General Supercharger Thread
  1. Aug 18, 2025 at 10:54 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    As winter approaches and you have the full swap to DEX3 you may experience a delayed shift sequence. It will subside once the atf gets to about 110-120F. You could un-pin your t-stat to warm it up quicker in winter. Dex 3 viscosity is 34.5 at 104F and 7.3 at 212F. WS is about 23 and 5.4 at those temps, so just a bit more.
    ARES35, HulkSmurf14, reywcms and 2 others like this.
  2. Aug 18, 2025 at 10:58 AM
    jhrrld
    jhrrld ID-Ten-T
    Josh
    OK
    2021 White Platinum CrewMax 4WD
    Yeah i plan on removing the paper clip in winter as it gets damn cold here. Thanks for the info MDL!
    HulkSmurf14 and Mdl[QUOTED] like this.
  3. Aug 18, 2025 at 11:02 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I narrowed down my transmission issue to the Torque Converter. I most likely slightly toasted it when my strainer came off as each time the TC unlocks it jumps 300-500rpm before transferring power. All solenoids activate and within ohm range. Fluid wasnt burnt and did see some debri in it, most likely from TC. Shifts well 1-4 is good, 5 and 6 has been an issue with hard shift. Only doing local drives until I can do a swap out and rebuild.
    Edit: 1-4 is still pretty tight. 5 will not unlock and has the slip in rpm's. So TC and possibly C2 clutch. S2 solenoid was good but who knows.
    ARES35, Wynnded, HulkSmurf14 and 3 others like this.
  4. Aug 18, 2025 at 11:13 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Thanks mdl! Fittings came.
    I have a 143k working when it came out but I didn't want to deal with the r&r if it failed in 2k miles tq converter if you want it
  5. Aug 18, 2025 at 11:26 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Thanks for the offer. I just have to find the time to head down to @reywcms and get his transmission that he's been graciously holding for me. I plan to swap out the whole unit and send mine out for a rebuild.
  6. Aug 18, 2025 at 5:47 PM
    LILTRD
    LILTRD New Member
    East Bay, California
    2013 Tundra RCSB
    Hidden Winch Lighting Suspension/Air bags Wheels/Tires Audio Center Console swap
    I would say something is out of sorts.^
    Although I don't have a reference for a tune other than stock, my truck has been running well with the Whipple tune and appears to be adequately safe in the a/f department from what I've been monitoring.
    My latest/highest boost number I've seen.
  7. Aug 18, 2025 at 6:31 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    What makes you think something is out of sorts? Stock pulley etc that’s not out of normal psi stock range. Have you checked the bypass valve is also working correctly we noticed many installers etc overlook this is clear and not caught on anything
    mustang67408, nags, Mdl and 1 other person like this.
  8. Aug 18, 2025 at 7:51 PM
    LILTRD
    LILTRD New Member
    2013 Tundra RCSB
    I was meaning to say compared to @nags buddy my Whipple canned tune has been good too me so far. So, something must be out of sorts with their install of the tune or file they received.
    mustang67408, nags, Mdl and 2 others like this.
  9. Aug 19, 2025 at 4:36 AM
    jhrrld
    jhrrld ID-Ten-T
    Josh
    OK
    So I've done 2 drain and fills, each time removing and replacing about 4L of trans fluid. As long as I'm putting in exactly what I've taken out it's ok to not check the level each time?
  10. Aug 19, 2025 at 4:40 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    don't clutch your pearls over the temp...if the pan is warm, you are GTG.
  11. Aug 19, 2025 at 4:55 AM
    jhrrld
    jhrrld ID-Ten-T
    Josh
    OK
    I had to stop yesterday as it was 120+ in my shop ugh damn temp pan temp would not get below 150*
    FFS, I want to slack.
  12. Aug 19, 2025 at 6:21 AM
    nags
    nags New Member
    I believe the tune wasn't installed properly (or at all). We'll find out soon when I get my hands back on it myself.
    mustang67408 likes this.
  13. Aug 19, 2025 at 6:29 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    I'll add:
    when you do an oil change.....do you check to see how much you added?
    then, why would you consider NOT checking the level on the 2nd most important piece of equipment on your truck?
    FTR - it's very, very easy.
    Tripleconpanna likes this.
  14. Aug 19, 2025 at 6:39 AM
    e30cabrio
    I paid a shop to D&F my '10 CrewMax transmission, 3 months later, I had no reverse. I drained & replaced 3x on the Sequoia, measuring exactly what came out & replacing it.
    HulkSmurf14 and jhrrld like this.
  15. Aug 19, 2025 at 6:44 AM
    jhrrld
    jhrrld ID-Ten-T
    Josh
    OK
    Logic tells me this is sufficient, but my OCD will force me to check it when I'm done draining and filling, just on the last iteration though.
  16. Aug 19, 2025 at 6:50 AM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    That's what I do when doing multiple drains in a row. Overfill, run, shift, drain, repeat. Just level check before you drive it.
    e30cabrio, Mdl, sbxx312 and 4 others like this.
  17. Aug 19, 2025 at 9:03 PM
    blenton
    blenton New Member
    Alright @LILTRD and @nags and @Danimal86 - what size stock pulley did whipple ship with your SC? My replacement blower came with a 3.75" pulley, but I'm told 3.875" is the standard size for an off the shelf kit. I had pulleyed down my 2.9 due to higher elevation and told whipple as much when I filled out their RMA forms. So now I'm curious which size is standard..
  18. Aug 19, 2025 at 9:22 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    The 3.0 comes with a larger pulley than the 2.9 did. 3.625 was stock on the 2.9.
    nags and HulkSmurf14 like this.
  19. Aug 19, 2025 at 9:25 PM
    blenton
    blenton New Member
    Right, I'm just wondering which size is stock with the 3.0. (wondering if they sent me a smaller pulley knowing I was running a smaller pulley on my setup).
  20. Aug 19, 2025 at 10:22 PM
    blenton
    blenton New Member
    Never mind. Figured it out.. 3.750” it is.
    mustang67408 and HulkSmurf14 like this.
  21. Aug 20, 2025 at 5:12 AM
    jhrrld
    jhrrld ID-Ten-T
    Josh
    OK
    @Cruisers & Co.
    I never received documentation on where to ship my stock valve to for core return. Anyone care to share where to ship the core?
    4 drain and fills complete and trans shifts quick and feels great. Next up install boost gauge/afr combo and traction bars, then maybe just maybe it's 76mm pulley time!
  22. Aug 20, 2025 at 5:13 AM
    bflooks
    bflooks New Member
    Metrowest MA
    Just ship it back to Johnny at Cruisers
    Label it with your order number or last name so he can track who it belongs to
    HulkSmurf14 likes this.
  23. Aug 20, 2025 at 5:15 AM
    jhrrld
    jhrrld ID-Ten-T
    Josh
    OK
    The address on their website? Mine came from AUS, don't want to ship it back there.
    bflooks[QUOTED] likes this.
  24. Aug 20, 2025 at 5:28 AM
    centex
    centex New Member
    Can confirm. This is what Johnny had me do.
  25. Aug 20, 2025 at 5:29 AM
    jhrrld
    jhrrld ID-Ten-T
    Josh
    OK
    Thank you! will ship it today!
  26. Aug 20, 2025 at 5:39 AM
    centex
    centex New Member
    One note is to be patient. It’s a solid 6-8wks before you get the core charge back.
    HulkSmurf14, bflooks and jhrrld like this.
  27. Aug 20, 2025 at 5:54 AM
    jhrrld
    jhrrld ID-Ten-T
    Josh
    OK
    Will not worry about that, main goal was to get the valve body off of my dinning room table. hahahaha
    HulkSmurf14, reywcms and bflooks like this.
  28. Aug 20, 2025 at 7:35 AM
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    that's just a 30 minutes trip from me...wonder if they do anything with the 750E/F's off the Tacoma/4Runner/GX470...
    HulkSmurf14 and e30cabrio like this.
  29. Aug 20, 2025 at 9:30 AM
    Js18tundra
    Js18tundra New Member
    18 Tundra sr5 TRD 4x4
    Diamondback se tonneau
  30. Aug 20, 2025 at 10:12 AM
    texoma
    texoma Triple C Chop Shop
    ChrisTopher
    Lago Vista, TX
    2018 Limited Tundra
    All the Chrome
    For some reason Toyota/Lexus Tran’s like to be overfilled a touch. I don’t know if it’s a full quart. I usually a pint. But it’s more about the pump pick up being able to stay submersed.
