  1. Sep 5, 2025 at 8:50 AM
    Yota303
    Yota303 -Running on hope and gasoline-
    Washington
    2016 MGM Crewmax 4x4 Limited
    I purchased the set from another member on here so I’m not exactly sure what he used but it’s a smoke tinted film of some sort, I can try to reach out to him and see what he wrapped them with. I agree it looks way better than the shiny red OEM. I also upgraded them with the plug and play Hot Tails kit from @memario1214 they replace the factory halogen bulbs with VLED’s. It also gives your turn signal an amber bulb that illuminates the same location as the reverse light, instead of the whole red portion of your brake light flashing for the turn signal.
  2. Sep 5, 2025 at 10:21 AM
    AZTundra
    Paul
    Phoenix, AZ
    I did his box and single 10” JL sub about two months ago, very pleased with the outcome.
  3. Sep 5, 2025 at 11:10 AM
    Ebrperk
    Ebrperk Old member
    South Central Kansas
    2018 1794 MGM
    Tinted windows, go rhino D6 side steps and shorty antenna, Bilstein 5100's rears, 6112's fonts set to 2.5" Rocktrix RT111 18x9 -12offset NItto Terra Grapplers G3's 275/70 R18's. Amp from James @ Tech12volts FRAC Harness
    Here is a good link to look through, There is a member near the last of the thread that did a clean install. Wire loomed everything. I thought looked really good
    https://www.tundras.com/threads/21-trd-pro-jbl-upgrade.107028/page-2
  4. Sep 5, 2025 at 11:29 AM
    1794TX
    Steven
    N.TX
    '20 1794
    I did the same to mine - don't remember from whom, but the idea came off this forum. I used this:
    Amazon.com: VViViD Extra-Wide Headlight Taillight Vinyl Tint Wrap Roll (Light Smoke 16" x 48" 2-Roll Pack) : VViViD: Automotive
    and an Xacto knife. Did the clear portion of the 3rd-brake light, too.
  5. Sep 5, 2025 at 2:38 PM
    easleycrawler
    Travis
    Easley, South Carolina
    2020 Limited DC 4X4 CEMENT
    1st oem piece showed up today. Waiting on quite a few pieces from AJT and 3 more oem pieces and then I'll completely disassemble my dash.
  6. Sep 5, 2025 at 2:45 PM
    martiartisan
    martiartisan New Member
    North Texas
    2020 Tundra DC, 2006 Tundra Crew Cab
    Adv fiberglass, king suspension, cbi armor, RLD Cap
    lerbud1, Randydw, Nbab23 and 12 others like this.
  7. Sep 5, 2025 at 4:53 PM
    French Avocado
    Utah / Wyo
  8. Sep 5, 2025 at 5:16 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    What other OEM pieces are you using??
    easleycrawler[QUOTED] likes this.
  9. Sep 5, 2025 at 6:02 PM
    easleycrawler
    Travis
    The 2 on each side of the steering wheel, above brake controller and the other side, the piece above the glove box. Mine are woodgrain and I ordered black.
  10. Sep 5, 2025 at 6:09 PM
    BR73
    BR73 TUNDRA LIFE
    Rick
    Talladega,Al
    L/S Grab Handle GCS AT Cooler Kit 295/70 18's TOYO Open Country AT III Bilstein 6112 / 5100 Coachbuilder Shackles +2 12Volt systems remote start Dasaita Android 13 CF trim / chrome delete Redline shifter boot Stillen CAI High flying steering wheel TRD shifter knob LED lights inside/outside Morimoto 3rd brake light
    Me too but CF for me PXL_20250826_232323584.jpg PXL_20250826_232346240.jpg PXL_20250826_232404263.jpg
    MGMTundra18, bulldog93, 1UP and 5 others like this.
  11. Sep 5, 2025 at 6:37 PM
    French Avocado
    Utah / Wyo
    Correct - we pay for the higher trim vehicles and then we replace the higher trim with the base black! Love it. (Although fewer replacements for the platinum than the 1794.
  12. Sep 5, 2025 at 6:55 PM
    easleycrawler
    Travis
    True. I'm not a woodgrain kinda guy. The silver pieces in my opinion, is just not good. I did the oem blackout dash in my 17 sr5.
  13. Sep 5, 2025 at 7:03 PM
    KH1414
    KH1414 New Member
    Kenny
    2019 SR5 TSS
    Alpharex tails, RC nerf steps, TRD Pro rear sway, Klearz 3rd brake smoked lense
    What’s the PN for that piece?
  14. Sep 5, 2025 at 7:06 PM
    Tripleconpanna
    Gotcha...
    Are you just putting vent rings on the outer HVAC ducts??
    BR73 and easleycrawler[QUOTED] like this.
  15. Sep 5, 2025 at 7:07 PM
    Tripleconpanna
  16. Sep 5, 2025 at 7:08 PM
    easleycrawler
    Travis
    Yeah, the ajt.
    BR73 and Tripleconpanna[QUOTED] like this.
  17. Sep 5, 2025 at 7:09 PM
    easleycrawler
    Travis
    Henry1jg, BR73, bulldog93 and 2 others like this.
  18. Sep 5, 2025 at 8:52 PM
    Sleeper16plat
    Sleeper16plat New Member
    Near Vancouver
    2016 Silver Platinum
    TRD Rear Sway Bar Bilstein 6112/5160 Pop Lock, Kenwood MX 1057 XR, Pioneer amp/speakers/subs, Tech12Volt dual sub box
    I removed the front bumper!
    But ran out of daylight, tomorrow I’ll mount a warn winch and RCI Arapaho bumper!
    BreyTundy, Nbab23, Henry1jg and 15 others like this.
  19. Sep 6, 2025 at 6:19 AM
    SwitchThrottle
    2021 Barcelona CrewMax
    Do you get any sun glare from those pieces?
    NewImprovedRon and BR73[QUOTED] like this.
  20. Sep 6, 2025 at 6:24 AM
    BR73
    BR73 TUNDRA LIFE
    Rick
    Talladega,Al
    No sir the trim looks more shiny in pics than it really looks like while in the truck
    Boneskull420 likes this.
  21. Sep 6, 2025 at 6:27 AM
    SwitchThrottle
    How long did it take to pull the dash apart and reinstall it?
    BR73[QUOTED] likes this.
  22. Sep 6, 2025 at 7:52 AM
    BR73
    BR73 TUNDRA LIFE
    Rick
    Talladega,Al
    Most all these pieces are overlays but they cover well and I heated the underside 3M strips before attaching.I also wiped down the OEM pieces with denatured alcohol to remove any interior surface protectant for optimum adhesion.17571702960793198672526723559848.jpg
  23. Sep 6, 2025 at 3:07 PM
    WV_21Tundra
    WV_21Tundra New Member
    21 Tundra SR5
    Looking for some help. I've used the search and it takes me to threads that talk about mirror caps but no part #s. Can they be ordered already painted or do I need to get them painted? Also pointed in the right direction for a #. Thanks
    easleycrawler likes this.
  24. Sep 6, 2025 at 3:30 PM
    easleycrawler
    Travis
    What color is your truck?
    Jim LE 1301 likes this.
  25. Sep 6, 2025 at 4:17 PM
    I bet you $20 it's red.
  26. Sep 6, 2025 at 4:20 PM
    ATV25
    ATV25 Young at heart
    Terry
    Redding, CA
    2019 Platinum
    5100s, Icon Rebounds, Maxxis Razors
    You can do a search on eBay there's quite a few outlets for color matched mirror covers
  27. Sep 6, 2025 at 4:23 PM
    easleycrawler
    Travis
    That's how I found mine and was gonna do the same for him.
    ATV25[QUOTED] likes this.
  28. Sep 6, 2025 at 4:57 PM
    jdg1982
    jdg1982 New Member
    Florence, Colorado (From Louisiana)
    2017 Magnetic Gray Tundra SR5 4x4
    This may help get the part numbers that you need.
    https://www.toyotapartsdeal.com/oem-toyota-tundra-mirror_cover.html
    WV_21Tundra[QUOTED] and ATV25 like this.
  29. Sep 6, 2025 at 6:39 PM
    Rakkasan
    Rakkasan New Member
    NorCal
    2020 Tundra- cement-crew max 4x4
    Spray in Bed liner, 2-10”subs/400w.amp, tailgate shock, Tinted windows, seat covers, dash cover, CatShield, Fuel D538 20”wheels, Husky custom floor mats, TSC tool chest, leather seat covers. Genuine Cooling systems transmission cooler, scan gauge OBD2
    Just wanted to say I love "Eddie" off the "Killers" album cover on your profile, took me right back to high school when I first completely immersed myself into Iron Maiden. I still listen to them regularly.
  30. Sep 6, 2025 at 7:20 PM
    Nbab23
    Nbab23 2020 SR5
    Nathan
    PA
    2020 SR5 crewmax
    Stillen CAI, DD 8” exhaust, Toytec Aluma coilovers, Icon leaf springs, SCS SR8 18x9 wheels, Cooper Rugged Trek 275/70/18 A/T Tires, Ecoological bumper shellz and grill surround, AJT interior black out kit, AJT shift knob. TRD pro style grill, VLED aqua blue footwell lights, MESO custom dome and map LED lights, swing case, Rough country bed mat, TRD pro headlights and fog lights, Morimoto XB tail lights and 3rd brake light.
    Finally got around to installing my warn hidden winch bumper and badlands 12K winch. A fair amount of trimming needing for the control box to fit, but all in all turned out real nice. Next is to get the winch tensioned up and I’ll be good to go for winter!
