  1. Sep 7, 2025 at 4:33 PM
    CC80guy
    CC80guy New Member
    Larry
    Lehighton, PA
    I'm in PA and in 67 years of working on them have never broken a wheel stud. Having said that, if they were overtightened in the first place I can see where they might break.
    des2mtn and Jack McCarthy like this.
  2. Sep 7, 2025 at 4:50 PM
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
    I've snapped a few on lug nut removal, but that's usually because tire shops f'ed up the lug nut install.
    oscardog86 and BroHon like this.
  3. Sep 7, 2025 at 5:03 PM
    Yep. If you need to stand on your tire iron to free a lug, it’s on too tight. Been there plenty of times and the only reason I goto shops that properly torque them.
  4. Sep 7, 2025 at 5:09 PM
    85 ft/lbs for alloys. Not very tight.
    oscardog86, BroHon and FrenchToasty like this.
  5. Sep 7, 2025 at 5:14 PM
    Once on a trail with @nice we had a 1/2” impact that wouldn’t break some lug nuts loose. Then steps in @nutbuster with a 4 way and pops them loose like it was nothing!
    oscardog86, bmf4069, des2mtn and 3 others like this.
  6. Sep 7, 2025 at 5:30 PM
    BroHon
    BroHon What day is it?
    Bro
    Final Outpost/Bitch Mitten
    '00 SR5 AC V8 4x4
    Iron oxide weight reduction
    bmf4069, des2mtn, Sirfive and 3 others like this.
  7. Sep 7, 2025 at 5:34 PM
    BroHon
    Bro
    '00 SR5 AC V8 4x4
    Ran across this the other day (I think it was here in the Milwaukee thread) and grabbed the text and sent it to a buddy of mine, interesting facts on those impacts. Did he keep it rollin smoke for over 15 seconds?
    I'll teach you guys something about the TORQUE OUTPUT of milwaukee impacts and other electric impacts.
    I spoke to a milwaukee engineer once. And he told me information that I've never seen mentioned in the manuals or in reviews.
    We were talking about the 1/2" high torque impact. And he explained to me that if the impacts gave maximum torque the second you pull the trigger. That nuts and bolts would be constantly ripping apart. He explained that you have to pull the trigger and hold it without releasing, and that the torque ramps up 100ft/lbs every second. So to get max power put into a bolt you have to hold the socket straight and square, then keep holding the trigger, after 5 it starts ramping up the torque figure. He said to reach max torque with the 1/2" high torque, it's after 12 seconds of holding the trigger.
    The smaller impacts same principal.
    To get max power you do have to hold the trigger and let the torque ramp up.
    Buzzing it for 3 seconds then letting go, the buzzing for 5 seconds and letting go... is not how to get max torque. You got to hold the trigger for over 10 seconds.
    The engineer said the software in the impact is designed to ramp up torque with trigger duration. If you let go. Got to start again.
    oscardog86, bmf4069, des2mtn and 2 others like this.
  8. Sep 7, 2025 at 5:47 PM
    From a practical standpoint, that’s not a good thing to do unless you don’t care about your impact sockets because that pounding will open up and round out the square anvil socket input.
    I’ve already done that to a 1/2” 12 mm socket with my right angle impact getting those rear bumper bracket bolts off. Deformed it after 10 seconds of continual pounding to break the rust bond.
  9. Sep 7, 2025 at 5:55 PM
    BroHon
    Bro
    '00 SR5 AC V8 4x4
    I'm just a messenger lol. That's how they say it works. I understand your point though. :thumbsup:
  10. Sep 7, 2025 at 6:45 PM
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
    He is more himself everyday. Checkup scheduled for the end of the week, hopefully we get the all clear to start doing some normal activities.
  11. Sep 7, 2025 at 6:50 PM
    bing5
    bing5 Long member
    New Mexico
    2004 Double Cab. 270k+
    Like she came out of the factory.
    Today's tool I bought for absolutely no good reason: Wera - 5003527001 Zyklop 8794 A Wobble extension, Square drive 1/4" Head x 56mm Extensionwera.jpg
    JakeJake, KNABORES and Jack McCarthy like this.
  12. Sep 7, 2025 at 6:53 PM
    Shiny.
  13. Sep 7, 2025 at 6:57 PM
    bing5
    bing5 Long member
    New Mexico
    Here I was expecting German craftmanship and supposedly the dirty rats made it in Taiwan! ;)
    With a name like Zyklop, it has to be cool, right?
    Upshot Knothole likes this.
  14. Sep 7, 2025 at 6:57 PM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    Any of you yankees ever had to hammer alloys off? Hitting the tires on a f150 from corpus didnt work. Had to make a bar that could hit the spokes to free it.
    Steve4X42002 likes this.
  15. Sep 7, 2025 at 7:04 PM
    I thought it was manufactured in the Czech Republic?
  16. Sep 7, 2025 at 7:05 PM
    bing5
    bing5 Long member
    New Mexico
    Brilliant! Thanks
    des2mtn[QUOTED] likes this.
  17. Sep 7, 2025 at 7:06 PM
    bing5
    bing5 Long member
    New Mexico
    We'll see. A guy on Amazon was griping that he received it and discovered that Wera made it in Taiwan. At least it isn't China. I'm old enough to remember when Ohio was pretty strong in tool and die.
    p.s. Always get it confused....Czech or German. OK, I looked it up. Headquartered in Germany. Production facilites in the Czech Republic.
  18. Sep 7, 2025 at 7:06 PM
    Sledgehammer and block of wood.
    Kalannar97 and Sirfive[QUOTED] like this.
  19. Sep 7, 2025 at 8:16 PM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    Nice score Knothole! I can’t wait for more updates. Do you have a winch picked out for it yet? Fyi, most smaller ARB bumpers can house a warn winch up to a 10k (the old school 10k winches, not the newer ones. I don’t think they can house the warn “integrated” winched either, but i’m not positive on that one.
    And if you’re worried about more front end rake, put some more firewood in the bed.
  20. Sep 7, 2025 at 8:27 PM
    Upshot Knothole
    Upshot Knothole New Member
    Thatchery
    PDX OR
    2003 SR5 V8 AC TRD 4x4
    I was looking at the Warn site last night. The instructions say it'll take a low profile Warn up to 12K. I noticed most of the higher end winches need a $150-$200 wiring kit to move the wiring box off the top of the winch. Probably go with something like the Warn Zeon 10-S winch if I can find a good deal on it, but I still need to crawl under the bumper and measure everything first.
    Also need new fog lights for it and I need to replace a few missing bolts that ARB said I should have that weren't on my truck.
    Front end only dropped 1cm when I measured it before and after the bumper swap. Not too bad, and doesn't everyone drive around with firewood in the back of their truck?
  21. Sep 7, 2025 at 8:31 PM
    Upshot Knothole
    Thatchery
    PDX OR
    I think they're trying to branch out more internationally, so probably cheaper to manufacture in Taiwan for the Americas and Australian markets. I have a bunch of their tools, I'll double check if any of mine are Taiwanese, I know all the old stuff I got was Czech Republic. Probably have to double or triple the price if they were made in Germany.
    bing5[QUOTED] likes this.
  22. Sep 7, 2025 at 8:44 PM
    bing5
    bing5 Long member
    New Mexico
    Kind of on a dog kick tonight. Have to know....is there a real life 455h0le_dachshund? If so, pics please
    JakeJake likes this.
  23. Sep 7, 2025 at 8:45 PM
    des2mtn
    Shady Grove
    Tonto cover
    Pretty sure he's pussy whipped right now
  24. Sep 7, 2025 at 8:47 PM
    bing5
    bing5 Long member
    New Mexico
    The dog or the owner?
  25. Sep 7, 2025 at 8:59 PM
    whodatschrome
    lots of dents
    I buy my battery cables from here. It’s bigger, better, and costs less than warn.
    https://www.batterycablesusa.com/ba...kJ6dP05qx1n1bJh4zMyuhXZv7Od0m7sBoCycMQAvD_BwE
  26. Sep 7, 2025 at 9:09 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I despise weenie dogs. Every one of em that I've met has either been an asshole or retarded. Usually the former.
    I need to come up with a name for this little black dude. I been tentatively calling him "Jett Kiti".
  27. Sep 7, 2025 at 9:14 PM
    bing5
    bing5 Long member
    New Mexico
    Nice. Cat guy myself. Looks like those two can ward off the weenies
    455h0le_dachshund likes this.
  28. Sep 7, 2025 at 9:18 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Jasmine (the older tabby) aka Shiti Kiti has been mean to the little one all weekend. She showed up at my house, with her two babies, about a year ago.
    The little black one followed me home, on a long walk, in the wee hours of Friday morning. I'm going to try to get him all set this week with shots and neutered.
    I'm definitely not a cat guy. I love dogs. But cats are growing on me and this little guy is very likely to be able to be trained like a dog. Unlike the tabby.
    oscardog86 likes this.
  29. Sep 7, 2025 at 9:27 PM
    bing5
    bing5 Long member
    New Mexico
    The Tank is busily pursuing a life of leisure
  30. Sep 7, 2025 at 9:42 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Since he followed me home on a 9/10 of-the-way-full moon, and I was listening to my goth play list, these are the names I'm thinking about so far in lieu of "Jett Kiti":
    Damien
    Shadow
    Spectre
    Mercy
    Banshee
    Luna
    Rozz
    Phantom
    Typo
    Spirit
    Shadow
    Shade
    Moon
    Darq
