017 at 2:36 PM
    Bpowa
    Bpowa New Member
    My side business is pressure washing. I would do this at home more often but it leaves a huge mess on the driveway and sidewalk.. Ugh!!!
  6. Nov 2, 2017 at 2:53 PM
    I always wash underneath and scrub my motor compartment every other month. That way if I ever have a leak I will know right away plus it looks good. Lol
    htw_hawaii and TheBeast like this.
  7. Nov 2, 2017 at 3:14 PM
    Hot or cold pressure washer?
  8. Nov 2, 2017 at 3:27 PM
    scpete24
    scpete24 Duuuuuuude
    Orange County, CA
    2016 TRD Pro Super White
    Do you worry about the pressure washer shooting water into the CV boots or potentially tearing the rubber? Or do you use it on a relatively low pressure?
  9. Nov 2, 2017 at 3:30 PM
    CJ21
    CJ21 [OP] CJ-21
    DELAWARE
    I used a 1400 PSI electric and had no Issues...Just enough!!:washing:
    scpete24 likes this.
  10. Nov 2, 2017 at 3:34 PM
    Cold or hot PW? Any chem degreaser? Soap?
  11. Nov 2, 2017 at 3:40 PM
    CJ21
    CJ21 [OP] CJ-21
    DELAWARE
    [​IMG] With Cold water.
  12. Nov 2, 2017 at 3:40 PM
    Thanks
  13. Nov 2, 2017 at 3:48 PM
    easleycrawler
    Travis
    Yep.
  14. Nov 2, 2017 at 3:58 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    On my MX bikes/utility quads I use simple green and keep the pressure washer nozzle as far away as I can while still getting the dirt, etc. off. I realize our trucks don't have MX suspension, but the parts are similar.
    Prostar 190 and scpete24[QUOTED] like this.
  15. Nov 2, 2017 at 3:59 PM
    I pressure wash mine quite regularly. Always after I get back from the mts.
  16. Nov 2, 2017 at 4:13 PM
    scpete24
    scpete24 Duuuuuuude
    Orange County, CA
    Thanks, good to know!
    MotoTundra[QUOTED] likes this.
  17. Nov 2, 2017 at 4:38 PM
    CJ21
    CJ21 [OP] CJ-21
    DELAWARE
  18. Nov 2, 2017 at 4:40 PM
    Straight or diluted?
    CJ21[QUOTED][OP] likes this.
  19. Nov 2, 2017 at 4:41 PM
    I
    I also use simple green buy it in the gallon jug of concentrate.
  20. Nov 2, 2017 at 4:41 PM
    CJ21
    CJ21 [OP] CJ-21
    DELAWARE
    Straight is how I used it.
    TXRailRoadBandit73 likes this.
  21. Nov 2, 2017 at 4:41 PM
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    that's just because you're super anal and overly ocd...
    T-Rex266[QUOTED] likes this.
  22. Nov 2, 2017 at 4:43 PM
    CJ21
    CJ21 [OP] CJ-21
    DELAWARE
  23. Nov 2, 2017 at 4:48 PM
    Ask Toytec how many have been voided due to people wheeling and not cleaning :)
    smslavin[QUOTED] likes this.
  24. Nov 2, 2017 at 4:49 PM
    smslavin
    smslavin New Member
    Hudson Valley
    Some stuff
    didn't say i don't do it. it was more about... :boink: :devil:
    MotoTundra and T-Rex266[QUOTED] like this.
  25. Nov 2, 2017 at 4:52 PM
  26. Nov 2, 2017 at 5:02 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    I will admit my truck hasn't seen much mud yet. Some puddles going through a dirt road or through the pits at the MX track, that's it.
    Boooooo
    T-Rex266 likes this.
  27. Nov 2, 2017 at 5:03 PM
  28. Nov 8, 2017 at 4:15 PM
    Medging
    Medging New Member
    2016 silver sky metallic platinum
    18inch fuel wheel, nfab step bars
    This might be a dumb question but I’m guessing you have to lay on the ground to wash most of the suspension? Is there anything you shouldn’t spray the degreaser on? Do you wet it and then spray the degreaser? Haven’t really used that stuff much.
    htw_hawaii and CJ21[OP] like this.
  29. Nov 8, 2017 at 4:29 PM
    CJ21
    CJ21 [OP] CJ-21
    DELAWARE
    :hattip: I just sprayed the degreaser on let it sit for 30 45 seconds and then sprayed it off and yes you probably going to have to lay on the ground to spray underneath. No dumb questions at all.
    htw_hawaii and Medging like this.
  30. Nov 10, 2017 at 1:43 PM
    71_340
    71_340 The German
    Hans
    FLW, MO
    I hose off the underneath and engine compartment every time I wash my truck because I can't stand dirt. With that said, my tuck really doesn't get very dirty because I don't go off-road and avoid mud puddles like the plague.
    Prostar 190 likes this.
