Anyone Replacing Their Steering Rack Bushings w/ 35's?
Discussion in '2.5 Gen Tundras (2014-2021)' started by InfernoPRO, Feb 1, 2020.
  1. Apr 9, 2024 at 2:31 PM
    #121
    InfernoPRO
    InfernoPRO [OP] Technicolor BASTRD
    Scott
    Sacramento
    2015 Inferno TRD PRO
    Good to hear your experience. Bummer about those bolts. Mine were hard to break free, but not to your level. All my old bushings were round. Did you do this to your 2010 or 2020?
  2. Apr 9, 2024 at 3:49 PM
    #122
    TundraDude772
    TundraDude772 Shake N’ Bake, Ricky Bobby
    Eric
    FL
    2010 & 2020 SR5
    2010 SR5 CrewMax Silver Sky Metallic 7” BDS/Fox 17x8.5 Method MR705 40x13.50 Toyo M/T Transfer Flow 46 gallon ICI Magnum front bumper PML Transmission Pan Hooke Road 18” bed rack Nature Nest Hard-Shell RTT Ironman 4x4 awning Coachbuilder upgrades SuperPro LCA Bushings Total Chaos UCA’s Energy rack bushings Moog LCA Cams 2020 SR5 Double Cab Voodoo Blue 40/20/40 Front Bench TRD Pro Grille TRD Pro headlights 17x9 Vision 351 285/70 Toyo A/T3 PML Transmission Pan RCI Skidplates eBay bumpers TRD rear sway bar
    It was on the 2010 with the BDS kit. Considering how bad my bushings were, I’m anticipating a massive improvement.
  3. Apr 9, 2024 at 7:04 PM
    #123
    Retroboy1989
    Northern Utah
    Anyone have any experience running the ES bushings long term? Any issues of longevity?
  4. Apr 11, 2024 at 8:05 AM
    #124
    Rc23
    Rc23 New Member
    Ross
    Chesapeake
    '16 Super White CrewMax
    2 of the factory bushings are supposed to be oval shaped
    Do you have part numbers for those LCA bushings? I'd love to swap mine out when I do my LBJ's
    Also - I feel your pain, the rack bolts were bonkers on mine how tight they were and almost impossible to hold.
  5. Apr 11, 2024 at 8:35 AM
    #125
    TundraDude772
    Eric
    FL
    2010 & 2020 SR5
    That’s strange, why would they be oval shaped? The energy urethane bushings were all the same shape. All the more reason to upgrade, I guess.
    Part numbers for the SuperPro or the OEM bushings? Actually I think I have pictures of both.
    CaptRussia253 likes this.
  6. Apr 11, 2024 at 9:08 AM
    #126
    Rc23
    Rc23 New Member
    Ross
    Chesapeake
    I’m all in on poly bushings. No more oem for me. Thanks - ordering.
    Yea I’ve heard different things on the oval shape - it may be less of an issue with stock height/ tires and wheels but it causes way more movement with the extra weight of oversized setups.
    reywcms likes this.
  7. Apr 11, 2024 at 9:21 AM
    #127
    TundraDude772
    Eric
    FL
    2010 & 2020 SR5
    If you aren’t doing them anytime soon, wait until they run a sale. It will save about $50 on a full set.
    Rc23[QUOTED] likes this.
  8. Apr 11, 2024 at 9:49 AM
    #128
    CaptRussia253
    CaptRussia253 New Member
    Ruslan
    Can anyone provide a link so I make sure I order the correct ones haha.
    Also, will probably buy an all-new steering rack and do it on the bench and have my old one as a spare.
  9. Apr 11, 2024 at 11:54 AM
    #129
    TundraDude772
    Eric
    FL
    2010 & 2020 SR5
    Link to poly rack bushings
    https://shop-coachbuilder.myshopify.com/collections/accessories/products/tundra-2007-power-steering-rack-poly-bushing-kit
    I have a new OEM rack in the garage but decided against using it since it’s pretty easy to switch later on if my old one ever craps out.
    sudobash likes this.
  10. May 16, 2024 at 1:35 PM
    #130
    TundraDude772
    Eric
    FL
    2010 & 2020 SR5
    Just got a email from superpro, 20% off sitewide until June 19th
  11. Jun 9, 2024 at 4:36 PM
    #131
    Tookooltundra
    Tookooltundra New Member
    2016 TRD PRO
    Rough Country 6" lift
    This is a BEAR OF A JOB... I followed the DIY...but my bushings were rust welded to steering rack...I had to use an air chisel to get the bottoms out. Now I'm working on the top bushings.I used a 7/8 socket..so far no movement. Any advice would be appreciated...There's room but it's very close quarters!!!
    Saltyhero13 likes this.
  12. Jun 9, 2024 at 9:27 PM
    #132
    Retroboy1989
    Northern Utah
    Make sure whatever you are using to drive the bushings is actually driving the shell and not bouncing off the rubber bushing. If you are trying to drive it by the rubber, you will whack it all day long and never move it.
  13. Jun 10, 2024 at 9:54 AM
    #133
    Tookooltundra
    2016 TRD PRO
    Thanks Retroboy1989....
    FYI Another way to remove bushings if they're rust welded like mine is to use a map torch to melt rubber and remove center bushings leaving metal shell.. You can then use a 6" blade with a Sawzall to make a relieve cut... once relief cut is made you can then use a flathead chisel or screwdriver and tap out remaining outershell.. I removed the top bushings via this method... If I had thought of this b4 it would've have saved a lot of time and
    tundra_20 and TundraDude772 like this.
  14. Dec 5, 2024 at 8:46 PM
    #134
    C.I.
    C.I. Surf, off road, sleep, repeat
    Cesar Pedrin
    Cabo, Mx
    2016 5.7 4x4 Bronze Crewmax
    Mods: Ongoing... probably never ending
    I'm in the process of doing this and a few more things while at it. However I'm not having a good time with the hardline on top of the passenger-side bushing. The damn fitting is crazy tight and won't break loose, fear I might round the corners :(
    Edit: nevermind all that. The fitting freed up in one of my tries (hurt myself, yay). Now I have to deal with lots of steering fluid out of the lines.
    TundraDude772 likes this.
  15. Dec 8, 2024 at 8:36 AM
    #135
    TundraDude772
    Eric
    FL
    2010 & 2020 SR5
    It’s worth removing that steering line because of how much easier it is to get to the nut on top of the rack. See my post #120. I didn’t have any trouble with the fitting though, hopefully it’s all a breeze after that for you.
  16. Dec 11, 2024 at 1:10 PM
    #136
    C.I.
    Cesar Pedrin
    Cabo, Mx
    Well, it's done.
    Had to create a tool to get the upper driver bushing out, it was simply not coming out with hammer hits, took a while to get the right setup, luckily there was plenty of steel laying around and it served as fab practice.
    Tool made it much less stressful and well, didn't want to bang something up. Removing the oil filter housing (was about time anyway) opened up a lot more angles to work around it too.
    Gonna use the chance to change outer tie rods with Coachbuilder's and also the ECGS bushing.
    Thread was a godsend. Thanks everyone :cheers:
    (no, its not pretty fabwork, flux core is messy and had to freehand a lot.)
    e6758c58-a35b-409d-a0ee-5c65d1960f36.jpg c0bc4811-ad9d-436c-ac62-f5298b478156.jpg
  17. Dec 14, 2024 at 4:31 PM
    #137
    Lemuel1
    Lemuel1 Enjoy
    Samuel
    2020 Tundra
    ToyTec Alumas 2.5,icon IT 2.5 rear,Wheelers superbumpstops, JBA UCA’s, 8 inch BA muffler kit,
    So any issues removing the top bolt from the steering shaft ? The one closer to the cab I cannot get the one at the rack and pinion.
  18. Dec 15, 2024 at 3:08 PM
    #138
    C.I.
    Cesar Pedrin
    Cabo, Mx
    I didn't have any problems other than the reduced room to work.
    I turned the wheel a little just to get it into a more favorable position to loosen it up, then turned it back to 12 o'clock. A paint marker is a great ally as others have mentioned
  19. Dec 15, 2024 at 3:13 PM
    #139
    Lemuel1
    Lemuel1 Enjoy
    Samuel
    2020 Tundra
    I finally got it. Steering wheel is upside down after job but I also did mevotech tie rods so meh. My only concern is all the error codes the truck threw at me. Wondering if I broke a sensor or alignment is messing it up
  20. Apr 12, 2025 at 3:22 PM
    #140
    thetwood
    thetwood New Member
    Louisville, CO
    2017 Blazing Blue Limited CrewMax TRD
    Kings, SPC, Icon Six Speed, Falken Wildpeak AT3w
    Just got done doing this. Took 7 hours, most of which was just figuring out how to get everything taken apart. Once I figured out how to maneuver the rack into place and lock it in, the passenger side bushings actually came out fairly easily (pickle fork for the win). Driver side upper took way longer. Struggled to get the right placement. My arm is dead from hammering at this point. But got it all done and back together. Thanks again to OP for posting a great write-up with pics and to everyone else who added suggestions. Glad it's over...
    tundra_20 likes this.
  21. Jul 30, 2025 at 4:42 AM
    #141
    JungleFev3r
    JungleFev3r New Member
    2020 MGM Tundra TRD
    Does anyone have any experience installing this style of bushings? Anything to worry about?
  22. Jul 30, 2025 at 9:46 AM
    #142
    C.I.
    Cesar Pedrin
    Cabo, Mx
    There is a video on how to install them without much hassle, lots of lube helps, it's arguably easy for the huge improvement.
    Hardest part IMHO is getting the OEM bushings out, will mostly depend on rust and how much you're willing to hammer the living crap out of them.
    Great chance to replace the steering fluid too :thumbsup:
    JungleFev3r[QUOTED] likes this.
  23. Sep 1, 2025 at 2:49 PM
    #143
    coTony
    Tony
    Montrose, CO
    I installed them while on 35’s knowing I am headed to 37’s
