Wireless Charging Options
Discussion in '3rd Gen Tundras (2022+)' started by Jaymz, Jan 18, 2024.
  1. Feb 14, 2024 at 4:04 PM
    Blufin
    Blufin Seasoned member
    Bob
    Cape Cod,MA.
    23 Capstone
    If they say it might be a software glitch/update then it's there job to find out period. Your truck is still under warranty and the question to ask them is "if this is your charger would find this acceptable " if it was yours?
    I personally do not have your symptoms but when my phone is charging if I open the rear windshield the charging stops or gets interrupted I would assume that the circuitry is that sensitive, so in the daytime I really couldn't give a rats ass but at night....Forget about it as of now I'll put my winter hat over it due to lighting up the cabin when it loses contact with the charger.
    Probably in the spring time I'll rip out the OEM and spend the money and get a duel station and blend it in to look the best that I can.
  2. Feb 14, 2024 at 4:14 PM
    Breathing Borla
    AZ
    Try sliding it a 1/4 “ - 1/2 “ to the left of the alignment tab on the right of the charger, that where I set mine and it works just fine
    Apple iPhone max 14, Apple silicon case
  3. Feb 14, 2024 at 5:00 PM
    DRP
    DRP Old Member
    Dave
    This is the same for me. S22 with a Pelican cover.
  4. Sep 5, 2025 at 12:47 PM
    warfare
    warfare New Member
    2012 Platinum and now 2023 Limited Hybrid TRD OffRoad
    Anyone know of a Qi2 charger for our new Tundras that will replace the pathetic OEM wireless charger?
  5. Sep 5, 2025 at 5:20 PM
    60centenergy
    60centenergy Mods Member
    Zack
    GVL
    ‘24 Lunar Rock SR5 TRD Sport
    Not a replacement for that but I’ve got a 3D printed mag charger insert for the top open center tray area that uses a Belkin mag charger if you wanna go that route. It uses the USB hookups in the console to connect to. It’s much better than OEM as far as speed and connection. You need to have a slim magnetic case for it to work.
    Here is my post if interested.
