  1. Aug 25, 2025 at 6:14 PM
    Wow and on a new battery.
    bulldog93 and Tripleconpanna like this.
  2. Aug 25, 2025 at 6:17 PM
    NWPirate
    Zach
    WA
    :eek2:
    Ok, who did it?
    :facepalm:
    Tripleconpanna likes this.
  3. Aug 25, 2025 at 6:31 PM
    Yep. Father in law changed the battery for her s few weeks ago and he said the terminals were corroded then. He cleaned and sprayed them. Once they get corroded you never fully get rid of it. I swapped the terminal out with a cheap one from AutoZone but will order an OEM one to replace it.
    bulldog93, HulkSmurf14, BR73 and 3 others like this.
  4. Aug 25, 2025 at 6:53 PM
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Too many…scratch that…not done yet.
    I've always had luck cleaning terminals like that with a simple soak in some coca-cola. Once clean and dry or on new ones, I've always liked noco ncp2 spray.
    bulldog93 and Tunrod like this.
  5. Aug 25, 2025 at 10:24 PM
    bulldog93
    bulldog93 Usually tired...
    Jeff
    Santa Rosa, California
    2020 Super White CM Tundra TRD Pro
    Yep. Probably the issue. :eek:
    woods and Tripleconpanna like this.
  6. Aug 26, 2025 at 3:40 AM
    RustyShackle323
    RustyShackle323 New Member
    Stewart
    NC
    2019 Platinum - Barcelona Red
    So you just needed a short Ethernet cable from the SG3 to the couplet then?
  7. Aug 26, 2025 at 5:33 AM
    Failed to start this morning. It started after a few tries. I'll verify with her but it didn't click or anything. When she brought it over last night, I started it 8 or 9 times in a row. I replaced the terminal and started it another 5 or 6 times. Seems like it doesn't want to start after it sits for a few hours. The battery may be leaking to cause the corrosion but I dont know if it could also have any other issues that is causing the problem. The starter sounds strong when it is starting.
    BR73 likes this.
  8. Aug 26, 2025 at 6:05 AM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    With the amount of corrosion you had on the terminals, did you end up just replacing the terminal or the entire cable??
    There's a good chance you may have a significant amount of corrosion that's not visible in the cable (hidden by the sheath), and if so you'll end up needing to replace the entire cable(s) to get a clean connection...
    BR73 and bulldog93 like this.
  9. Aug 26, 2025 at 6:22 AM
    I just replaced the pos terminal so far. The end of the cable at the crimp didn't show any corrosion but I havent cut into the sheathing downstream on the cable yet to see what it looks like. I could get a new pos cable and run it on the outside of the harness and zip tie it. With that much corrosion after a month it could be leaking and affecting a cell....think we should have the battery load tested and swap it out?
  10. Aug 26, 2025 at 6:23 AM
    WV_21Tundra
    WV_21Tundra New Member
    21 Tundra SR5
    Obviously that's not good but I've seen much worse with no starting or running issues. I would look at my body grounds as well. Also just because your battery is new doesn't mean it's good. Could also pull the ground when she is done for the day and connect in the morning.
  11. Aug 26, 2025 at 6:57 AM
    Tripleconpanna
    Battery could definitely have an issue or two, but it's new so probably not... can't remember if you have a SG hooked up to this vehicle or not, but I'd plug in a reader and check volts when you first power down and after sitting overnight (to see if there's a drop in voltage). Also, make sure you hit those terminals (on the battery) with a good cleaner such as baking soda (someone else mentioned coke), let the cleaner work for a bit, and then make sure all that corrosion is cleaned off the posts with wire brush, etc. while you're checking the cables.
    Also, to echo what WV 21 said, I'd definitely check for corrosion and just the connections in generally in grounding stap...
  12. Aug 26, 2025 at 7:42 AM
    subspd
    subspd New Member
    Seth
    SW Florida
    2015 Tundra Platinum 4x4
    Magnuson Supercharger - TRD Exhaust - TRD BBK
  13. Aug 26, 2025 at 7:52 AM
    BR73
    BR73 TUNDRA LIFE
    Rick
    Talladega,Al
    L/S Grab Handle GCS AT Cooler Kit 295/70 18's TOYO Open Country AT III Bilstein 6112 / 5100 Coachbuilder Shackles +2 12Volt systems remote start Dasaita Android 13 CF trim / chrome delete Redline shifter boot Stillen CAI High flying steering wheel TRD shifter knob LED lights inside/outside Morimoto 3rd brake light
    Are you having long starts or the truck not turning over when you hit the switch?
  14. Aug 26, 2025 at 8:09 AM
    Its the kids 2006 4Runner. It won't turn over at all. Just normal dash lights. No clicking from the solenoid, no rotation. Starter is strong when it does start.
    HulkSmurf14 likes this.
