Retrax bed cover and support issues
Discussion in 'Tonneau Covers, Caps and Shells' started by jman229, May 22, 2025.
  1. May 30, 2025 at 9:47 PM
    MikroT
    MikroT New Member
    Dom
    2024 Tundra Hybrid
    @SAGE63 Ohh that is interesting. The driver side on mine has a rubber grip clamp style, but the passenger side has the bronze looking steel locking pin. On second thought, what engineer would pair steel on aluminum unless they were looking for wear issues down the road. I may just put a cap over the pin so it stops wearing my properly aligned cover. Bam problem solved.
  2. May 30, 2025 at 10:30 PM
    SAGE63
    San Diego County
    I will post
    Pictures tomorrow, they may have made changes for third gen Tundra model
    jman229[OP] likes this.
  3. May 31, 2025 at 2:44 AM
    bowhuntercoop
    bowhuntercoop New Member
    2025 limited off road
    No came that way
    MikroT likes this.
  4. May 31, 2025 at 3:01 PM
    SAGE63
    San Diego County
    ok the pictures. Also my left side does have the square cutout hole. my original rails did not.
    20250531_144937.jpg 20250531_144930.jpg 20250531_145039.jpg 20250531_145049.jpg
    MikroT likes this.
  5. May 31, 2025 at 4:16 PM
    bowhuntercoop
    That first pic the set screw isn’t even touching the rail! Check the alignment.
    why can’t we just drill a 3/16 hole in the right side rail? That would make double locks on both side? I think even having the square cut out on the driver side is enough imo
  6. May 31, 2025 at 4:35 PM
    SAGE63
    San Diego County
    Yeah it keeps slipping off. looks like I need longer alignment shims on the driver side and readjust the passenger side shims
  7. Aug 13, 2025 at 2:42 PM
    NimbusDog
    NimbusDog New Member
    Tampa, FL
    2022 Tundra
    I've tried calling syneticusa 5 days in a row, they NEVER answer. You got lucky.
  8. Aug 18, 2025 at 10:56 AM
    OutCasT
    OutCasT New Member
    O.G.
    Oakley, Ca
    ‘23 Mag Gray Limited TRD 4x4 Crewmax
    Any updates on the Retrax issue? Was considering the same model, but might have to look elsewhere.
  9. Aug 18, 2025 at 10:59 AM
    lapoolboy
    lapoolboy New Member
    I emailed them last week asking to buy a replacement gasket. They said it wasn't available separately, so they sent me a complete rolling assembly free of charge. Can't ask for better service than that. Love my Retrax.
    SAGE63 likes this.
  10. Aug 18, 2025 at 11:02 AM
    OutCasT
    OutCasT New Member
    O.G.
    Oakley, Ca
    Was this through Realtruck?
  11. Aug 18, 2025 at 11:07 AM
    lapoolboy
    Yes. Retrax was acquired by RealTruck. I purchased my cover before this though direct from Retrax.
  12. Aug 18, 2025 at 11:10 AM
    OutCasT
    OutCasT New Member
    O.G.
    Oakley, Ca
    Okay, thanks!
  13. Aug 18, 2025 at 11:19 AM
    SAGE63
    San Diego County
    same for me
  14. Aug 18, 2025 at 1:54 PM
    Calif-Tundra
    Calif-Tundra New Member
    Bob
    2023 Tundra Limited TRD
    For what it's worth I bought a new set of Retrax Pro XT rails to get the "T-Slot" from Realtruck. $369 for the set I believe. I have the Retrax Poly version without T-Slots and wanted to upgrade. Might be a solution if they won't help you.
  15. Sep 8, 2025 at 7:26 AM
    jman229
    jman229 [OP] New Member
    I may try support again at a later time, but assuming they won't be of help again I will probably just ride this cover until its toast and see what else is out there.
  16. Sep 8, 2025 at 10:42 AM
    Breckler23
    Breckler23 New Member
    Georiga
    2025 Limited TRD OR Black
    Mine is marking the right side like crazy. I almost feel just drilling a hole would solve the problem
