Rago Dash Plate
Discussion in '2.5 Gen Tundras (2014-2021)' started by ProtoJ, Jun 29, 2020.
  1. Aug 22, 2025 at 8:38 AM
    #121
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    I think this was a very well thought out, engineered and designed product. I have had absolutely no complaints aside from a couple of the nutserts coming out.....when you have multip[le items to mount (ik eeo my phine and scangauge 3) there isn't a better product in my opinion.
    Incidentally, has anyone figured out an easy way to reinstall the nutserts......i can't find anyything that doesn't require a special tool and multi pack.
  2. Aug 22, 2025 at 9:48 AM
    #122
    Most of us don't use the Rago for phones.
    bulldog93 likes this.
  3. Aug 22, 2025 at 9:50 AM
    #123
    Tunrod
    Tunrod New Member
    Rod
    2021 SR5 CM 4x4
    I wasn't to keen drilling into my dash as well until I found out the dash mat comes out.
  4. Aug 22, 2025 at 2:31 PM
    #124
    NEVERGIVEUP
    NEVERGIVEUP New Member
    2021 Super White Tundra SR5 CM
    Yeah I wouldn’t either. The phone would just be one item. I would use it more like this…possibly mount a Starlink mini there as well.
  5. Aug 22, 2025 at 4:37 PM
    #125
    That oil temp reading is no good though. I wish we had the capability to read it on the Tundra.
    NEVERGIVEUP[QUOTED] likes this.
  6. Aug 22, 2025 at 5:16 PM
    #126
    Dsptundra
    Austin TX Area
    2021 Silver Limited CM
    Has anyone swapped in a 12v socket to the new Rago plates that come with the USB? I would like this to be 12v so I can plug in my RV rear camera screen as it does not have an option for USB.
  7. Aug 22, 2025 at 5:22 PM
    #127
    I never thought about that with mine. Blue Sea has 12V sockets with a nut so I think you could make that work. You might have to drill the hole in the dash to accommodate the length.
  8. Aug 22, 2025 at 5:58 PM
    #128
    NEVERGIVEUP
    You can get that same device and mount it in your tundra.
  9. Aug 22, 2025 at 6:13 PM
    #129
    I have a SG3. My point was that the oil temp reading is inaccurate. Tundras don't have an oil temp or oil pressure sending unit to get readings from.
  10. Aug 22, 2025 at 8:00 PM
    #130
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    It's kinda like the AFR reading on the SGiii... It's not an accurate reading of your AFR just what the ECU is programmed to 'request' under the given conditions, but the actual AFR isn't what's being displayed :thumbsup:
    NEVERGIVEUP likes this.
  11. Aug 23, 2025 at 11:51 PM
    #131
    NEVERGIVEUP
    Good to know. I was unaware of this
