General Supercharger Thread
  1. Sep 1, 2025 at 11:36 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    I just went and double checked everything in that box and cant find the second stepped spacer. that what you meant?
    HulkSmurf14, e30cabrio and jstone88 like this.
  2. Sep 1, 2025 at 11:38 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Yep then you’re missing it
  3. Sep 1, 2025 at 11:42 AM
    Danimal86
    Daniel
    Sacramento, CA
    Well I'll be damned.....glad i'm not loosing my mind about that spacer. I'll reach out to whipple.
    I had a sneaking suspicion that it was the reservoir cap.
    My kit had the 2017TUND-BOLT4004-02 bag in it, but that isn't the one with the step spacer in it. Is that what you meant?
  4. Sep 1, 2025 at 11:49 AM
    blenton
    blenton New Member
    Yup. I couldn't tell who's writing was who's on the sheets, but noticed that the parts sheet had the -01 circled and -02 red lettered to the side. Mine didn't have the red letter, just the different numbers on the parts bag.
    And just to beat a dead horse, your kit came with injectors, yah?
  5. Sep 1, 2025 at 11:52 AM
    Danimal86
    Daniel
    Sacramento, CA
    Anything in black ink on the pack slip was whipple. I wrote in red and highlighter.
    Yeah it came with injectors
    Another question. Anyone know what the spacer/bolts are for in the bottom right of the box?
  6. Sep 1, 2025 at 11:56 AM
    blenton
    blenton New Member
    I think the spacers are the intake box spacers. They were different on the 2.9 kit, but at some point you needed to the tilt the bottom half of the air filter box upwards to give a straighter shot at the throttle body. I know the intake tube changed from the 2.9 to 3.0, but I still think you need to elevate the box. But they may be for something else..
  7. Sep 1, 2025 at 12:00 PM
    Danimal86
    Daniel
    Sacramento, CA
    They weren't on the packlist for that box. Some random bolts/spacers, lol.....that'll give me some nice stress when i try to figure out where they go.
    I'll have to go back through the instructions....I dont remember reading anything about that...but makes some sense.
  8. Sep 1, 2025 at 12:18 PM
    blenton
    blenton New Member
    That was just my supposition after puzzling over the spacers as well. The 2.9 kit had some C shaped 1/8"x 1/2" steel flat bar for the air box spacers. And, like I said, the intake tube changed so maybe the spacers are no longer needed. Let us know what you figure out :)
  9. Sep 1, 2025 at 12:43 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Getting tools and area cleaned up to swap transmission out. Spoke with John at IPT on rebuild and using new OEM torque converter. Talked fluids, Dex3 and Idemitsu type 4, was more interested in the type 4 having the similar additive pack for warranty.
    The hardest part will be that passenger header with that stupid air tube!
    Jego, ARES35, Wynnded and 6 others like this.
  10. Sep 1, 2025 at 1:19 PM
    blenton
    blenton New Member
    WOOHOO!!
    Interested to hear what he had to say about the fluids; when I spoke with him a while back he said WS period. Still odd to me that Dex3 is kinda fine. Dunno why, just is.
    ARES35, HulkSmurf14 and Mdl[QUOTED] like this.
  11. Sep 1, 2025 at 1:28 PM
    Danimal86
    Daniel
    Sacramento, CA
    when i hear back from whipple, i'll ask them about random bolts/spacers.
    HulkSmurf14 likes this.
  12. Sep 1, 2025 at 1:48 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Guess I’ll try that idemetsu even I already sent out dex to sniv lol
  13. Sep 1, 2025 at 2:05 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    He was stating dex3 may not have the needed additives for longevity. He was interested in the idemitsu tls 4 that had similar additive package as WS. All the Toyota training says to use WS but we know others will work just take a hit on mpg.
  14. Sep 1, 2025 at 2:10 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    If you swap out the dex3 every year you are good. It just breaks down quickly with high hp and heat we throw at it. That was the only reason asking about the idemitsu add pack and giving a warranty on his work. I was just up front with what my plans were.
  15. Sep 1, 2025 at 2:34 PM
    nags
    nags New Member
    Been working with Sniv on tuning this thing today. First tune from him and limp mode came back but he solved it quickly and tweaked from there. I don't think he's quite done yet but she running good good now :muscleflexing:
  16. Sep 1, 2025 at 2:38 PM
    Fastlane47
    Fastlane47 New Member
    Maryland
    24 TRD Pro
  17. Sep 1, 2025 at 4:52 PM
    ARES35
    ARES35 New member for life
    Mile high
    He'll get it dialed in.
  18. Sep 1, 2025 at 9:30 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Got those exhaust manifold nuts soaking. Noticed my Sequoia t-case is seeping oil at the fipg case seal. So I'll have to split the case to re-seal. Will have to order front rear shaft seals and t-case oil pump o-ring and the square cut seal on pump rotor. Hope they are in stock. As usual header manifold nuts are holding me up...
    ARES35 likes this.
  19. Sep 2, 2025 at 5:01 AM
    jhrrld
    jhrrld ID-Ten-T
    Josh
    OK
    2021 White Platinum CrewMax 4WD
    Dex III now and I plan on 30k drain and fills (just one round), is that sufficient in your mind? I have the nomad valve body with OE pan and I'm pleased with the firm shifts.
  20. Sep 2, 2025 at 5:53 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I believe WAT mentioned complete yearly exchange of fluid. Followed by a drain and fill as getting all the fluid from torque converter is not 100%.
    From post #21892:
    Edit: @Jowett mentioned the Idemitsu TLS type 4 fluid was similar to Dex3 with a WS additive pack. The TLS type 4 has similar viscosity to Dex3 but is a synthetic blend.
    Too many decisions... I ran it for a few months before my transmission went out. Had issues way before fluid swap.
    ARES35, HulkSmurf14, bflooks and 2 others like this.
  21. Sep 2, 2025 at 1:47 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Sooo we know I'm significantly faster than 7.82 because I just killed an angry young man 2x by 3+ car lengths.
    I didn't do a dragy but sniv has the log. lol
    Thought I posted the link, that is at 21:40
    https://youtu.be/VvgYOb4SmR4?feature=shared
    Saltyhero13, Fastlane47, Mdl and 3 others like this.
  22. Sep 2, 2025 at 2:33 PM
    ARES35
    Mile high
    Changed out tensioner and idler pulley since I'm exactly at 90k miles. Surprisingly neither had any play whatsoever. Oh well fresh ones are on.
  23. Sep 3, 2025 at 5:18 PM
    Silver17
    Northeast
    2017 TRD 4x4 Harrop SC
    I’ve noticed lately I get very little oil in my catchcan when I check it. I don’t check it at any set mileage interval, just when I think about it. Probably 2-3 times per oil change. Anymore all I get is a few drops out. I thought I used to get a bit more in the past. Could this be from consistent use of a good quality 5w30? Been using Pennzoil ultra platinum. I do want to replace the PCV valve but it looks like a bear to get to with the supercharger installed. I haven’t seen any other issues however that make me think there’s anything wrong with the PCV at 74k miles.
    ARES35, e30cabrio and HulkSmurf14 like this.
  24. Sep 3, 2025 at 6:42 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    PCV...it is a PITA with the boost maker...I had to MacGuyver some hose and some flexible extensions to unthread, rethread on, and tighten...it made me so mad doing it but I'm glad I got it done! I lost some bits and my hands are not for surgery purposes...but I got it done. The catch can is a other indicator on how it's breathing...yours does work, or used to, so it will 99% be your PCV. :anonymous:
  25. Sep 3, 2025 at 7:11 PM
    Silver17
    Northeast
    Bleh. Maybe this fall. Not looking forward to it.
  26. Sep 3, 2025 at 7:11 PM
    centex
    centex New Member
    No issues getting to it with a turbo. Just saying :boink:
  27. Sep 3, 2025 at 7:11 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Some fool over-torqued the top 2 bolts on the trans bell-housing to engine. But that would be me!:rolleyes:
    A one day job turned into 3. Dog at vet, shopping, yardwork etc. Why do these things get in the way of wrenching?
    Fastlane47, ssmokedz, bflooks and 4 others like this.
  28. Sep 3, 2025 at 7:12 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    And don't drop it into the valley of no return...double sided sticky tape works.:D
  29. Sep 3, 2025 at 7:12 PM
    centex
    centex New Member
    Ooof.
  30. Sep 3, 2025 at 7:13 PM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    Somewhere under my Harrop lays 1/2 of my old PVC valve. Not fun
