Is the Tundra Hybrid worth it?
Discussion in '3rd Gen Tundras (2022+)' started by BBurgDave, Aug 15, 2025.
  1. Aug 17, 2025 at 1:50 AM
    SWB Tundra
    SWB Tundra New Member
    T
    Cenral Arkansas
    2024 Tundra Platinum 4x4 CM Hybrid
    I drove both. Did not like the throttle lag. Went with one that had no throttle lag. I enjoy the truck.
  2. Aug 17, 2025 at 2:48 AM
    NimbusDog
    NimbusDog New Member
    Tampa, FL
    2022 Tundra
    Exactly.
  3. Aug 17, 2025 at 7:05 AM
    Matt2015Tundra
    Matt2015Tundra New Member
    2023 1794 CrewMax
    Not hating just stating...facts.
    For all the claims of more power, less hesitation, blah blah blah...the fact remains the hybrid is only 4/10 faster 0-60 and is actually slower in the 1/4 mile than the non-hybrid. The hybrid is heavier, has less storage, is more complex and potentially more trouble-prone.
    IMO, the only true benefit of the hybrid is slightly better towing capabilities, and I think even those claims are over-stated.
  4. Aug 17, 2025 at 7:57 AM
    Reciprocal
    Reciprocal New Member
    2025 Tundra 4x4 Limited Crew Cab 5.5
    It runs my 3 gal air compressor.
  5. Aug 17, 2025 at 8:04 AM
    Breathing Borla
    AZ
    mobile blow up dolls
    Ok shit we found a good use
  6. Aug 17, 2025 at 8:11 AM
    Reciprocal
    No the dolls are medium density foam.
  7. Aug 17, 2025 at 9:47 AM
    Matt2015Tundra
    2023 1794 CrewMax
    I'm not surprised since most 3-gallon air compressors only require around 350 watts.
    But the guy mentioned power tools. A typical corded circular saw, or angle grinder, requires around 1500 watts. A corded drill around 800 watts.
    Heck, even a typical kitchen toaster, or hair dryer, needs more watts than 400.
  8. Aug 17, 2025 at 9:58 AM
    jctmundra
    jctmundra New Member
    Northern VT
    '23 1794 Hybrid Stunning Mesquite/Cream
    Tools with cords? Is this 2001?
  9. Aug 17, 2025 at 10:30 AM
    SWB Tundra
    T
    Cenral Arkansas
    If I was worried about drag times. I would finish truck I started few years back. Start racing again. These trucks are okay for big truck, but nothing special.
  10. Aug 17, 2025 at 11:10 AM
    SWB Tundra
    T
    Cenral Arkansas
    That 4/10 of a second you speak about is sitting still waiting for turbos to spool up after pressing throttle.
  11. Aug 17, 2025 at 11:34 AM
    18" TRD Off Road Wheels
    You make it sound like the truck can't move without boost. The hyperbolic nature of that comment is silly.
    The hybrid has more power so long as it's got juice in the battery. Fact. It uses it to compensate for turbo lag. Fact.
    However, implying it is some kind of night and day difference is disingenuous. The 10 speed transmission makes good use of the over square engine's natural low end torque and gets the truck moving just fine for a truck with or without battery or boost assistance.
    Much of the lag is also a delay in throttle response as the RPMs don't start rising as soon as you press the throttle. That is programming and has nothing to do with the hybrid vs non-hybrid setup. No one expects either to be a race car unless they're delusional.
    If empty, the performance is so similar that it's negligible for most drivers. The only place the hybrid will have a major advantage is off the line while towing heavy.
    OHwendTrd, BlackNBlu, DRP and 4 others like this.
  12. Aug 17, 2025 at 11:44 AM
    Breathing Borla
    AZ
    damn , stop with all these facts
    You’re starting to sound like a tundra owner again, the ford contamination if wearing off :p
    drewpweinerMD, BlackNBlu and kirkb like this.
  13. Aug 17, 2025 at 11:49 AM
    Well people are acting like there's some great divide between the two and as though owners need to shit on the other. They're both Tundras, for crying out loud.
  14. Aug 17, 2025 at 12:07 PM
    Reciprocal
    Does the hybrid regenerate to the battery when coasting or braking?
  15. Aug 17, 2025 at 12:14 PM
    Matt2015Tundra
    2023 1794 CrewMax
    I feel like this guy did a fairly honest and unbiased review on the hybrid vs. non-hybrid discussion.
    His reasons for ultimately choosing the non-hybrid are my exact reasons too.
    https://www.youtube.com/watch?v=zFXYWZIif2c
  16. Aug 17, 2025 at 12:17 PM
    It does regenerative braking from what I can find searching the web. Still, it's a low capacity system used for added power and torque, not for fuel economy.
    woods and Reciprocal[QUOTED] like this.
  17. Aug 17, 2025 at 12:30 PM
    Never saw that one. Good breakdown.
  18. Aug 17, 2025 at 1:15 PM
    NimbusDog
    Tampa, FL
    2022 Tundra
    4/10 is 4 car lengths, see ya'll in my rear view!
  19. Aug 17, 2025 at 1:15 PM
    NimbusDog
    Tampa, FL
    2022 Tundra
    AGREED
  20. Aug 17, 2025 at 1:28 PM
    #50
    Uh, no?
    60 mph is only 88 feet per second. 4/10 of a second at 60 mph would only be 35 feet. That's if you are already going 60, not getting up to 60.
    The lead in a hybrid is going to be half that distance or less. So something like 17 feet. The Tundra is a bit over 19 feet long. It's less than one Tundra length lead and that's the distance from nose to nose; not the gap between tail and nose.
    So basically the non hybrid will be in your blindspot... until it overtakes you in less than a quarter mile.
    Matt2015Tundra likes this.
  21. Aug 17, 2025 at 1:31 PM
    #51
    NimbusDog
    Tampa, FL
    2022 Tundra
    It was a joke, relax.
    And 35 feet is only if you're doing a constant 60mph, not accelerating.
    So youre only 17 feet behind, or 10 feet, or even 5. Whatever. We arent racing stock trucks on the strip
    And the posted 1/4 mile times from car and driver and motor trend both place the hybrid faster in the 1/4 mile over the non hybrid... So i'm not sure what you're reading.
    GODZILLA likes this.
  22. Aug 17, 2025 at 1:39 PM
    #52
    SWB Tundra
    T
    Cenral Arkansas
    That is far enough to be looking at tail lights. Sounds like a win.
    All jokes a side. When I test drove non hybrid. It laid down on full throttle take off. Half throttle wasn't so bad. But, that was enough for me.
    Hybrid just done its thing. May equal out on big end. But, doesn't matter to me. Take off is what matters to me not what it is doing at 1320 mark.
    I'm done. Not that serious to me.
    woods, GODZILLA[QUOTED] and NimbusDog like this.
  23. Aug 17, 2025 at 1:40 PM
    #53
    Ah, couldn't tell and the math was just way off.
    Agreed, the "race" stats are useless, especially on trucks.
    NimbusDog[QUOTED] likes this.
  24. Aug 17, 2025 at 1:41 PM
    #54
    NimbusDog
    Tampa, FL
    2022 Tundra
    Also, in 1/4 mile racing, 1/10th = 1 car length is a rule of thumb. Not strictly scientifically precise. In that scenario the vehicle is always under acceleration during the race. There's a load of variables, so all you can go with is a a close to equal as you can.
  25. Aug 17, 2025 at 1:45 PM
    #55
    NimbusDog
    Tampa, FL
    2022 Tundra
    Lol yeah, if you want a fast truck, try Nick's S10
    GODZILLA[QUOTED] likes this.
  26. Aug 17, 2025 at 1:48 PM
    #56
    With as fat as our trucks are it is probably scaled more like tenths of vehicle lengths per second difference. Lol
  27. Aug 17, 2025 at 1:56 PM
    #57
    Definitely nothing serious. It's purely a preference thing. It's like arguing if SR5 or Limited is a better trim; all subjective priorities.
    BlackNBlu likes this.
  28. Aug 17, 2025 at 1:56 PM
    #58
    NimbusDog
    Tampa, FL
    2022 Tundra
    It's all good, I love my new old truck. Was helping a friend today on his rusty ass f150, went to parts store, dope behind counter was trying to shit on my ride. "oh you got that v6, how do you like it?"
    I replied "its fucking awesome"
  29. Aug 17, 2025 at 1:57 PM
    #59
    NimbusDog
    Tampa, FL
    2022 Tundra
    For sure. I personally found it annoying toyota sort of has 2 top level trims.. like their top off road style is trd pro, and top pavement princess is capstone... Id like a few capstone features on my trd please.
  30. Aug 17, 2025 at 1:57 PM
    #60
    BlackNBlu
    BlackNBlu Justa Member
    Rich
    MN
    The best explanation of the two in one place.
    Short answer: performance-wise, they're really not that different.
    NimbusDog and GODZILLA[QUOTED] like this.
