The Great HU Install of 2023
Discussion in 'Audio & Video' started by RainMan_PNW, Aug 19, 2023.
Did you get in on the recent Best Buy clearance frenzy? What did you get?
  1. Alpine ILX-F511
    35 vote(s)
    26.7%
  2. Alpine ILX-F509
    4 vote(s)
    3.1%
  3. Alpine ILX-F507
    0 vote(s)
    0.0%
  4. Kenwood DMX-1037S
    16 vote(s)
    12.2%
  5. Something else (let us know in the thread)
    4 vote(s)
    3.1%
  6. I bought enough to start my own car stereo franchise
    2 vote(s)
    1.5%
  7. No - I was late to the party
    55 vote(s)
    42.0%
  8. No - I didn't need a new head unit
    19 vote(s)
    14.5%
Multiple votes are allowed.
  1. Sep 3, 2025 at 5:01 PM
    #1021
    Azblue
    The Dirty T ( ^_^)_且
    Ok, unrelated to the install, but since so many of us have installed this HU, I figured it was a good thread to ask.
    Is the transmission temp gauge on the Alpine accurate enough to use for a drain and fill vs the usual means?
  2. Sep 3, 2025 at 5:05 PM
    #1022
    I also have a scan gauge2 you can use if you want. I’ll help if you need; I’ll help make sure the beer is cold…..
    Azblue[QUOTED] likes this.
  3. Sep 3, 2025 at 5:11 PM
    #1023
    Azblue
    Thanks, and as you know, there is always cold beer. :cheers: My thinking is that either a scan gauge, the old OBD jumper trick, or the Alpine HU are all relying on the same sensor in the trans, so it should work.
  4. Sep 3, 2025 at 5:14 PM
    #1024
    I can try to plug my SG2 into the 4runner with the alpine and compare and let you know.
    bulldog93 and Azblue[QUOTED] like this.
  5. Sep 3, 2025 at 5:15 PM
    #1025
    ToyoMafia
    Magic carpet.
    Cool slaps and plastiDip
    It gets the information from the truck it’s just able to read it. I used it for my trans fluid swap because my scan gauge was being a bitch
  6. Sep 3, 2025 at 5:23 PM
    #1026
    Also since you tow, I say we do the full 12 qt swap using the radiator lines……
    Azblue[QUOTED] and ToyoMafia like this.
  7. Sep 3, 2025 at 5:36 PM
    #1027
    ToyoMafia
    Magic carpet.
    Yes.
    Azblue and FrenchToasty[QUOTED] like this.
  8. Sep 3, 2025 at 5:38 PM
    #1028
    Azblue
    That's what I was thinking.
    I had a drain and fill done fairly recently, so I figured I'd just do another one. I'm planning ahead for my yearly Black Friday order when I buy all my maintenance stuff from Toyota. Filters, ATF, coolant, etc.
  9. Sep 3, 2025 at 5:39 PM
    #1029
    ToyoMafia
    Magic carpet.
    I’m kinda of a tard but I think the readable sensors are called PID’s and these units just sync to those and display what they are sensing.
  10. Sep 3, 2025 at 5:40 PM
    #1030
    ToyoMafia
    Magic carpet.
    I did a full 12qt swap to amsoil at 70k should be good for 30 years
  11. Sep 3, 2025 at 5:42 PM
    #1031
    Azblue
    You're doing better than me if you are only kinda. I'm full blown tard.
  12. Sep 3, 2025 at 5:44 PM
    #1032
    I’m a fan of amsoil, I know Tom is too. It’s not a ton cheaper but I kinda trust it more. Look for the atf with the blue top and “fuel efficient” on the bottle.
    ToyoMafia and Azblue[QUOTED] like this.
  13. Sep 3, 2025 at 5:46 PM
    #1033
    ToyoMafia
    Magic carpet.
    I run all amsoil in both trucks. Every fluid
  14. Sep 3, 2025 at 5:48 PM
    #1034
    Azblue
    So, both of you drank all the Kool-Aide.
  15. Sep 3, 2025 at 5:49 PM
    #1035
    ToyoMafia
    Magic carpet.
    We have hung out. I think we both know I drink a bunch but it’s never koolaid
  16. Sep 3, 2025 at 5:50 PM
    #1036
    Azblue
    Yep. :fistbump: :cheers:
  17. Sep 3, 2025 at 6:05 PM
    #1037
    1794TX
    Steven
    N.TX
    '20 1794
  18. Sep 4, 2025 at 8:49 AM
    #1038
    Iilac
    Iilac New Member
    The tranny sensor reads high on my Alpine. It starts at around 150 Fahrenheit right at startup when parked overnight. Where does your temp reading start up at?
  19. Sep 4, 2025 at 9:18 AM
    #1039
    Azblue
    It's within a few degrees of what my garage is. Currently in the 80s.
  20. Sep 5, 2025 at 8:22 AM
    #1040
    Iilac
    Iilac New Member
    Did you have to do calibrations/PID modifications? I have been messing with my Alpine but it reads at the 150F temp.
  21. Sep 5, 2025 at 11:31 AM
    #1041
    Azblue
    It's been a while, but if I recall, I just followed the steps listed in this thread.
    AZBoatHauler likes this.
