TRD Sway Bar 2023 1794
Discussion in '3rd Gen Tundras (2022+)' started by LouALouA, Mar 23, 2023.
  1. May 20, 2025 at 9:00 AM
    #151
    kjinxx2
    kjinxx2 New Member
    I did the same.. uggh.. I still need to repair the thread and will use a helicoil. I think the shape of those bolts makes them prone to cross threading...
  2. May 20, 2025 at 9:29 AM
    #152
    deanyuan
    deanyuan New Member
    Sorry you had that happen to you as well, but it does make me feel a little better about my situation that I'm not the only one who did it. Hope you figure it out, and if you do, post some pics. I'm not sure if ill fix the cross threaded one or just leave it in for now
  3. Jul 21, 2025 at 5:54 AM
    #153
    cody.tx
    cody.tx New Member
    @4R0Z3N - update - the TRD sway bar eliminated *most* of the rubbing (35x12.5 KO2s on 20" TRD Offroad Wheels).
    now there is no rub in reverse, and less but still a little bit of tread catching when in drive
    given that i exclusively back into parking spots it's not a major issue, I like the wheels and stance currently and rather not do any spacers or aftermarket wheels. likely this is how my pavement princess will be set up for the foreseeable future....
    turning radius is definitely better now, but dangit it does still rub... since the 285/75/18 you're running is closer to 35x11.5 I'll bet the sway bar would fully clear any rubbing you're having
    MAC25Tundra, ScottieBones and Yaboy like this.
  4. Jul 21, 2025 at 7:18 AM
    #154
    kjinxx2
    kjinxx2 New Member
    Is there any way you could snag a picture of the rubbing? Probably a bit of effort, so totally understand if you don't want to. I'm looking at your exact setup and just curious what to expect.
  5. Jul 21, 2025 at 7:39 AM
    #155
    cody.tx
    cody.tx New Member
    here go - it's actually only the driver side that is rubbing, 5500 miles on it and haven't had alignment checked which I'll likely have done in short order. the sway bar seems to be nice and centered with the pass/driver stops up against the bushings.
    prior to the red one I had pretty substantial rubbing on both sides in forward and reverse, so it's definitely an improvement
    Yaboy and kjinxx2[QUOTED] like this.
  6. Jul 21, 2025 at 7:51 AM
    #156
    kjinxx2
    kjinxx2 New Member
    Thank you very much - this is super helpful
    cody.tx[QUOTED] likes this.
  7. Aug 11, 2025 at 1:14 PM
    #157
    ryanschaff
    ryanschaff New Member
    It looks like you kept the sway bar spacer from the 3 inch lift when doing the trd pro sway bar. What was the reasoning in keeping the spacer? I thought one of the benefits of doing the pro sway bar was it allows you to remove that 3 inch lift spacer which gives you more tire clearance?
  8. Aug 11, 2025 at 1:31 PM
    #158
    kjinxx2
    kjinxx2 New Member
    Think the consensus is that the TRD Pro sway bar is built for the pre-3" lift angle and so it requires the drop spacers to operate as designed with the 3" lift kit.
  9. Aug 11, 2025 at 2:11 PM
    #159
    ryanschaff
    Hmm, with 285/65/20s with the trd pro bar will it rub if keeping the spacers? I see with 35x12.5 rubs.
  10. Aug 11, 2025 at 4:15 PM
    #160
    Tundra Texan
    Tundra Texan New Member
    Todd
    2016 Tundra
    None at this point.
    Back in my Tacoma days it was the first things we removed.
    That way you had true independent suspension.
    Then came the quick disconnects.
    Pull a pin and tie up the sway bar.
  11. Aug 13, 2025 at 8:00 AM
    #161
    teab
    teab 2023 Platinum w/ PRO bits
    Ty
    Denver
    2023 Platinum MGM 6.5
    TRD Pro Wheels, Go Rhino D6, Airlift bags/compressor, Talons Alum Cat Shield, Cheap-o Amazon Mud Flaps, Fastop Tonneau/Topper, Rear TRD Pro Shocks
    https://youtu.be/gcgKbUTQJy8?si=edOXsVGOgV2ZNZmn
    Tundra Texan[QUOTED] likes this.
  12. Aug 13, 2025 at 9:29 AM
    #162
    Tundra Texan
    Todd
    2016 Tundra
    None at this point.
    It kinda seems his testing was inconclusive.
    Wish he would have come right out and told us his results.
    He kinda rattled on.
    In my case it wasn't about adding travel so much as having a more independent suspension.
    Did it really help in the end?
    It certainly seemed to.
    But then a lot of the things you do to your truck seem to work just because you wanted them to.
  13. Aug 31, 2025 at 9:21 PM
    #163
    rag9836
    rag9836 New Member
    Robert
    Riverside, CA
    2021 Tundra TRD Pro Crew Max
    275/70/18 BFGs, TRD Cold Air Intake, BRShine LED light swap, FRAC front camera, ESP Under Seat Storage, Rocky Mounts bike holder, tinted front driver and passenger.
  14. Sep 3, 2025 at 5:01 AM
    #164
    Ipaddick
    Ipaddick New Member
    Canada
    Platinum hybrid w/advanced package
  15. Sep 7, 2025 at 1:23 AM
    #165
    counterattack
    counterattack New Member
    What sway bars did you install for your 23? I'm leaning towards a hellwig for the rear.
